Home » Archived » BIRT » Error: <unused> is not recognized! by using version 2.6.1(Error: <unused> is not recognized! by using version 2.6.1)
Re: Error: <unused> is not recognized! by using version 2.6.1 [message #639997 is a reply to message #639990] |
Thu, 18 November 2010 15:56 |
Does the report run? Do you get the error on all reports or just the one?
Jason
On 11/18/2010 10:46 AM, Peng wrote:
> by runing birt report with version 2.6.1 i got following message during
> methode "validateParameters()" of "IRunAndRenderTask":
> line 1 column 1 - Error: <unused> is not recognized!
> This document has errors that must be fixed before
> using HTML Tidy to generate a tidied up version.
> i have checkt the reporting parameters, all of these were set correctly
> before start reporting generation. I am not sure where the said <unused>
> tag was generated. In the design xml there is no such tag at all.
> Does anyone has idea how it does happen?
> regards
Re: Error: <unused> is not recognized! by using version 2.6.1 [message #640012 is a reply to message #640006] |
Thu, 18 November 2010 16:28 |
Can you set the log level to FINEST and post the log?
Jason
On 11/18/2010 11:20 AM, Peng wrote:
> Hi Jason,
> the report runs. the wished pdf was correct generated.
> I get this type of error on all reports.
> BTW: i just find out that this error has nothing to do with
> validetaParameters() methode. By comment this methode i still get the
> same error message.
> Thanks for your help.
> regards
Re: Error: <unused> is not recognized! by using version 2.6.1 [message #640125 is a reply to message #640012] |
Fri, 19 November 2010 09:08 |
Peng Messages: 14 Registered: February 2010 |
Hi Jason,
by setting the log level to FINEST i got the following log-content from the file "ReportEngine_2010_11_19_09_47_20.log" (i still can not any <unused> within it):
19.11.2010 09:47:20 org.eclipse.birt.report.engine.api.impl.ReportEngine <init>
FEIN: ReportEngine created. EngineConfig: EngineConfig: org.eclipse.birt.report.engine.api.EngineConfig.scriptObject s={};BIRT_HOME=;logLevel=FINEST;PLATFORM_CONTEXT=org.eclipse.birt.core.framework.PlatformServletContext@3fd1869;resourceLocator=com.xxx.xxx.reporting.rptconfig.RPTResourceLocator@3fd1879 ;org.eclipse.birt.report.engine.api.EngineConfig.emitterConf igs={html=org.eclipse.birt.report.engine.api.HTMLEmitterConfig@3fd1995};logDest=logs;
19.11.2010 09:47:20 org.eclipse.birt.report.engine.extension.internal.ExtensionM anager getExtensions
FEIN: Start load extension point: org.eclipse.birt.report.engine.reportitemGeneration
19.11.2010 09:47:20 org.eclipse.birt.report.engine.extension.internal.ExtensionM anager loadGenerationExtensionDefns
FEIN: Load generation extension: Chart
FEIN: Start load extension point: org.eclipse.birt.report.engine.reportitemPresentation
19.11.2010 09:47:20 org.eclipse.birt.report.engine.extension.internal.ExtensionM anager loadPresentationExtensionDefns
FEIN: Load prsentation extension: Chart
FEIN: Start load extension point: org.eclipse.birt.report.engine.reportitemQuery
19.11.2010 09:47:20 org.eclipse.birt.report.engine.extension.internal.ExtensionM anager loadQueryExtensionDefns
FEIN: Load query extension: Chart
FEIN: Start load extension point: org.eclipse.birt.report.engine.emitters
19.11.2010 09:47:20 org.eclipse.birt.report.engine.extension.internal.ExtensionM anager loadEmitterExtensionDefns
FEIN: Load xml emitter com.xxx.xxx.reporting.birt.emitter.xml
FEIN: Load html emitter org.eclipse.birt.report.engine.emitter.html
FEIN: Load pdf emitter org.eclipse.birt.report.engine.emitter.pdf
FEIN: Load postscript emitter org.eclipse.birt.report.engine.emitter.postscript
FEIN: Load ppt emitter org.eclipse.birt.report.engine.emitter.ppt
FEIN: Load xls emitter org.eclipse.birt.report.engine.emitter.prototype.excel
FEIN: Load doc emitter org.eclipse.birt.report.engine.emitter.word
FEIN: Start load extension point: org.eclipse.birt.report.engine.reportEventHandler
FEIN: Start load extension point: org.eclipse.birt.report.engine.reportItemPreparation
FEIN: Start load extension point: org.eclipse.birt.report.engine.dataExtraction
19.11.2010 09:47:20 org.eclipse.birt.report.engine.extension.internal.ExtensionM anager loadDataExtractionExtensions
FEIN: Load data extraction extension: org.eclipse.birt.report.engine.dataextraction.csv
FEIN: Start load extension point: org.eclipse.birt.report.engine.extendedItemFactory
19.11.2010 09:47:20 org.eclipse.birt.report.engine.extension.internal.ExtensionM anager loadExtendedItems
FEIN: Load extendedItem extension: Crosstab
FEIN: Load extendedItem extension: CrosstabCell
FEIN: Load extendedItem extension: AggregationCell
19.11.2010 09:53:21 org.eclipse.birt.report.engine.api.impl.ReportEngine openReportDesign
FEIN: ReportEngine.openReportDesign: designStream=weblogic.utils.zip.SafeZipFileInputStream@2293c5f
19.11.2010 09:53:23 org.eclipse.birt.report.engine.api.impl.ReportEngine createRunAndRenderTask
FEIN: ReportEngine.createRunAndRenderTask: reportRunnable=org.eclipse.birt.report.engine.api.impl.ReportRunnable@20c93ce
19.11.2010 09:53:23 org.eclipse.birt.report.engine.api.impl.EngineTask setAppContext
