The plugin 'org.apache.maven.plugins:maven-eclispe-plugin' does not exist or no valid version could [message #640165] |
Fri, 19 November 2010 12:15 |
swapnil patil Messages: 2 Registered: November 2010 |
Hi ,
When I Run mvn -P test eclispe:eclipse -e command
getting following exception
[INFO] Scanning for projects...
[INFO] Searching repository for plugin with prefix: 'eclispe'.
[INFO] ------------------------------------------------------------ ------------
[ERROR] BUILD ERROR
[INFO] The plugin 'org.apache.maven.plugins:maven-eclispe-plugin' does not exist or no valid version could be found
[INFO] Trace
org.apache.maven.lifecycle.LifecycleExecutionException: The plugin 'org.apache.maven.plugins:maven-eclispe-plugin' does not exist or no valid version could be found
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.verifyPl ugin(DefaultLifecycleExecutor.java:1569)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.getMojoD escriptor(DefaultLifecycleExecutor.java:1851)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.segmentT askListByAggregationNeeds(DefaultLifecycleExecutor.java:462)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.execute( DefaultLifecycleExecutor.java:175)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:32
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:138)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:362)
at org.apache.maven.cli.compat.CompatibleMain.main(CompatibleMa in.java:60)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.codehaus.classworlds.Launcher.launchEnhanced(Launcher.ja va:315)
at org.codehaus.classworlds.Launcher.launch(Launcher.java:255)
at org.codehaus.classworlds.Launcher.mainWithExitCode(Launcher. java:430)
at org.codehaus.classworlds.Launcher.main(Launcher.java:375)
Caused by: org.apache.maven.plugin.version.PluginVersionNotFoundExcepti on: The plugin 'org.apache.maven.plugins:maven-eclispe-plugin' does not exist or no valid version could be found
at org.apache.maven.plugin.version.DefaultPluginVersionManager. resolvePluginVersion(DefaultPluginVersionManager.java:229)
at org.apache.maven.plugin.version.DefaultPluginVersionManager. resolvePluginVersion(DefaultPluginVersionManager.java:91)
at org.apache.maven.plugin.DefaultPluginManager.verifyPlugin(De faultPluginManager.java:179)
at org.apache.maven.plugin.DefaultPluginManager.loadPluginDescr iptor(DefaultPluginManager.java:1642)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.verifyPl ugin(DefaultLifecycleExecutor.java:1540)
... 15 more
[INFO] Total time: < 1 second
[INFO] Finished at: Fri Nov 19 14:40:22 IST 2010
[INFO] Final Memory: 12M/29M
please help me to sort out this.
[Updated on: Fri, 19 November 2010 12:15] Report message to a moderator
FUDForum. Page generated in 0.02278 seconds
