Re: GRAPHITI based editor in a RCP [message #709125 is a reply to message #675940] |
Wed, 03 August 2011 14:21 |
Christian B Messages: 68 Registered: August 2011 |
Member |
thanks for the input, i was able to get the editor into my RCP, but i have a follow up question.
Murthybhat wrote on Wed, 01 June 2011 23:53Also for a RCP, I had to extend a editor in Plugin.xml and have the class extend "org.eclipse.graphiti.ui.editor.DiagramEditor".
Why do you have to to this? I didn't have to , but the editor is there anyhow. I think this is due to the fact that i load the org.eclipse.graphiti.ui plugin in my product and this plugin registers the view in its plugin.xml. Can you explain which plugins from graphiti you load for your RCP and if i shouldn't load org.eclipse.graphiti.ui?
thanks!
[Updated on: Wed, 03 August 2011 14:28] Report message to a moderator
FUDForum. Page generated in 0.02177 seconds
