Home » Archived » M2M (model-to-model transformation) » [QVTo] Operation or atribute similar to the _xmiID_ of ATL.
Re: [QVTo] Operation or atribute similar to the _xmiID_ of ATL. [message #640391 is a reply to message #640386] |
Sun, 21 November 2010 15:19   |
Toñi Reina Messages: 209 Registered: July 2009 |
Hi Ed,
the problem is that I need to relate objects from to different
models, and I have used the reference that is in an xmi file. Thus, for
example, I have the model:
<SWC:WebFlow xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:SWC="http://org.mwacsl.swc"
xsi:schemaLocation="http://org.mwacsl.swc ../metamodel/SWC.ecore"
project="cinemaApp" author="AMRQ" version="1.0.1" initial="//@nodes.0"
id="CinemaApp">
<transitions id="login" source="//@nodes.0" target="//@nodes.1"/>
<transitions id="movies" source="//@nodes.1" target="//@nodes.2"/>
<transitions id="exit1" source="//@nodes.1" target="//@nodes.4"
guard=""/>
<transitions id="book" source="//@nodes.2" target="//@nodes.1"/>
<transitions id="exit2" source="//@nodes.2" target="//@nodes.4"/>
<transitions id="details" source="//@nodes.2" target="//@nodes.5"/>
<transitions id="exit3" source="//@nodes.3" target="//@nodes.4"/>
<transitions id="end" source="//@nodes.4" target="//@nodes.6"/>
<transitions id="back" source="//@nodes.5" target="//@nodes.2"/>
<nodes xsi:type="SWC:FrontEndView" id="UserLogin" label="UserLogin"
outgoingTrans="//@transitions.0"/>
<nodes xsi:type="SWC:FrontEndView" id="GreatTheUser"
incomingTrans="//@transitions.0 //@transitions.3" label="GreatTheUser"
outgoingTrans="//@transitions.1 //@transitions.2"/>
<nodes xsi:type="SWC:FrontEndView" id="ShowMovieList"
incomingTrans="//@transitions.1 //@transitions.8" label="ShowMovieList"
outgoingTrans="//@transitions.3 //@transitions.4 //@transitions.5"/>
<nodes xsi:type="SWC:FrontEndView" id="ShowTransitionSummary"
label="ShowTransitionSummary" outgoingTrans="//@transitions.6"/>
<nodes xsi:type="SWC:FrontEndView" id="Exit"
incomingTrans="//@transitions.2 //@transitions.4 //@transitions.6"
label="Exit" outgoingTrans="//@transitions.7"/>
<nodes xsi:type="SWC:FrontEndView" id="ShowMovieDetails"
incomingTrans="//@transitions.5" label="ShowMovieDetails"
outgoingTrans="//@transitions.8"/>
<nodes xsi:type="SWC:EndState" id="EndState"
incomingTrans="//@transitions.7"/>
</SWC:WebFlow>
that conforms to org.mwacsl.swc metamodel (a metamodel I have previously
defined). My question is, once I have the object correspoding to
<transitions id="login" source="//@nodes.0" target="//@nodes.1"/>, how
can I obtain the reference //@transitions.0 that EMF associates to this
object using QVT?
Toñi
El 21/11/2010 15:39, Ed Willink escribió:
> Hi Toni
> It will be easier to help if you state your problem, rather than a
> particular tool-specific solution that you require another tool to emulate.
> Regards
> Ed Willink
> On 21/11/2010 11:30, Toñi Reina Quintero wrote:
>> Hi all,
>> I'm looking for an operation or an attribute in QVT similar to the
>> _xmiID_ of ATL.
>> The only thing I've found are _localId() and _globalId(), but they
>> aren't implemented in QVTo yet.
>> Could anybody confirm that they are similars or give me any hint about
>> this subject??
Re: [QVTo] Operation or atribute similar to the _xmiID_ of ATL. [message #640406 is a reply to message #640391] |
Sun, 21 November 2010 18:49   |
Ed Willink Messages: 6985 Registered: July 2009 |
Hi Toni
It depends what meta-model you use.