FEIN: EngineTask.setAppContext: context=Report_Engine=org.eclipse.birt.report.engine.api.ReportEngine@3fd1ad2;Report_Design=org.eclipse.birt.report.engine.api.impl.ReportRunnable@20c93ce ;servletResponse=null;reportTask=null;Report_Design_File=DSR eport;servletRequest=null;Birt_Report_Parameters={ID=9005059 13 / 1, USER=Li, Peng 101};Report_Data_Holder=com.xxx.xxx.reporting.dataholders.ds.DSDataHolder@24abddc;reportEngine=org.eclipse.birt.report.engine.api.ReportEngine@3fd1ad2;PARENT_CLASSLOADER=weblogic.utils.classloaders.ChangeAwareClassLoader@3e0e050 finder: weblogic.utils.classloaders.CodeGenClassFinder@3990622 annotation: cdx@cdx;reportDesign=org.eclipse.birt.report.engine.api.impl.ReportRunnable@20c93ce;Report_Request={Report_View_ID=-1, Report_UserSession=com.xxx.xxx.model.security.UserSession@2ad3132, Report_Module=[BaseRemoteObject] home: weblogic.ejb.container.internal.StatefulEJBHomeImpl@2df8ebc, Report_Session=weblogic.servlet.internal.session.MemorySessionData@328b389, Report_Datasheet=[BaseRemoteObject] home: weblogic.ejb.container.internal.StatefulEJBHomeImpl@2d9dc43, Report_Client=CDX_Web, Report_Type=1, Report_NODE_ID=900505913, Report_Creator=Li, Peng 101, Report_Language=de, Report_Format=pdf};Report_Locale=de;Report_Process_Config=or g.apache.commons.configuration.HierarchicalConfiguration$1@2260f41 ;Report_Render_Config=org.apache.commons.configuration.Hiera rchicalConfiguration$1@2a11500;
19.11.2010 09:53:23 org.eclipse.birt.report.engine.api.impl.EngineTask setParameterValue
FEIN: EngineTask.setParameterValue: ID=900505913 / 1 [java.lang.String]
FEIN: EngineTask.setParameterValue: USER=Li, Peng 101 [java.lang.String]
19.11.2010 09:53:23 org.eclipse.birt.report.engine.api.impl.EngineTask loggerParamters
FEIN: Running the report with paramters: ID:900505913 / 1
USER:Li, Peng 101
19.11.2010 09:53:23 org.eclipse.birt.report.engine.api.impl.EngineTask setLocale
FEIN: EngineTask.setLocale: locale=Deutsch
USER:Li, Peng 101
19.11.2010 09:53:24 org.eclipse.birt.data.engine.api.DataEngineContext DataEngineContext
FEINER: ENTRY 3 [object Object] null null org.eclipse.birt.report.engine.executor.ApplicationClassLoad er @383378f
FEINER: RETURN
19.11.2010 09:53:24 org.eclipse.birt.data.engine.impl.DataEngineImpl DataEngineImpl
FEINER: ENTRY org.eclipse.birt.data.engine.api.DataEngineContext@24b07c3
19.11.2010 09:53:24 org.eclipse.birt.data.engine.impl.DataEngineSession DataEngineSession
FEINER: ENTRY org.eclipse.birt.data.engine.impl.DataEngineImpl@248fa53
FEINER: RETURN
FEINER: RETURN
19.11.2010 09:53:24 org.eclipse.birt.data.engine.impl.DataEngineImpl <init>
FEIN: Data Engine starts up
19.11.2010 09:53:24 org.eclipse.birt.data.engine.impl.DataEngineImpl defineDataSource
FEINER: ENTRY CDXItemReportDataSource
FEIN: DataEngine.defineDataSource: org.eclipse.birt.report.data.adapter.internal.adapter.Script DataSourceAdapter @25e020b
19.11.2010 09:53:24 org.eclipse.birt.data.engine.impl.DataSourceRuntime DataSourceRuntime
FEINER: ENTRY org.eclipse.birt.report.data.adapter.internal.adapter.Script DataSourceAdapter @25e020b [object Object]
FEINER: RETURN
19.11.2010 09:53:24 org.eclipse.birt.data.engine.impl.ScriptDataSourceRuntime ScriptDataSourceRuntime
FEINER: RETURN
19.11.2010 09:53:24 org.eclipse.birt.data.engine.impl.ScriptDataSourceRuntime <init>
FEINER: ScriptDataSourceRuntime starts up
FEINER: RETURN
19.11.2010 09:53:24 org.eclipse.birt.report.data.adapter.impl.ModelAdapter adaptDataSet
FEIN: handle type: org.eclipse.birt.report.model.api.ScriptDataSetHandle
19.11.2010 09:53:24 org.eclipse.birt.data.engine.impl.DataEngineImpl defineDataSet
FEINER: ENTRY CDXItemReportSupplierDataSet
FEIN: DataEngine.defineDataSet: org.eclipse.birt.report.data.adapter.internal.adapter.Script DataSetAdapter @26de37a
FEINER: RETURN
FEIN: DataEngine.defineDataSource: org.eclipse.birt.report.data.adapter.internal.adapter.Script DataSourceAdapter @26d4568
FEINER: ENTRY org.eclipse.birt.report.data.adapter.internal.adapter.Script DataSourceAdapter @26d4568 [object Object]
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY CDXItemReportProductDataSet
FEIN: DataEngine.defineDataSet: org.eclipse.birt.report.data.adapter.internal.adapter.Script DataSetAdapter @26d80f2
FEINER: RETURN
FEIN: DataEngine.defineDataSource: org.eclipse.birt.report.data.adapter.internal.adapter.Script DataSourceAdapter @26e11f7
FEINER: ENTRY org.eclipse.birt.report.data.adapter.internal.adapter.Script DataSourceAdapter @26e11f7 [object Object]
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY DSDetailDataSet
FEIN: DataEngine.defineDataSet: org.eclipse.birt.report.data.adapter.internal.adapter.Script DataSetAdapter @26e3bf6
FEINER: RETURN
19.11.2010 09:53:24 org.eclipse.birt.data.engine.impl.DataEngineImpl prepare
FEINER: ENTRY QueryDefinition(DataSetName : null
ResultSetExpressions : {CREATION_DATE=org.eclipse.birt.data.engine.api.querydefn.Binding@2ea6b50e}
Subqueries : org.eclipse.birt.data.engine.api.querydefn.SubqueryDefinitio n @25daea1,
org.eclipse.birt.data.engine.api.querydefn.SubqueryDefinitio n @25e6914
MaxRows : 0
FEIN: Start to prepare query: QueryDefinition(DataSetName : null
MaxRows : 0
19.11.2010 09:53:24 org.eclipse.birt.data.engine.impl.PreparedDummyQuery PreparedDummyQuery
FEINER: ENTRY org.eclipse.birt.data.engine.api.querydefn.QueryDefinition@257676d org.eclipse.birt.data.engine.impl.DataEngineSession@249f703
19.11.2010 09:53:24 org.eclipse.birt.data.engine.impl.GroupBindingColumn GroupBindingColumn
FEINER: ENTRY null 0 {CREATION_DATE=org.eclipse.birt.data.engine.api.querydefn.Binding@2ea6b50e}
FEINER: RETURN
FEINER: RETURN
FEIN: Finished preparing query.
