OSGI dependencies [message #641914] |
Mon, 29 November 2010 09:04 |
I'm developing a osgi enterprise application based on Virgo server. An application should have full support of json and Ajax and is running on Spring 3.0.5.RELEASE.
Her the problem starts. When deploying I have constant problems with a class org/codehaus/jackson/map/ObjectMapper. An exception that it does not exists.
I searched the forum and found this http:// www.eclipse.org/forums/index.php?t=msg&th=199043&S=5 c9780c0a5499fd8e0c9f8ac1b9e8379#msg_634843
link, which described the same problem.
I have org.codehous.jackson 1.6.1 defined in my pom.xml file and due to optional import of org.codehous.jackson in org.springsource.web I unjared the org.springsource.web 3.0.5.RELEASE jar to see what kind of version is requested in 3.0.5.RELEASE as in upper post was stated that the 3.0.0 version had optional dependency to 1.0.0. org.codehous.jackson package.
3.0.5.RELEASE requests [1.3.0 to 2.0.0) org.codehouse.jackson package so I have a correct version but I even exported jackson packages in my application bundle.
it still doesn't work.
Finally I connected to osgi console of Virgo server and checked vsh bundle list command. This is my output:
osgi> vsh bundle list
Id Name Version State
0 org.eclipse.osgi 3.6.1.R36x_v20100806 ACTIVE
1 org.eclipse.virgo.region.user 0.0.0 ACTIVE
2 org.eclipse.virgo.kernel.userregion 2.1.0.RELEASE ACTIVE
3 org.eclipse.virgo.kernel.osgicommand 2.1.0.RELEASE ACTIVE
4 org.springframework.osgi.core 1.2.1 ACTIVE
5 S org.springframework.osgi.extender 1.2.1 ACTIVE
6 org.springframework.osgi.io 1.2.1 ACTIVE
7 org.eclipse.virgo.kernel.agent.dm 2.1.0.RELEASE ACTIVE
8 S org.eclipse.virgo.kernel.deployer.dm 2.1.0.RELEASE ACTIVE
9 com.springsource.javax.ejb 3.0.0 ACTIVE
10 com.springsource.javax.el 1.0.0 ACTIVE
11 com.springsource.javax.jms 1.1.0 ACTIVE
12 com.springsource.javax.persistence 1.0.0 ACTIVE
13 com.springsource.javax.portlet 2.0.0 ACTIVE
14 com.springsource.javax.servlet 2.5.0 ACTIVE
15 com.springsource.javax.servlet.jsp 2.1.0 ACTIVE
16 com.springsource.javax.xml.rpc 1.1.0 ACTIVE
17 com.springsource.org.aopalliance 1.0.0 ACTIVE
18 com.springsource.org.apache.commons.codec 1.3.0 ACTIVE
19 com.springsource.org.apache.commons.fileupload 1.2.0 ACTIVE
20 com.springsource.org.apache.commons.httpclient 3.1.0 ACTIVE
21 com.springsource.org.apache.commons.io 1.4.0 ACTIVE
22 com.springsource.slf4j.api 1.6.1 ACTIVE
23 com.springsource.slf4j.nop 1.6.1 RESOLVED
24 com.springsource.slf4j.org.apache.log4j 1.6.1 ACTIVE
25 org.eclipse.virgo.kernel.dmfragment 2.1.0.RELEASE RESOLVED
26 org.springframework.aop 3.0.0.RELEASE ACTIVE
27 org.springframework.asm 3.0.0.RELEASE ACTIVE
28 org.springframework.beans 3.0.0.RELEASE ACTIVE
29 org.springframework.context 3.0.0.RELEASE ACTIVE
30 org.springframework.core 3.0.0.RELEASE ACTIVE
31 org.springframework.expression 3.0.0.RELEASE ACTIVE
32 org.springframework.jdbc 3.0.0.RELEASE ACTIVE
33 org.springframework.orm 3.0.0.RELEASE ACTIVE
34 org.springframework.oxm 3.0.0.RELEASE ACTIVE