If you use SWC.ecore then the xmi:ids are an implementation secret that
arguably should not be exposed. The whole principle of XMI is that
references are resolved so you just deal with objects/elements.
If you use the XMI meta-model then you can do whatever you like, but I
think you should really consider why you want the reference in the first
place.
Ed Willink
On 21/11/2010 15:19, Toñi Reina Quintero wrote:
> Hi Ed,
> for example, I have the model:
> id="CinemaApp">
> guard=""/>
> label="ShowMovieList" outgoingTrans="//@transitions.3 //@transitions.4
> //@transitions.5"/>
> </SWC:WebFlow>
> previously defined). My question is, once I have the object
> correspoding to <transitions id="login" source="//@nodes.0"
> target="//@nodes.1"/>, how can I obtain the reference //@transitions.0
> that EMF associates to this object using QVT?
> Regards,
> Toñi
>> Hi Toni
>> emulate.
>> Regards
>> Ed Willink
>>> Hi all,
>>> _xmiID_ of ATL.
>>> this subject??
Re: [QVTo] Operation or atribute similar to the _xmiID_ of ATL. [message #640412 is a reply to message #640406] |
Sun, 21 November 2010 19:35   |
Hi Ed,
Thanks for your answer. I was thinking in a generic way of relating
models, in a similar way to model weaving. So that, instead of make my
meta-models must have an id, I was thinking in using this id in a
reflective way. But, due to your answer, I'm afraid I cannot do it as I
was thinking, that is, using a query in QVT which could return an
object, given its id.
Toñi
E 21/11/2010 19:49, Ed Willink escribió:
> Hi Toni
> place.
> Regards
> Ed Willink
>> Hi Ed,
>> the problem is that I need to relate objects from to different models,
>> id="CinemaApp">
>> guard=""/>
>> //@transitions.5"/>
>> </SWC:WebFlow>
>> Regards,
>> Toñi
>>> Hi Toni
>>> emulate.
>>> Regards
>>> Ed Willink
>>>> Hi all,
>>>> _xmiID_ of ATL.
>>>> this subject??
Re: [QVTo] Operation or atribute similar to the _xmiID_ of ATL. [message #640417 is a reply to message #640412] |
Sun, 21 November 2010 21:36   |
Hi Toni
If you really want ids you can write a black box transformation to
compute one.
Ed Willink
On 21/11/2010 19:35, Toñi Reina Quintero wrote:
> Hi Ed,
> Regards,
> Toñi
>> Hi Toni
>> place.
>> Regards
>> Ed Willink
>>> Hi Ed,
>>> id="CinemaApp">
>>> guard=""/>
>>> //@transitions.5"/>
>>> </SWC:WebFlow>
>>> Regards,
>>> Toñi
>>>> Hi Toni
>>>> emulate.
>>>> Regards
>>>> Ed Willink
>>>>> Hi all,
>>>>> _xmiID_ of ATL.
>>>>> this subject??
Re: [QVTo] Operation or atribute similar to the _xmiID_ of ATL. [message #640422 is a reply to message #640417] |
Sun, 21 November 2010 22:40  |
I think that's the best option. Could you tell me if the current
implementation of QVTo supports these black box transformations?
Toñi Reina
El 21/11/2010 22:36, Ed Willink escribió:
> Hi Toni
> compute one.
> Regards
> Ed Willink
>> Hi Ed,
>> Regards,
>> Toñi
>>> Hi Toni
>>> place.
>>> Regards
>>> Ed Willink
>>>> Hi Ed,
>>>> id="CinemaApp">
>>>> guard=""/>
>>>> //@transitions.5"/>
>>>> </SWC:WebFlow>
>>>> Regards,
>>>> Toñi
>>>>> Hi Toni
>>>>> emulate.
>>>>> Regards
>>>>> Ed Willink
>>>>>> Hi all,
>>>>>> _xmiID_ of ATL.
>>>>>> about
>>>>>> this subject??
Current Time: Sun Jan 17 14:12:19 GMT 2021
Powered by FUDForum. Page generated in 0.02129 seconds
