Re: IWAB0014E error when trying to create WebService in Helios [message #642355 is a reply to message #642271] |
Tue, 30 November 2010 23:50 |
Shane Clarke Messages: 67 Registered: July 2009 |
Member |
Couple of questions.
Was the environment on the other PC that was working the same as the Windows 7 box (Helios, Java, Tomcat, CXF versions) ?
On the Windows 7 box this isn't working:
At which point is the error thrown. On opening the Web services wizard for example?
If you open the Eclipse preferences and go to the Web Services > Server and Runtime preference page how many runtimes do you see listed in the "Web service runtime" combo box?
Shane
[Updated on: Tue, 30 November 2010 23:51] Report message to a moderator
Re: IWAB0014E error when trying to create WebService in Helios [message #642404 is a reply to message #642355] |
Wed, 01 December 2010 08:35 |
St Messages: 4 Registered: November 2010 |
Yes, both computers have the same environnement (cxf 2.3.0, latest, helios version, Tomcat 6...). It's the same project shared by svn.
This error happens when i want to generate a webservice from an java class (right click on a java interface -> Web Services -> Create Web Service).
The wizard dialog is not shown but the pop up error i mentioned appears.
I have the same error popup when i do File -> New -> Web Service (popup when i click on next).
In Web Service Runtime combobox, i see "Apache Axis", "Apache Axis2" and "Apache CXF 2.x"
In "CXF 2.x Preferences", I see 3 differents CXF runtimes :
* 2.2.10
* 2.2.6
* 2.3.0 (selected one but do the same if i select other)
Stéphane
[Updated on: Wed, 01 December 2010 09:01] Report message to a moderator
Re: IWAB0014E error when trying to create WebService in Helios [message #642413 is a reply to message #642404] |
Wed, 01 December 2010 09:08 |
Member |
Going on the stacktrace you posted it looks like no web service runtimes can be found when opening the web services wizard.
Possibly pointing to a problem loading the information from the extension points that contribute the runtimes.
Given that you've got the same version of Helios/WTP running successfully on another machine with the same environment, OS/Arch i'm thinking it's likely a bad install.
Could you try a fresh install on that machine?
[Updated on: Wed, 01 December 2010 09:27] Report message to a moderator
FUDForum. Page generated in 0.03971 seconds