35 org.springframework.transaction 3.0.0.RELEASE ACTIVE
36 org.springframework.web 3.0.0.RELEASE ACTIVE
37 org.eclipse.gemini.web.core 1.1.0.RELEASE ACTIVE
38 S org.eclipse.gemini.web.tomcat 1.1.0.RELEASE ACTIVE
39 S org.eclipse.virgo.web.core 2.1.0.RELEASE ACTIVE
40 org.eclipse.virgo.web.dm 2.1.0.RELEASE ACTIVE
41 org.eclipse.virgo.web.tomcat 2.1.0.RELEASE ACTIVE
42 com.springsource.javax.annotation 1.0.0 ACTIVE
43 com.springsource.javax.mail 1.4.0 ACTIVE
44 com.springsource.org.apache.catalina.ha.springsource 6.0.29.S2-r1559 RESOLVED
45 com.springsource.org.apache.catalina.springsource 6.0.29.S2-r1559 ACTIVE
46 com.springsource.org.apache.catalina.tribes.springsource 6.0.29.S2-r1559 RESOLVED
47 com.springsource.org.apache.coyote.springsource 6.0.29.S2-r1559 RESOLVED
48 com.springsource.org.apache.el.springsource 6.0.29.S2-r1559 ACTIVE
49 com.springsource.org.apache.jasper.springsource 6.0.29.S2-r1559 RESOLVED
50 com.springsource.org.apache.juli.extras.springsource 6.0.29.S2-r1559 ACTIVE
51 org.eclipse.jdt.core.compiler.batch 3.3.0 ACTIVE
52 S org.eclipse.virgo.apps.admin.core 2.1.0.RELEASE ACTIVE
53 S org.eclipse.virgo.apps.admin.web 2.1.0.RELEASE ACTIVE
54 com.springsource.javax.servlet.jsp.jstl 1.1.2 ACTIVE
55 com.springsource.org.apache.taglibs.standard 1.1.2 ACTIVE
56 org.springframework.context.support 3.0.0.RELEASE ACTIVE
57 org.springframework.js 2.0.8.RELEASE ACTIVE
58 org.springframework.web.servlet 3.0.0.RELEASE ACTIVE
59 S org.eclipse.virgo.apps.repository-2.1.0.RELEASE-org.eclipse.virgo.apps.repository.core 2.1.0.RELEASE ACTIVE
60 S org.eclipse.virgo.apps.repository-2.1.0.RELEASE-org.eclipse.virgo.apps.repository.web 2.1.0.RELEASE ACTIVE
61 org.eclipse.virgo.apps.repository-2.1.0.RELEASE-synthetic.context 2.1.0.RELEASE ACTIVE
62 org.eclipse.virgo.apps.splash 2.1.0.RELEASE ACTIVE
63 S com.objectverse.web 1.0.0 ACTIVE
64 org.springframework.aspects 3.0.0.RELEASE ACTIVE
65 org.springframework.jms 3.0.0.RELEASE ACTIVE
66 org.springframework.web.portlet 3.0.0.RELEASE ACTIVE
osgi>
My application is correctly deployed and started. What cought my eye was 3.0.0.RELEASE spring packages. Why? I have 3.0.5.RELEASE in my pom.xml defined.
Shouldn't there be a higher version of these bundles installed?
Bojan
Re: OSGI dependencies [message #643135 is a reply to message #642190] |
Sun, 05 December 2010 00:19 |
here is the result. I downloaded dependent bundles to target/depnendency directory. I copied 3.0.5 version to repository/ext folder and changed libd file. The server doesn't wanna boot. It searches for 3.0.0 bundles.
Should I change something else?
Bojan
[Updated on: Sun, 05 December 2010 00:37] Report message to a moderator
Re: OSGI dependencies [message #643274 is a reply to message #643135] |
Mon, 06 December 2010 11:06 |
Glyn Normington Messages: 1222 Registered: July 2009 |
Please check that you have deleted the file org.springframework.spring-library-3.0.0.RELEASE.libd from repository/ext and have also deleted all the bundles that org.springframework.spring-library-3.0.0.RELEASE.libd refers to from repository/ext.
