Home » Eclipse Projects » Marketplace Client Project » MarketPlace didn't work with my RCP(InvocationTargetException when opening MarketPlace Wizard)
MarketPlace didn't work with my RCP [message #642409] Wed, 01 December 2010 08:57 Go to next message
No real name is currently offline No real nameFriend
I am trying to integrate the Eclipse MarketPlace into my RCP program. I have added the "org.eclipse.epp.mpc.ui" dependency and copied org.eclipse.epp.mpc.*.jar into the Plugins folder. As the result I can launch the MarketPlace Wizard via the Help menu. But every time I got an "Unexpected Exception" when the Search/Recent/Popular tab opened.
Could anyone give me some advises to get the MarketPlace work with my RCP?
Stack trace:
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:421)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 1008)
at org.eclipse.epp.internal.mpc.ui.wizards.MarketplaceViewer.do Query(MarketplaceViewer.java:237)
at org.eclipse.epp.internal.mpc.ui.wizards.MarketplaceViewer.do Query(MarketplaceViewer.java:229)
at org.eclipse.epp.internal.mpc.ui.wizards.MarketplaceViewer.se tContentType(MarketplaceViewer.java:328)
at org.eclipse.epp.internal.mpc.ui.wizards.MarketplacePage$1.wi dgetSelected(MarketplacePage.java:111)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:234)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:4066)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3657)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.epp.internal.mpc.ui.commands.MarketplaceWizardCo mmand.execute(MarketplaceWizardCommand.java:140)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(Handle rProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command. java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.execute Command(SlaveHandlerService.java:241)
at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSel ection(CommandContributionItem.java:820)
at org.eclipse.ui.menus.CommandContributionItem.access$19(Comma ndContributionItem.java:806)
at org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(C ommandContributionItem.java:796)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2629)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2593)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 27)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:670)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:663)
at com.adobe.lcide.rcp.Application.start(Unknown Source)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
at org.eclipse.epp.internal.mpc.ui.catalog.MarketplaceDiscovery Strategy.handleSearchResult(MarketplaceDiscoveryStrategy.jav a:159)
at org.eclipse.epp.internal.mpc.ui.catalog.MarketplaceDiscovery Strategy.popular(MarketplaceDiscoveryStrategy.java:357)
at org.eclipse.epp.internal.mpc.ui.catalog.MarketplaceCatalog$3 .run(MarketplaceCatalog.java:86)
at org.eclipse.epp.internal.mpc.ui.catalog.MarketplaceCatalog.p erformDiscovery(MarketplaceCatalog.java:316)
at org.eclipse.epp.internal.mpc.ui.catalog.MarketplaceCatalog.p opular(MarketplaceCatalog.java:84)
at org.eclipse.epp.internal.mpc.ui.wizards.MarketplaceViewer$3. run(MarketplaceViewer.java:241)
at org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:121)
Re: MarketPlace didn't work with my RCP [message #642588 is a reply to message #642409] Wed, 01 December 2010 21:21 Go to previous messageGo to next message
Ian Skerrett is currently offline Ian SkerrettFriend
Are you trying to use the data from the Eclipse Marketplace or have you implemented your own catalog? To implement you own catalog you need to be following the api specified at http://wiki.eclipse.org/Marketplace/REST
Re: MarketPlace didn't work with my RCP [message #642618 is a reply to message #642588] Thu, 02 December 2010 02:07 Go to previous messageGo to next message
No, the data is from the Eclipse MarketPlace.
Re: MarketPlace didn't work with my RCP [message #642649 is a reply to message #642618] Thu, 02 December 2010 08:15 Go to previous messageGo to next message
The NullPointException occurred here:
Set knownRepositories = new HashSet(
          Arrays.asList(repositoryTracker.getKnownRepositories(session)));
so repositoryTracker must be null. This variable was returned by ProvisioningUI:
RepositoryTracker repositoryTracker = ProvisioningUI.getDefaultUI().getRepositoryTracker();
But according to
http:// help.eclipse.org/helios/index.jsp?topic=/org.eclipse.platfor m.doc.isv/reference/api/org/eclipse/equinox/p2/ui/Provisioni ngUI.html, the repository tracker must not be null. So are there some problems in my RCP configuration?
Re: MarketPlace didn't work with my RCP [message #658311 is a reply to message #642649] Mon, 07 March 2011 20:14 Go to previous message
Missing name Mising name is currently offline Missing name Mising nameFriend
In my case I had to add the org.eclipse.equinox.ds bundle and it's required plugins.
Previous Topic:Install multiple soultions via Marketplace Client
Next Topic:Profile id _SELF_ is not registered - when using MPC in my RCP application
Current Time: Mon May 17 01:41:41 GMT 2021
Powered by FUDForum. Page generated in 0.02081 seconds