FEINER: RETURN
Subqueries : org.eclipse.birt.data.engine.api.querydefn.SubqueryDefinitio n @25e70c5,
org.eclipse.birt.data.engine.api.querydefn.SubqueryDefinitio n @25e794d
MaxRows : 0
MaxRows : 0
FEINER: ENTRY org.eclipse.birt.data.engine.api.querydefn.QueryDefinition@25e6dba org.eclipse.birt.data.engine.impl.DataEngineSession@249f703
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY QueryDefinition(DataSetName : CDXItemReportSupplierDataSet
ResultSetExpressions : {COMPANY=org.eclipse.birt.data.engine.api.querydefn.Binding@6372c85d, DUNS_NUMBER=org.eclipse.birt.data.engine.api.querydefn.Binding@af593592, STREET=org.eclipse.birt.data.engine.api.querydefn.Binding@92684403, LOCATION=org.eclipse.birt.data.engine.api.querydefn.Binding@9ff58fb5, SUPPLIER_NUMBER=org.eclipse.birt.data.engine.api.querydefn.Binding@5601851c, CONTACT_PERSON=org.eclipse.birt.data.engine.api.querydefn.Binding@2fddc74, CONTACT_TEL=org.eclipse.birt.data.engine.api.querydefn.Binding@82d7233c, CONTACT_FAX=org.eclipse.birt.data.engine.api.querydefn.Binding@82d6ee3e, CONTACT_MAIL=org.eclipse.birt.data.engine.api.querydefn.Binding@d80a0696}
MaxRows : 0
FEIN: Start to prepare query: QueryDefinition(DataSetName : CDXItemReportSupplierDataSet
MaxRows : 0
19.11.2010 09:53:24 org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery PreparedDataSourceQuery
FEINER: ENTRY org.eclipse.birt.data.engine.impl.DataEngineImpl@248fa53 org.eclipse.birt.data.engine.api.querydefn.QueryDefinition@25e7f48 org.eclipse.birt.data.engine.impl.ScriptDataSetAdapter@25798d4 {Report_Engine=org.eclipse.birt.report.engine.api.ReportEngine@3fd1ad2, Report_Design=org.eclipse.birt.report.engine.api.impl.ReportRunnable@20c93ce, servletResponse=null, Report_Design_File=DSReport, reportTask=null, servletRequest=null, Birt_Report_Parameters={ID=900505913 / 1, USER=Li, Peng 101}, org.eclipse.datatools.connectivity.oda.util_consumerResource Ids= org.eclipse.datatools.connectivity.oda.util.ResourceIdentifi ers @2692a74, reportEngine=org.eclipse.birt.report.engine.api.ReportEngine@3fd1ad2, Report_Data_Holder=com.xxx.xxx.reporting.dataholders.ds.DSDataHolder@24abddc, PARENT_CLASSLOADER=weblogic.utils.classloaders.ChangeAwareClassLoader@3e0e050 finder: weblogic.utils.classloaders.CodeGenClassFinder@3990622 annotation: cdx@cdx, Report_Request={Report_View_ID=-1, Report_UserSession=com.xxx.xxx.model.security.UserSession@2ad3132, Report_Module=[BaseRemoteObject] home: weblogic.ejb.container.internal.StatefulEJBHomeImpl@2df8ebc, Report_Session=weblogic.servlet.internal.session.MemorySessionData@328b389, Report_Datasheet=[BaseRemoteObject] home: weblogic.ejb.container.internal.StatefulEJBHomeImpl@2d9dc43, Report_Client=CDX_Web, Report_Type=1, Report_NODE_ID=900505913, Report_Creator=Li, Peng 101, Report_Language=de, Report_Format=pdf}, reportDesign=org.eclipse.birt.report.engine.api.impl.ReportRunnable@20c93ce, Report_Locale=de, PDF_RENDER_CONTEXT=org.eclipse.birt.report.engine.api.PDFRenderContext@383385a, Report_Render_Config=org.apache.commons.configuration.Hierar chicalConfiguration$1@2a11500, Report_Process_Config=org.apache.commons.configuration.Hiera rchicalConfiguration$1@2260f41}
19.11.2010 09:53:24 org.eclipse.birt.data.engine.impl.PreparedQuery PreparedQuery
FEIN: PreparedQuery starts up.
19.11.2010 09:53:24 org.eclipse.birt.data.engine.impl.aggregation.AggregateTable AggregateTable
FEINER: ENTRY
FEINER: RETURN
FEINER: ENTRY C:\Users\li2\AppData\Local\Temp\DataEngine_38337107_1\ [object Object] []
FEINER: RETURN
19.11.2010 09:53:24 org.eclipse.birt.data.engine.impl.PreparedQuery <init>
FEIN: Start to prepare a PreparedQuery.
19.11.2010 09:53:24 org.eclipse.birt.data.engine.impl.aggregation.AggrRegistry AggrRegistry
FEINER: ENTRY 0 -1 true org.eclipse.birt.core.script.ScriptContext@38341e2
FEINER: RETURN
19.11.2010 09:53:24 org.eclipse.birt.data.engine.expression.ColumnReferenceExpre ssion ColumnReferenceExpression
FEINER: ENTRY COMPANY
FEINER: RETURN
FEINER: ENTRY DUNS_NUMBER
FEINER: RETURN
FEINER: ENTRY STREET
FEINER: RETURN
FEINER: ENTRY LOCATION
FEINER: RETURN
FEINER: ENTRY SUPPLIER_NUMBER
FEINER: RETURN
FEINER: ENTRY CONTACT_PERSON
FEINER: RETURN
FEINER: ENTRY CONTACT_TEL
FEINER: RETURN
FEINER: ENTRY CONTACT_FAX
FEINER: RETURN
FEINER: ENTRY CONTACT_MAIL
FEINER: RETURN
FEINER: ENTRY null 0 {COMPANY=org.eclipse.birt.data.engine.api.querydefn.Binding@6372c85d, LOCATION=org.eclipse.birt.data.engine.api.querydefn.Binding@9ff58fb5, SUPPLIER_NUMBER=org.eclipse.birt.data.engine.api.querydefn.Binding@5601851c, CONTACT_TEL=org.eclipse.birt.data.engine.api.querydefn.Binding@82d7233c, CONTACT_PERSON=org.eclipse.birt.data.engine.api.querydefn.Binding@2fddc74, CONTACT_MAIL=org.eclipse.birt.data.engine.api.querydefn.Binding@d80a0696, CONTACT_FAX=org.eclipse.birt.data.engine.api.querydefn.Binding@82d6ee3e, STREET=org.eclipse.birt.data.engine.api.querydefn.Binding@92684403, DUNS_NUMBER=org.eclipse.birt.data.engine.api.querydefn.Binding@af593592}
FEINER: RETURN
FEIN: Finished preparing the PreparedQuery.