Then make sure you have copied org.springframework.spring-library-3.0.5.RELEASE.libd and copied all the (3.0.5) bundles it refers to repository/ext.
Then start the server with the -clean option and let us know what happens. The server should start up as normal and use Spring 3.0.5.
[Updated on: Mon, 06 December 2010 11:08] Report message to a moderator
Re: OSGI dependencies [message #643711 is a reply to message #643274] |
Tue, 07 December 2010 23:19 |
Thanks. I followed your steps. Here is the content of the repository/ext folder:
Volume in drive C has no label.
Volume Serial Number is F0B5-01D1
Directory of C:\springsource\virgo-web-server-2.1.0.RELEASE\repository\ext
08.12.2010 00:12 <DIR> .
08.12.2010 00:12 <DIR> ..
04.02.2009 14:31 63.759 com.springsource.javax.activation-1.1.0.jar
04.02.2009 14:20 6.195 com.springsource.javax.annotation-1.0.0.jar
03.08.2009 12:43 34.176 com.springsource.javax.ejb-3.0.0.jar
04.02.2009 14:32 29.892 com.springsource.javax.el-1.0.0.jar
04.02.2009 13:02 26.178 com.springsource.javax.jms-1.1.0.jar
04.02.2009 14:35 393.311 com.springsource.javax.mail-1.4.0.jar
04.02.2009 13:50 53.773 com.springsource.javax.persistence-1.0.0.jar
04.02.2009 13:38 48.648 com.springsource.javax.portlet-2.0.0.jar
04.02.2009 13:02 89.582 com.springsource.javax.servlet-2.5.0.jar
04.02.2009 13:30 82.151 com.springsource.javax.servlet.jsp-2.1.0.jar
05.02.2009 14:27 21.266 com.springsource.javax.servlet.jsp.jstl-1.1.2.jar
03.08.2009 13:00 15.518 com.springsource.javax.transaction-1.1.0.jar
04.02.2009 13:14 91.992 com.springsource.javax.xml.bind-2.1.7.jar
04.02.2009 13:34 32.322 com.springsource.javax.xml.rpc-1.1.0.jar
04.02.2009 13:34 19.496 com.springsource.javax.xml.soap-1.3.0.jar
04.02.2009 13:12 26.729 com.springsource.javax.xml.stream-1.0.1.jar
04.02.2009 13:20 4.615 com.springsource.org.aopalliance-1.0.0.jar
07.09.2010 16:18 131.230 com.springsource.org.apache.catalina.ha.springsource-6.0.29.S2-r1559.jar
26.08.2010 16:01 1.216.256 com.springsource.org.apache.catalina.springsource-6.0.29.S2-r1559.jar
07.09.2010 16:21 237.564 com.springsource.org.apache.catalina.tribes.springsource-6.0.29.S2-r1559.jar
04.02.2009 13:04 47.421 com.springsource.org.apache.commons.codec-1.3.0.jar
04.02.2009 13:39 54.080 com.springsource.org.apache.commons.fileupload-1.2.0.jar
04.02.2009 13:05 307.965 com.springsource.org.apache.commons.httpclient-3.1.0.jar
04.02.2009 13:39 110.412 com.springsource.org.apache.commons.io-1.4.0.jar
26.08.2010 16:06 764.928 com.springsource.org.apache.coyote.springsource-6.0.29.S2-r1559.jar
27.08.2010 09:29 110.019 com.springsource.org.apache.el.springsource-6.0.29.S2-r1559.jar
