Re: Eclipse Tasks TODO [message #640293 is a reply to message #640274] |
Sat, 20 November 2010 02:42 |
Deepak Azad Messages: 543 Registered: July 2009 |
On 11/20/2010 2:27 AM, adam.balgach@gmail.com wrote:
> All -
> I have eclipse set up with 2 projects in it, the 2nd project has linked
> source from the first project.
> In various parts around the code i have the //TODO task to help keep
> track of unimplemented methods, etc. My question is in eclipse, under
> the Tasks view, i see duplicated tasks for the TODO items in the linked
> source. Is there way to see only TODO items in non-linked source.
> IE. i would like to see all the TODOs in project 1, and all the TODOs in
> project 2, however, no see the overlapping ones from the linked source
> in project 2. Might not be possible, have spent a while trying to figure
> it out.
> Thanks-
> A.
- Open the Task view's view menu (the inverted triangle icon on the top
right of the view)
- Configure contents
- under 'Scope' select 'On selected element and its children'
Now when you select a project in Package explorer you will see TODO's
for only that project
(Note: you can configure other views in the same way, e.g. problems view)
FUDForum. Page generated in 0.02522 seconds