FEINER: RETURN
19.11.2010 09:53:24 org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery PreparedScriptDSQuery
19.11.2010 09:53:24 org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery PreparedScriptDSQueryss
FEINER: RETURN
FEINER: PreparedScriptDSQuery starts up.
FEINER: RETURN
FEINER: ENTRY QueryDefinition(DataSetName : CDXItemReportProductDataSet
ResultSetExpressions : {PART_NUMBER=org.eclipse.birt.data.engine.api.querydefn.Binding@4d47a915, PART_NAME=org.eclipse.birt.data.engine.api.querydefn.Binding@3c044f57, SAMPLEREPORT_NUMBER=org.eclipse.birt.data.engine.api.querydefn.Binding@8059b4a, SAMPLEREPORT_DATE=org.eclipse.birt.data.engine.api.querydefn.Binding@5e8ebfef, ORDER_NUMBER=org.eclipse.birt.data.engine.api.querydefn.Binding@5c836d7a, DELIVERY_NUMBER=org.eclipse.birt.data.engine.api.querydefn.Binding@62cd25f4, ID_VERSION=org.eclipse.birt.data.engine.api.querydefn.Binding@d76f0d94, NODE_ID=org.eclipse.birt.data.engine.api.querydefn.Binding@a8d3f078, DS_STATE=org.eclipse.birt.data.engine.api.querydefn.Binding@654a50c1, CHANGE_DATE=org.eclipse.birt.data.engine.api.querydefn.Binding@1f71e6dd, STATE_DATE=org.eclipse.birt.data.engine.api.querydefn.Binding@1114f2bc}
MaxRows : 0
FEIN: Start to prepare query: QueryDefinition(DataSetName : CDXItemReportProductDataSet
MaxRows : 0
FEINER: ENTRY org.eclipse.birt.data.engine.impl.DataEngineImpl@248fa53 org.eclipse.birt.data.engine.api.querydefn.QueryDefinition@25ee370 org.eclipse.birt.data.engine.impl.ScriptDataSetAdapter@259457f {Report_Engine=org.eclipse.birt.report.engine.api.ReportEngine@3fd1ad2, Report_Design=org.eclipse.birt.report.engine.api.impl.ReportRunnable@20c93ce, servletResponse=null, Report_Design_File=DSReport, reportTask=null, servletRequest=null, Birt_Report_Parameters={ID=900505913 / 1, USER=Li, Peng 101}, org.eclipse.datatools.connectivity.oda.util_consumerResource Ids= org.eclipse.datatools.connectivity.oda.util.ResourceIdentifi ers @2692a74, reportEngine=org.eclipse.birt.report.engine.api.ReportEngine@3fd1ad2, Report_Data_Holder=com.xxx.xxx.reporting.dataholders.ds.DSDataHolder@24abddc, PARENT_CLASSLOADER=weblogic.utils.classloaders.ChangeAwareClassLoader@3e0e050 finder: weblogic.utils.classloaders.CodeGenClassFinder@3990622 annotation: cdx@cdx, Report_Request={Report_View_ID=-1, Report_UserSession=com.xxx.xxx.model.security.UserSession@2ad3132, Report_Module=[BaseRemoteObject] home: weblogic.ejb.container.internal.StatefulEJBHomeImpl@2df8ebc, Report_Session=weblogic.servlet.internal.session.MemorySessionData@328b389, Report_Datasheet=[BaseRemoteObject] home: weblogic.ejb.container.internal.StatefulEJBHomeImpl@2d9dc43, Report_Client=CDX_Web, Report_Type=1, Report_NODE_ID=900505913, Report_Creator=Li, Peng 101, Report_Language=de, Report_Format=pdf}, reportDesign=org.eclipse.birt.report.engine.api.impl.ReportRunnable@20c93ce, Report_Locale=de, PDF_RENDER_CONTEXT=org.eclipse.birt.report.engine.api.PDFRenderContext@383385a, Report_Render_Config=org.apache.commons.configuration.Hierar chicalConfiguration$1@2a11500, Report_Process_Config=org.apache.commons.configuration.Hiera rchicalConfiguration$1@2260f41}
FEINER: ENTRY
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY PART_NUMBER
FEINER: RETURN
FEINER: ENTRY PART_NAME
FEINER: RETURN
FEINER: ENTRY SAMPLEREPORT_NUMBER
FEINER: RETURN
FEINER: ENTRY SAMPLEREPORT_DATE
FEINER: RETURN
FEINER: ENTRY ORDER_NUMBER
FEINER: RETURN
FEINER: ENTRY DELIVERY_NUMBER
FEINER: RETURN
FEINER: ENTRY ID
FEINER: RETURN
FEINER: ENTRY NODE_ID
FEINER: RETURN
FEINER: ENTRY DS_STATE
FEINER: RETURN
FEINER: ENTRY CHANGE_DATE
FEINER: RETURN
19.11.2010 09:53:24 org.eclipse.birt.data.engine.expression.ComplexExpression ComplexExpression
FEINER: ENTRY
FEINER: RETURN
FEINER: ENTRY
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY null 0 {PART_NUMBER=org.eclipse.birt.data.engine.api.querydefn.Binding@4d47a915, DELIVERY_NUMBER=org.eclipse.birt.data.engine.api.querydefn.Binding@62cd25f4, CHANGE_DATE=org.eclipse.birt.data.engine.api.querydefn.Binding@1f71e6dd, DS_STATE=org.eclipse.birt.data.engine.api.querydefn.Binding@654a50c1, SAMPLEREPORT_DATE=org.eclipse.birt.data.engine.api.querydefn.Binding@5e8ebfef, PART_NAME=org.eclipse.birt.data.engine.api.querydefn.Binding@3c044f57, STATE_DATE=org.eclipse.birt.data.engine.api.querydefn.Binding@1114f2bc, NODE_ID=org.eclipse.birt.data.engine.api.querydefn.Binding@a8d3f078, ORDER_NUMBER=org.eclipse.birt.data.engine.api.querydefn.Binding@5c836d7a, SAMPLEREPORT_NUMBER=org.eclipse.birt.data.engine.api.querydefn.Binding@8059b4a, ID_VERSION=org.eclipse.birt.data.engine.api.querydefn.Binding@d76f0d94}
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
ResultSetExpressions : {PART_NUMBER=org.eclipse.birt.data.engine.api.querydefn.Binding@4d47a915, PART_NAME=org.eclipse.birt.data.engine.api.querydefn.Binding@3c044f57, SAMPLEREPORT_NUMBER=org.eclipse.birt.data.engine.api.querydefn.Binding@8059b4a, ID_VERSION=org.eclipse.birt.data.engine.api.querydefn.Binding@d76f0d94, NODE_ID=org.eclipse.birt.data.engine.api.querydefn.Binding@a8d3f078}
MaxRows : 0
MaxRows : 0
