Re: data loss while exporting pdf [message #640946 is a reply to message #640760] |
Tue, 23 November 2010 16:00 |
I assume there is no white space in the data as this should cause a wrap
automatically. There are css tricks but they only work on HTML and not
the PDF output. One option may be to implement the js code as an event
handler in java. It may run quicker for you.
Jason
On 11/22/2010 11:29 PM, paladine wrote:
> I have seen this post Jason but it is not a good solution for me because
> i dont wanna use javascript. it makes my monitoring process slower.
> sometimes, i am monitoring more than 1000 pages and this javascript runs
> 1000 times at that situation. I am looking for a built-in method as css
> or column size tricks.
> do you have any other solution ?
> thanks in advance
FUDForum. Page generated in 0.03601 seconds