02.09.2010 17:39 532.849 com.springsource.org.apache.jasper.springsource-6.0.29.S2-r1559.jar
26.08.2010 15:37 26.944 com.springsource.org.apache.juli.extras.springsource-6.0.29.S2-r1559.jar
04.02.2009 14:08 398.371 com.springsource.org.apache.taglibs.standard-1.1.2.jar
07.10.2009 17:53 1.614.157 com.springsource.org.aspectj.weaver-1.6.6.RELEASE.jar
03.08.2010 11:34 25.982 com.springsource.slf4j.api-1.6.1.jar
03.08.2010 17:58 4.738 com.springsource.slf4j.bridge-1.6.1.jar
03.08.2010 15:36 4.998 com.springsource.slf4j.nop-1.6.1.jar
03.08.2010 18:05 17.616 com.springsource.slf4j.org.apache.commons.logging-1.6.1.jar
04.08.2010 14:19 12.646 com.springsource.slf4j.org.apache.log4j-1.6.1.jar
08.12.2010 00:12 0 list.txt
15.09.2009 12:12 85.016 org.apache.felix.configadmin-1.2.4.jar
08.06.2009 16:56 73.372 org.apache.felix.eventadmin-1.0.0.jar
14.07.2009 14:43 22.291 org.apache.felix.log-1.0.0.jar
04.02.2009 16:38 60.384 org.eclipse.equinox.cm-1.0.0.v20080509-1800.jar
28.10.2010 12:05 62.312 org.eclipse.gemini.web.core-1.1.0.RELEASE.jar
28.10.2010 12:05 188.900 org.eclipse.gemini.web.tomcat-1.1.0.RELEASE.jar
27.08.2010 11:53 1.563.059 org.eclipse.jdt.core-3.3.1.v_780_R33x.jar
04.02.2009 16:38 63.665 org.eclipse.osgi.services-3.1.200.v20071203.jar
28.10.2010 13:14 32.696 org.eclipse.virgo.apps.admin.core-2.1.0.RELEASE.jar
28.10.2010 13:14 1.733.481 org.eclipse.virgo.apps.admin.web-2.1.0.RELEASE.war
28.10.2010 11:20 23.248 org.eclipse.virgo.kernel.agent.dm-2.1.0.RELEASE.jar
28.10.2010 11:23 37.372 org.eclipse.virgo.kernel.artifact-2.1.0.RELEASE.jar
28.10.2010 11:23 155.248 org.eclipse.virgo.kernel.core-2.1.0.RELEASE.jar
28.10.2010 11:24 456.840 org.eclipse.virgo.kernel.deployer-2.1.0.RELEASE.jar
28.10.2010 11:24 8.704 org.eclipse.virgo.kernel.deployer.dm-2.1.0.RELEASE.jar
28.10.2010 11:06 24.956 org.eclipse.virgo.kernel.dmfragment-2.1.0.RELEASE.jar
28.10.2010 11:24 55.929 org.eclipse.virgo.kernel.osgi-2.1.0.RELEASE.jar
28.10.2010 11:24 51.961 org.eclipse.virgo.kernel.services-2.1.0.RELEASE.jar
28.10.2010 11:20 966 org.eclipse.virgo.kernel.userregion.springdm.plan
28.10.2010 10:57 14.064 org.eclipse.virgo.medic-2.1.0.RELEASE.jar
28.10.2010 10:57 561.741 org.eclipse.virgo.medic.core-2.1.0.RELEASE.jar
28.10.2010 10:43 21.266 org.eclipse.virgo.osgi.extensions.equinox-2.1.0.RELEASE.jar
28.10.2010 10:43 22.032 org.eclipse.virgo.osgi.launcher-2.1.0.RELEASE.jar
28.10.2010 11:01 155.003 org.eclipse.virgo.repository-2.1.0.RELEASE.jar
28.10.2010 13:03 883 org.eclipse.virgo.web-2.1.0.RELEASE.plan
28.10.2010 13:03 27.195 org.eclipse.virgo.web.core-2.1.0.RELEASE.jar
28.10.2010 13:02 6.590 org.eclipse.virgo.web.dm-2.1.0.RELEASE.jar