FEINER: ENTRY org.eclipse.birt.data.engine.impl.DataEngineImpl@248fa53 org.eclipse.birt.data.engine.api.querydefn.QueryDefinition@25f0908 org.eclipse.birt.data.engine.impl.ScriptDataSetAdapter@25287d8 {Report_Engine=org.eclipse.birt.report.engine.api.ReportEngine@3fd1ad2, Report_Design=org.eclipse.birt.report.engine.api.impl.ReportRunnable@20c93ce, servletResponse=null, Report_Design_File=DSReport, reportTask=null, servletRequest=null, Birt_Report_Parameters={ID=900505913 / 1, USER=Li, Peng 101}, org.eclipse.datatools.con
Re: Error: <unused> is not recognized! by using version 2.6.1 [message #640127 is a reply to message #639990] |
Fri, 19 November 2010 09:16 |
because of the log file size, here is the part 2 of the log content:
FEINER: ENTRY
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY ID_VERSION
FEINER: RETURN
FEINER: ENTRY QUANTITY
FEINER: RETURN
FEINER: ENTRY MASS
FEINER: RETURN
FEINER: ENTRY PORTION
FEINER: RETURN
FEINER: ENTRY PORTION_INTERVAL
FEINER: RETURN
FEINER: ENTRY CLASS_NAME
FEINER: RETURN
FEINER: ENTRY APPLICATION_NAME_ID
FEINER: RETURN
FEINER: ENTRY PART_NAME_IMAGE
FEINER: RETURN
FEINER: ENTRY PART_NUMBER_IMAGE
FEINER: RETURN
FEINER: ENTRY CLASS_IMAGE
FEINER: RETURN
FEINER: ENTRY APPLICATION_IMAGE
FEINER: RETURN
FEINER: ENTRY LEVEL
FEINER: RETURN
FEINER: ENTRY null 0 {PORTION=org.eclipse.birt.data.engine.api.querydefn.Binding@136c2fc7, CLASS_NAME=org.eclipse.birt.data.engine.api.querydefn.Binding@d5c9112, PART_NAME_IMAGE=org.eclipse.birt.data.engine.api.querydefn.Binding@d5d04653, APPLICATION_IMAGE=org.eclipse.birt.data.engine.api.querydefn.Binding@3291096c, PART_NAME=org.eclipse.birt.data.engine.api.querydefn.Binding@3c044f57, LEVEL=org.eclipse.birt.data.engine.api.querydefn.Binding@44fa364, PART_NUMBER=org.eclipse.birt.data.engine.api.querydefn.Binding@4d47a915, APPLICATION_NAME_ID=org.eclipse.birt.data.engine.api.querydefn.Binding@c721fb40, CLASS_IMAGE=org.eclipse.birt.data.engine.api.querydefn.Binding@9df46394, PORTION_INTERVAL=org.eclipse.birt.data.engine.api.querydefn.Binding@bcfaa63d, MASS=org.eclipse.birt.data.engine.api.querydefn.Binding@23fef4, QUANTITY=org.eclipse.birt.data.engine.api.querydefn.Binding@e20e548b, ID_VERSION=org.eclipse.birt.data.engine.api.querydefn.Binding@d76f0d94, PART_NUMBER_IMAGE=org.eclipse.birt.data.engine.api.querydefn.Binding@f64cd991}
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.impl.DataEngineImpl@248fa53 org.eclipse.birt.data.engine.api.querydefn.QueryDefinition@25f1e04 org.eclipse.birt.data.engine.impl.ScriptDataSetAdapter@253d837 {Report_Engine=org.eclipse.birt.report.engine.api.ReportEngine@3fd1ad2, Report_Design=org.eclipse.birt.report.engine.api.impl.ReportRunnable@20c93ce, servletResponse=null, Report_Design_File=DSReport, reportTask=null, servletRequest=null, Birt_Report_Parameters={ID=900505913 / 1, USER=Li, Peng 101}, org.eclipse.datatools.connectivity.oda.util_consumerResource Ids= org.eclipse.datatools.connectivity.oda.util.ResourceIdentifi ers @2692a74, reportEngine=org.eclipse.birt.report.engine.api.ReportEngine@3fd1ad2, Report_Data_Holder=com.xxx.xxx.reporting.dataholders.ds.DSDataHolder@24abddc, PARENT_CLASSLOADER=weblogic.utils.classloaders.ChangeAwareClassLoader@3e0e050 finder: weblogic.utils.classloaders.CodeGenClassFinder@3990622 annotation: cdx@cdx, Report_Request={Report_View_ID=-1, Report_UserSession=com.xxx.xxx.model.security.UserSession@2ad3132, Report_Module=[BaseRemoteObject] home: weblogic.ejb.container.internal.StatefulEJBHomeImpl@2df8ebc, Report_Session=weblogic.servlet.internal.session.MemorySessionData@328b389, Report_Datasheet=[BaseRemoteObject] home: weblogic.ejb.container.internal.StatefulEJBHomeImpl@2d9dc43, Report_Client=CDX_Web, Report_Type=1, Report_NODE_ID=900505913, Report_Creator=Li, Peng 101, Report_Language=de, Report_Format=pdf}, reportDesign=org.eclipse.birt.report.engine.api.impl.ReportRunnable@20c93ce, Report_Locale=de, PDF_RENDER_CONTEXT=org.eclipse.birt.report.engine.api.PDFRenderContext@383385a, Report_Render_Config=org.apache.commons.configuration.Hierar chicalConfiguration$1@2a11500, Report_Process_Config=org.apache.commons.configuration.Hiera rchicalConfiguration$1@2260f41}
FEINER: RETURN
FEINER: RETURN
19.11.2010 09:53:25 org.eclipse.birt.data.engine.impl.ExprManagerUtil ExprManagerUtil
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ExprManager@264e794
FEINER: RETURN
19.11.2010 09:53:25 org.eclipse.birt.data.engine.script.ScriptEvalUtil evaluateJSExpr
FEINER: ENTRY evaluateJSExpr() scriptText=new Date(), source=null, lineNo=0
19.11.2010 09:53:25 org.eclipse.birt.data.engine.impl.PreparedDummyQuery PreparedDummyQuery
FEINER: ENTRY org.eclipse.birt.data.engine.api.querydefn.SubqueryDefinitio n @25daea1 org.eclipse.birt.data.engine.impl.DataEngineSession@249f703
19.11.2010 09:53:25 org.eclipse.birt.data.engine.impl.GroupBindingColumn GroupBindingColumn
FEINER: ENTRY null 0 {ID=org.eclipse.birt.data.engine.api.querydefn.Binding@91b, CREATION_DATE=org.eclipse.birt.data.engine.api.querydefn.Binding@2ea6b50e}
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ExprManager@26f3fe1
FEINER: RETURN
FEINER: ENTRY evaluateJSExpr() scriptText=params["ID"], source=null, lineNo=0
FEINER: ENTRY org.eclipse.birt.data.engine.api.querydefn.SubqueryDefinitio n @25e6914 org.eclipse.birt.data.engine.impl.DataEngineSession@249f703
FEINER: ENTRY null 0 {USER=org.eclipse.birt.data.engine.api.querydefn.Binding@27e3cb, CREATION_DATE=org.eclipse.birt.data.engine.api.querydefn.Binding@2ea6b50e}
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ExprManager@271ccc1
