Re: [ATL] Problems installing ATL in Papyrus [message #642645 is a reply to message #642538] |
Thu, 02 December 2010 07:16   |
William Piers Messages: 297 Registered: July 2009 |
--------------050605060509050600010703
During the installation, there is a page named "Selection needed" which
displays certificates and asks "Do you trust these certificates?"
Below is a list of certificates with checkboxes above (in our case,
there is only one checkbox).
You have to check it before doing "Ok" in order to avoid the problem.
William
Le 01/12/2010 18:41, Luciane Agner a écrit :
> I need to use "ATL Transformation" in Papyrus. I tried to install the
> file m2m-atl-Update-3.1.1.zip in Papyrus, using the resource "Help
> Install New Software" but the following error message appears:
> An error occurred during the
> org.eclipse.equinox.internal.provisional.p2.engine.phases.Ch eckTrust
> phase.
> session context was:(profile=profile,
> phase=org.eclipse.equinox.internal.provisional.p2.engine.pha
> ses.CheckTrust, operand=null --> [R]org.antlr.runtime
> 3.0.0.v200803061811, action=).
> could you help me please?
> Thanks
> Luciane Agner
name="william_piers.vcf"
filename="william_piers.vcf"
YmVnaW46dmNhcmQNCmZuOldpbGxpYW0gUGllcnMNCm46UGllcnM7V2lsbGlh bQ0Kb3JnOk9i
ZW8NCmFkcjoyIHJ1ZSBSb2JlcnQgU2NodW1hbm47O2xvdCAyNDtOQU5URVM7 OzQ0NDA4O0Zy
YW5jZQ0KZW1haWw7aW50ZXJuZXQ6d2lsbGlhbS5waWVyc0BvYmVvLmZyDQp0 aXRsZTpNREEg
Q29uc3VsdGFudA0KdGVsO3dvcms6KzMzICgwKTIgNTEgMTMgNTAgNTMNCnVy bDpodHRwOi8v
d3d3Lm9iZW8uZnINCnZlcnNpb246Mi4xDQplbmQ6dmNhcmQNCg0K
--------------050605060509050600010703--
FUDForum. Page generated in 0.02185 seconds
