Home » Eclipse Projects » Eclipse Platform » visible tabs(Getting control over what comes up in new windows)
visible tabs [message #641280] Wed, 24 November 2010 17:56 Go to next message
Missing name Mising name is currently offline Missing name Mising nameFriend
How can a default window layout be set-up? If I I make a new window I'd like to get the same tabs as before or at least a very minimal set of them. In other words, can I prevent the Outline tab, the Make Target Tab, the Task List tab, the Remote Environments tab, the tasks Tab, and so forth from showing? I want to primarily see and edit my code, and that part of the window doesn't end up with much space by default.
Re: visible tabs [message #641293 is a reply to message #641280] Wed, 24 November 2010 18:49 Go to previous message
Paul Webster is currently offline Paul WebsterFriend
You can create your own perspective with almost nothing in it.
But if you mean just in general usage:
1) open a starting perspective
2) customize it by closing views and changing the layout
3) Use Window>Save Perspective As to save it to a new name
Then just open new windows with your new perspective.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Previous Topic:Maven Error assembling WAR
Next Topic:Build a project when another is closed
Current Time: Fri Mar 05 02:05:58 GMT 2021
Powered by FUDForum. Page generated in 0.02654 seconds