FEINER: RETURN
FEINER: ENTRY evaluateJSExpr() scriptText=params["USER"], source=null, lineNo=0
19.11.2010 09:53:26 org.eclipse.birt.report.engine.layout.pdf.font.FontMappingMa nagerFactory loadFontMappingConfig
INFO: load font config in bundleentry://59.fwk36689683/fontsConfig.xml cost 99ms
19.11.2010 09:53:26 org.eclipse.birt.report.engine.layout.pdf.font.FontMappingMa nagerFactory$2 run
INFO: register fonts in /usr/openwin/lib/locale/ja/X11/fonts/TT cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/iso_8859_13/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/ru.ansi-1251/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/iso_8859_15/X11/fonts/TrueType cost:0ms
INFO: register fonts in d:/windows/fonts cost:3ms
19.11.2010 09:53:42 org.eclipse.birt.report.engine.layout.pdf.font.FontMappingMa nagerFactory$2 run
INFO: register fonts in C:/windows/fonts cost:16653ms
INFO: register fonts in /usr/X11R6/lib/X11/fonts/truetype cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/ar/X11/fonts/TrueType cost:0ms
INFO: register fonts in e:/WINNT/fonts cost:0ms
INFO: register fonts in /var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType cost:0ms
INFO: register fonts in C:/WINNT/fonts cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/iso_8859_2/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/X11R6/lib/X11/fonts/tt cost:1ms
INFO: register fonts in /usr/openwin/lib/locale/th_TH/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/iso_8859_8/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/iso_8859_7/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/X11R6/lib/X11/fonts/TTF cost:0ms
INFO: register fonts in /usr/openwin/lib/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/share/fonts/truetype cost:0ms
INFO: register fonts in f:/WINNT/fonts cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/ko.UTF-8/X11/fonts/TrueType cost:0ms
INFO: register fonts in g:/WINNT/fonts cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/iso_8859_5/X11/fonts/TrueType cost:0ms
INFO: register fonts in f:/windows/fonts cost:0ms
INFO: register fonts in d:/WINNT/fonts cost:3ms
INFO: register fonts in /usr/share/fonts/ko/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/zh_TW/X11/fonts/TrueType cost:0ms
INFO: register fonts in e:/windows/fonts cost:0ms
INFO: register fonts in /usr/share/fonts/zh_TW/TrueType cost:0ms
INFO: register fonts in /usr/share/fonts/ja/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/zh_CN.GB18030/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/share/fonts/default/TrueType cost:0ms
INFO: register fonts in /usr/X/lib/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/euro_fonts/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/hi_IN.UTF-8/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/zh.GBK/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/X11R6/lib/X11/fonts/OTF cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/iso_8859_9/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/X11R6/lib/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/zh_TW.BIG5/X11/fonts/TT cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/ko/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/zh_HK.BIG5HK/X11/fonts/TT cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/KOI8-R/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/zh/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/share/fonts/zh_CN/TrueType cost:0ms
INFO: register fonts in g:/windows/fonts cost:0ms
19.11.2010 09:53:42 org.eclipse.birt.report.engine.layout.pdf.font.FontMappingMa nagerFactory loadFontMappingConfig
INFO: load font config in bundleentry://59.fwk36689683/fontsConfig_win32.xml cost 6ms
INFO: load font config in bundleentry://59.fwk36689683/fontsConfig_pdf.xml cost 3ms
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.DataSetRuntime DataSetRuntime
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ScriptDataSetAdapter@25798d4 null
FEINER: RETURN
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime ScriptDataSetRuntime
FEINER: RETURN
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime <init>
FEINER: ScriptDataSetRuntime starts up
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.ParameterUtil ParameterUtil
FEINER: ENTRY null org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime@255580e org.eclipse.birt.data.engine.api.querydefn.QueryDefinition@25e7f48 [object Object]
FEINER: RETURN
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.QueryExecutor QueryExecutor
FEINER: ENTRY [object Object] org.eclipse.birt.data.engine.api.querydefn.QueryDefinition@25e7f48 org.eclipse.birt.data.engine.impl.aggregation.AggregateTable @30bb4b8 org.eclipse.birt.data.engine.impl.DataEngineSession@249f703
FEINER: RETURN
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.PreparedQuery doPrepare
FEINER: Start to prepare the execution.
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ScriptDataSetAdapter@25798d4 org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$ScriptDSQueryExecutor@255ae5e
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY null org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime@256027b org.eclipse.birt.data.engine.api.querydefn.QueryDefinition@25e7f48 [object Object]
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: Finish preparing the execution.