28.10.2010 13:03 22.643 org.eclipse.virgo.web.tomcat-2.1.0.RELEASE.jar
17.11.2010 22:03 321.190 org.springframework.aop-3.0.5.RELEASE.jar
17.11.2010 22:03 53.082 org.springframework.asm-3.0.5.RELEASE.jar
17.11.2010 22:03 35.548 org.springframework.aspects-3.0.5.RELEASE.jar
17.11.2010 22:03 555.410 org.springframework.beans-3.0.5.RELEASE.jar
17.11.2010 22:03 668.861 org.springframework.context-3.0.5.RELEASE.jar
17.11.2010 22:03 100.870 org.springframework.context.support-3.0.5.RELEASE.jar
17.11.2010 22:03 382.442 org.springframework.core-3.0.5.RELEASE.jar
17.11.2010 22:03 169.752 org.springframework.expression-3.0.5.RELEASE.jar
17.11.2010 22:03 1.810 org.springframework.instrument-3.0.5.RELEASE.jar
17.11.2010 22:10 385.712 org.springframework.jdbc-3.0.5.RELEASE.jar
17.11.2010 22:03 185.312 org.springframework.jms-3.0.5.RELEASE.jar
06.08.2009 23:44 1.206.223 org.springframework.js-2.0.8.RELEASE.jar
17.11.2010 22:03 334.327 org.springframework.orm-3.0.5.RELEASE.jar
16.12.2009 17:32 362.889 org.springframework.osgi.core-1.2.1.jar
16.12.2009 17:34 120.822 org.springframework.osgi.extender-1.2.1.jar
16.12.2009 17:33 35.859 org.springframework.osgi.io-1.2.1.jar
17.11.2010 22:03 61.379 org.springframework.oxm-3.0.5.RELEASE.jar
17.11.2010 22:03 1.313 org.springframework.spring-library-3.0.5.RELEASE.libd
17.11.2010 22:03 231.922 org.springframework.transaction-3.0.5.RELEASE.jar
17.11.2010 22:03 395.587 org.springframework.web-3.0.5.RELEASE.jar
17.11.2010 22:03 175.412 org.springframework.web.portlet-3.0.5.RELEASE.jar
17.11.2010 22:03 418.977 org.springframework.web.servlet-3.0.5.RELEASE.jar
86 File(s) 18.394.295 bytes
2 Dir(s) 288.980.983.808 bytes free
I added -clean tag to the server startup parameters in SpringSource.
I get following error, when I start the server:
[2010-12-08 00:10:22.605] startup-tracker <KE0001I> Kernel starting.
[2010-12-08 00:10:25.625] startup-tracker <KE0002I> Kernel started.
[2010-12-08 00:10:25.736] system-artifacts <DE0000I> Installing plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-12-08 00:10:27.313] system-artifacts <DE0000I> Installing bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-12-08 00:10:27.754] system-artifacts <DE0000I> Installing bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-12-08 00:10:27.868] system-artifacts <DE0000I> Installing bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-12-08 00:10:27.944] system-artifacts <DE0000I> Installing bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.RELEASE'.
[2010-12-08 00:10:28.004] system-artifacts <DE0000I> Installing bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.RELEASE'.
