Re: Change partially color of scatter chart line [message #641246 is a reply to message #641169] |
Wed, 24 November 2010 15:42 |
Helmut,
All line segments in a scatter chart have to have the same color for any
one series. The last place you can change it is in the beforeDrawSeries
script like:
function beforeDrawSeries( series, isr, icsc )
if( series.getClass() == ScatterSeriesImpl ){
series.getLineAttributes().getColor().set(0,255,0);
Jason
On 11/24/2010 8:21 AM, Helmut Neubauer wrote:
> I've a scatter chart showing the line between the markers and I would
> like to change the color if the associated values are greater than a
> defined value.
> I tried to use beforeDrawDataPoint with fill, but I could only change
> the marker color using this way.
> Perhaps you can help me?
> Helmut
Re: Change partially color of scatter chart line [message #641615 is a reply to message #641246] |
Fri, 26 November 2010 10:33 |
No real name Messages: 7 Registered: November 2010 |
Had the same problem, just use this code snippet on the onRender() Event for the chart. I had to use a dynamic border line and change the color of the bars in a bar chart to change the color (green, yellow, red) based on the borders and a small calculation for the yellow ones if it's between a unvisible border between 75% and the database border (100%)
good luck!
Nadine
* Called before rendering Series.
* @param series
* Series
* @param isr
* ISeriesRenderer
* @param icsc
* IChartScriptContext
var ot;
var ut;
var ot75;
var ut75;
* Called after populating the series dataset.
* @param series
* Series
* @param dataSet
* DataSet
* @param icsc
function afterDataSetFilled( series, dataSet, icsc )
if (series.getSeriesIdentifier()=="OT"){
var list = dataSet.getValues();
if (list.length > 0){
ot = list[0];
ot75 = ot * 0.75;
} else if (series.getSeriesIdentifier()=="UT"){
ut = list[0];
ut75 = ut * 0.75;
* Called after drawing each datapoint graphical representation or marker.
* @param dph
* DataPointHints
* @param fill
* Fill
* @param icsc
function beforeDrawDataPoint( dph, fill, icsc )
var xVal = dph.getOrthogonalValue();
if (xVal >= 0){
if (xVal >= ot) {
fill.set(255,0,0);
else if ((xVal >= ot75) && (xVal < ot)){
fill.set(255,255,0);
} else if (xVal < ot75){
fill.set(0,255,0);
else if (xVal < 0){
if (xVal <= ut){
fill.set(255,0,0);
else if ((xVal <= ut75) && (xVal > ut)){
else if ((xVal > ut75) && (xVal < 0)){
fill.set(0,255,0);
FUDForum. Page generated in 0.01947 seconds