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.ServiceForQueryResults ServiceForQueryResults
FEINER: ENTRY org.eclipse.birt.data.engine.impl.DataEngineSession@249f703 [object Object] 2 org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery@30bb0d3 org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery@30bb0d3 org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$ScriptDSQueryExecutor@255ae5e org.eclipse.birt.data.engine.api.querydefn.QueryDefinition@25e7f48 org.eclipse.birt.data.engine.impl.ExprManager@30bb4c8
FEINER: RETURN
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.QueryResults QueryResults
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ServiceForQueryResults@25832c9
FEINER: RETURN
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.ExprManagerUtil ExprManagerUtil
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ExprManager@30bb4c8
FEINER: RETURN
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.QueryExecutor execute
FEINER: Start to execute
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.ExecutorHelper ExecutorHelper
FEINER: ENTRY null
FEINER: RETURN
19.11.2010 09:53:43 org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper populateData
FEIN: MemoryCache is used
FEIN: Time consumed by cache is: 0 second
19.11.2010 09:53:43 org.eclipse.birt.data.engine.expression.ColumnReferenceExpre ssion ColumnReferenceExpression
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: Finish executing
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.ResultIterator ResultIterator
FEINER: ENTRY org.eclipse.birt.data.engine.impl.QueryResults$ResultService@2498693 org.eclipse.birt.data.engine.executor.transform.CachedResult Set @258cb07 [object Object]
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.BindingColumnsEvalUtil BindingColumnsEvalUtil
FEINER: ENTRY org.eclipse.birt.data.engine.executor.transform.CachedResult Set @258cb07 [object Object] org.eclipse.birt.data.engine.impl.ResultIterator$RDSaveHelper@249a331 [org.eclipse.birt.data.engine.impl.GroupBindingColumn@30bc4c8] {}
FEINER: RETURN
FEINER: RETURN
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.QueryResults getResultIterator
FEIN: finished
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.ResultIterator getValue
FEINER: get of value binding column: COMPANY
FEINER: get of value binding column: DUNS_NUMBER
FEINER: get of value binding column: STREET
FEINER: get of value binding column: LOCATION
FEINER: get of value binding column: SUPPLIER_NUMBER
FEINER: get of value binding column: CONTACT_PERSON
FEINER: get of value binding column: CONTACT_TEL
FEINER: get of value binding column: CONTACT_FAX
FEINER: get of value binding column: CONTACT_MAIL
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.ResultIterator close
FEIN: a ResultIterator is closed
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.QueryExecutor close
FEINER: executor closed
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.QueryResults close
FEIN: QueryResults is closed
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ScriptDataSetAdapter@259457f null
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY null org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime@277269c org.eclipse.birt.data.engine.api.querydefn.QueryDefinition@25ee370 [object Object]
FEINER: RETURN
FEINER: ENTRY [object Object] org.eclipse.birt.data.engine.api.querydefn.QueryDefinition@25ee370 org.eclipse.birt.data.engine.impl.aggregation.AggregateTable @30bb5d7 org.eclipse.birt.data.engine.impl.DataEngineSession@249f703
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ScriptDataSetAdapter@259457f org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$ScriptDSQueryExecutor@2774737
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY null org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime@27766d8 org.eclipse.birt.data.engine.api.querydefn.QueryDefinition@25ee370 [object Object]
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.impl.DataEngineSession@249f703 [object Object] 2 org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery@30bb0fc org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery@30bb0fc org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$ScriptDSQueryExecutor@2774737 org.eclipse.birt.data.engine.api.querydefn.QueryDefinition@25ee370 org.eclipse.birt.data.engine.impl.ExprManager@30bb5e7
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ServiceForQueryResults@2708ee9
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ExprManager@30bb5e7
FEINER: RETURN
FEINER: ENTRY null
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
19.11.2010 09:53:43 org.eclipse.birt.data.engine.expression.ComplexExpression ComplexExpression
FEINER: ENTRY
FEINER: RETURN
FEINER: ENTRY
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY ID
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY
FEINER: RETURN
FEINER: ENTRY
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY ID
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.impl.QueryResults$ResultService@2702177 org.eclipse.birt.data.engine.executor.transform.CachedResult Set @272f694 [object Object]
FEINER: ENTRY org.eclipse.birt.data.engine.executor.transform.CachedResult Set @272f694 [object Object] org.eclipse.birt.data.engine.impl.ResultIterator$RDSaveHelper@270412f [org.eclipse.birt.data.engine.impl.GroupBindingColumn@30bc98e] {}
FEINER: RETURN
19.11.2010 09:53:43 org.eclipse.birt.data.engine.script.JSRowObject JSRowObject
FEINER: ENTRY
19.11.2010 09:53:43 org.eclipse.birt.data.engine.script.JSRowObject get
FEINER: RETURN
FEIN: finished
FEINER: get of value binding column: PART_NUMBER
FEINER: get of value binding column: PART_NAME
FEINER: get of value binding column: SAMPLEREPORT_NUMBER
FEINER: get of value binding column: SAMPLEREPORT_DATE
FEINER: get of value binding column: ORDER_NUMBER
FEINER: get of value binding column: DELIVERY_NUMBER
FEINER: get of value binding column: ID_VERSION
FEINER: get of value binding column: NODE_ID
FEINER: get of value binding column: STATE_DATE
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ExprManager@30bb2f3
FEINER: RETURN
19.11.2010 09:53:43 org.eclipse.birt.data.engine.script.ScriptEvalUtil evaluateJSExpr
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.PreparedDummyQuery PreparedDummyQuery
FEINER: ENTRY org.eclipse.birt.data.engine.api.querydefn.SubqueryDefinitio n @25e70c5 org.eclipse.birt.data.engine.impl.DataEngineSession@249f703
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.GroupBindingColumn GroupBindingColumn
FEINER: RETURN
FEINER: RETURN
Re: Error: <unused> is not recognized! by using version 2.6.1 [message #640128 is a reply to message #639990] |
Fri, 19 November 2010 09:18 |
part3 of log file content:
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ExprManager@27c913e
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.api.querydefn.SubqueryDefinitio n @25e794d org.eclipse.birt.data.engine.impl.DataEngineSession@249f703
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ExprManager@27dde9f
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ScriptDataSetAdapter@25287d8 null
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY null org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime@27811ac org.eclipse.birt.data.engine.api.querydefn.QueryDefinition@25f0908 [object Object]
FEINER: RETURN
FEINER: ENTRY [object Object] org.eclipse.birt.data.engine.api.querydefn.QueryDefinition@25f0908 org.eclipse.birt.data.engine.impl.aggregation.AggregateTable @30bb533 org.eclipse.birt.data.engine.impl.DataEngineSession@249f703