[2010-12-08 00:10:30.994] system-artifacts <DE0002E> Installation of plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0' failed. org.eclipse.virgo.kernel.deployer.core.DeploymentException: commit failed
at org.eclipse.virgo.kernel.install.pipeline.stage.resolve.internal.CommitStage.process(CommitStage.java:41)
at org.eclipse.virgo.kernel.install.pipeline.internal.StandardPipeline.doProcessTree(StandardPipeline.java:62)
at org.eclipse.virgo.kernel.install.pipeline.internal.CompensatingPipeline.doProcessTree(CompensatingPipeline.java:72)
at org.eclipse.virgo.kernel.install.pipeline.stage.AbstractPipelineStage.process(AbstractPipelineStage.java:41)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.driveInstallPipeline(PipelinedApplicationDeployer.java:271)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.doInstall(PipelinedApplicationDeployer.java:151)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.install(PipelinedApplicationDeployer.java:123)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.deploy(PipelinedApplicationDeployer.java:190)
at org.eclipse.virgo.kernel.userregion.internal.InitialArtifactDeployer$ArtifactDeployingRunnable.deployArtifacts(InitialArtifactDeployer.java:155)
at org.eclipse.virgo.kernel.userregion.internal.InitialArtifactDeployer$ArtifactDeployingRunnable.run(InitialArtifactDeployer.java:145)
at java.lang.Thread.run(Thread.java:619)
Caused by: org.osgi.framework.BundleException: An error occurred trying to read the bundle
at org.eclipse.osgi.internal.baseadaptor.BundleInstall.begin(BundleInstall.java:94)
at org.eclipse.osgi.framework.internal.core.Framework.installWorkerPrivileged(Framework.java:921)
at org.eclipse.osgi.framework.internal.core.Framework$1.run(Framework.java:837)
at org.eclipse.osgi.framework.internal.core.Framework.installWorker(Framework.java:888)
at org.eclipse.osgi.framework.internal.core.Framework.installBundle(Framework.java:832)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.installBundle(BundleContextImpl.java:167)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.installBundle(BundleContextImpl.java:161)
at org.eclipse.virgo.kernel.userregion.internal.quasi.StandardQuasiFramework.doInstallBundleInternal(StandardQuasiFramework.java:399)
at org.eclipse.virgo.kernel.userregion.internal.quasi.StandardQuasiFramework.installBundleDescription(StandardQuasiFramework.java:395)
at org.eclipse.virgo.kernel.userregion.internal.quasi.StandardQuasiFramework.installOtherBundles(StandardQuasiFramework.java:338)
at org.eclipse.virgo.kernel.userregion.internal.quasi.StandardQuasiFramework.commit(StandardQuasiFramework.java:297)
at org.eclipse.virgo.kernel.install.pipeline.stage.resolve.internal.CommitStage.process(CommitStage.java:39)
... 12 common frames omitted
Caused by: java.io.FileNotFoundException: C:\springsource\virgo-web-server-2.1.0.RELEASE\repository\ext\org.springframework.aop-3.0.0.RELEASE.jar (The system cannot find the file specified)
at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.<init>(FileInputStream.java:106)
at java.io.FileInputStream.<init>(FileInputStream.java:66)
at sun.net.www.protocol.file.FileURLConnection.connect(FileURLConnection.java:70)
at sun.net.www.protocol.file.FileURLConnection.getInputStream(FileURLConnection.java:161)
at org.eclipse.osgi.internal.baseadaptor.BundleInstall.begin(BundleInstall.java:56)
... 24 common frames omitted
[2010-12-08 00:10:31.003] system-artifacts <DE0003E> Install failed for bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-12-08 00:10:31.007] system-artifacts <DE0003E> Install failed for bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-12-08 00:10:31.011] system-artifacts <DE0003E> Install failed for bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-12-08 00:10:31.015] system-artifacts <DE0003E> Install failed for bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.RELEASE'.
[2010-12-08 00:10:31.019] system-artifacts <DE0003E> Install failed for bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.RELEASE'.
[2010-12-08 00:10:31.023] system-artifacts <DE0003E> Install failed for plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-12-08 00:10:31.058] system-artifacts <UR0002E> User region failed while deploying initial artifacts. Shutting down.
[2010-12-08 00:10:31.064] System Bundle Shutdown <KE0010I> Shutdown initiated.
I have no ideas where is the reference to the 3.0.0. bundle. I also manually triggered clean of the project, clean of the Virgo server and also I manually deleted my whole application in stage folder as also in work folder.
Re: OSGI dependencies [message #643765 is a reply to message #643753] |
Wed, 08 December 2010 08:33 |
I started the serve from the console with startup.bat -clean and it still failed. Then I opened startup.bat and started the server with dmk.bat -clean and it started correctly.
After that it starts also in eclipse. Now I have org.springsource.mock.staticmock problem to solve.
Thank you for all your time and support.
Bojan
FUDForum. Page generated in 0.02954 seconds