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ScriptDataSetAdapter@25287d8 org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$ScriptDSQueryExecutor@278416f
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY null org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime@27869ac org.eclipse.birt.data.engine.api.querydefn.QueryDefinition@25f0908 [object Object]
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.impl.DataEngineSession@249f703 [object Object] 2 org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery@30bb0e4 org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery@30bb0e4 org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$ScriptDSQueryExecutor@278416f org.eclipse.birt.data.engine.api.querydefn.QueryDefinition@25f0908 org.eclipse.birt.data.engine.impl.ExprManager@30bb543
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ServiceForQueryResults@278fe1a
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ExprManager@30bb543
FEINER: RETURN
FEINER: ENTRY null
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY ID
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY ID
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.impl.QueryResults$ResultService@279b04b org.eclipse.birt.data.engine.executor.transform.CachedResult Set @2793011 [object Object]
FEINER: ENTRY org.eclipse.birt.data.engine.executor.transform.CachedResult Set @2793011 [object Object] org.eclipse.birt.data.engine.impl.ResultIterator$RDSaveHelper@279cb02 [org.eclipse.birt.data.engine.impl.GroupBindingColumn@30bc616] {}
FEINER: RETURN
FEINER: RETURN
FEIN: finished
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ScriptDataSetAdapter@253d837 null
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY null org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime@2853fa0 org.eclipse.birt.data.engine.api.querydefn.QueryDefinition@25f1e04 [object Object]
FEINER: RETURN
FEINER: ENTRY [object Object] org.eclipse.birt.data.engine.api.querydefn.QueryDefinition@25f1e04 org.eclipse.birt.data.engine.impl.aggregation.AggregateTable @30bb55c org.eclipse.birt.data.engine.impl.DataEngineSession@249f703
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ScriptDataSetAdapter@253d837 org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$ScriptDSQueryExecutor@285a3f3
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY null org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime@285d079 org.eclipse.birt.data.engine.api.querydefn.QueryDefinition@25f1e04 [object Object]
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.impl.DataEngineSession@249f703 [object Object] 2 org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery@30bb0eb org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery@30bb0eb org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$ScriptDSQueryExecutor@285a3f3 org.eclipse.birt.data.engine.api.querydefn.QueryDefinition@25f1e04 org.eclipse.birt.data.engine.impl.ExprManager@30bb56c
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ServiceForQueryResults@286d6af
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ExprManager@30bb56c
FEINER: RETURN
FEINER: ENTRY null
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY LEVEL
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY MASS
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY LEVEL
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY MASS
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.impl.QueryResults$ResultService@288d136 org.eclipse.birt.data.engine.executor.transform.CachedResult Set @2878c63 [object Object]
FEINER: ENTRY org.eclipse.birt.data.engine.executor.transform.CachedResult Set @2878c63 [object Object] org.eclipse.birt.data.engine.impl.ResultIterator$RDSaveHelper@2899467 [org.eclipse.birt.data.engine.impl.GroupBindingColumn@30bc63d] {}
FEINER: RETURN
FEINER: RETURN
FEIN: finished
FEINER: get of value binding column: LEVEL
FEINER: get of value binding column: PART_NAME_IMAGE
FEINER: get of value binding column: PART_NUMBER_IMAGE
FEINER: get of value binding column: QUANTITY
FEINER: get of value binding column: MASS
FEINER: get of value binding column: PORTION
FEINER: get of value binding column: PORTION_INTERVAL
FEINER: get of value binding column: CLASS_IMAGE
FEINER: get of value binding column: CLASS_NAME
FEINER: get of value binding column: APPLICATION_IMAGE
FEINER: get of value binding column: APPLICATION_NAME_ID
FEINER: ge
Re: Error: <unused> is not recognized! by using version 2.6.1 [message #640213 is a reply to message #640129] |
Fri, 19 November 2010 15:35 |
Do you get any errors running this report in the designer?
Run the report with the preview tab and then select the xml view and
look for any error indications.
Jason
On 11/19/2010 4:22 AM, Peng wrote:
> part4 :
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> FEINER: executor closed 19.11.2010 09:53:43
> 19.11.2010 09:53:44 DataEngineImpl shutdown
> FEINER: ENTRY
> 19.11.2010 09:53:44 org.eclipse.birt.data.engine.impl.DataEngineImpl
> shutdown
> FEIN: Data engine shuts down
> shutdown
> FEINER: RETURN
Re: Error: <unused> is not recognized! by using version 2.6.1 [message #640648 is a reply to message #640467] |
Mon, 22 November 2010 16:47 |
Where is this located in your report?
reporting/dsType_substance.png": ReferenceError: "reporting" is not defined
Jason
On 11/22/2010 3:50 AM, Peng wrote:
> Because i am using scripted dataset event hanlder to create report at
> run time, so by your suggestion "run report with preview tab" there are
> alwasy some exceptions due to non-exsiting resources.
> there are the shown messages in the xml view:
> Multiple annotations found at this line:
> - org.eclipse.birt.report.engine.api.EngineException: Unhandled
> exception when executing script. at
> org.eclipse.birt.report.engine.script.internal.ScriptExecuto
> r.addException(ScriptExecutor.java:162) at
> r.addException(ScriptExecutor.java:147) at
> org.eclipse.birt.report.engine.script.internal.ScriptDataSet
> ScriptExecutor.handleOpen(ScriptDataSetScriptExecutor.java:9 9) at
> org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime.open(
> ScriptDataSetRuntime.java:80) at
> ptDSQueryExecutor$CustomDataSet.open(PreparedScriptDSQuery.j ava:247) at
> ptDSQueryExecutor.executeOdiQuery(PreparedScriptDSQuery.java :223) at
> org.eclipse.birt.data.engine.impl.QueryExecutor.execute(Quer
> yExecutor.java:1094) at
> org.eclipse.birt.data.engine.impl.ServiceForQueryResults.exe
> cuteQuery(ServiceForQueryResults.java:232) at
> org.eclipse.birt.data.engine.impl.QueryResults.getResultIter
> ator(QueryResults.java:172) at
> org.eclipse.birt.report.engine.data.dte.QueryResultSet.<init
> >(QueryResultSet.java:98) at
> org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExec
> uteQuery(DteDataEngine.java:168) at
> org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.e
> xecute(AbstractDataEngine.java:265) at
> org.eclipse.birt.report.engine.executor.ExecutionContext.exe
> cuteQuery(ExecutionContext.java:1876) at
> org.eclipse.birt.report.engine.executor.QueryItemExecutor.ex
> ecuteQuery(QueryItemExecutor.java:80) at
> org.eclipse.birt.report.engine.executor.TableItemExecutor.ex
> ecute(TableItemExecutor.java:62) at
> org.eclipse.birt.report.engine.internal.executor.dup.Suppres
> sDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor .java:43)
> at org.eclipse.birt.report.engine.internal.executor.wrap.Wrappe
> dReportItemExecutor.execute
> (WrappedReportItemExecutor.java:46) at
> org.eclipse.birt.report.engine.internal.executor.l18n.Locali
> zedReportItemExecutor.execute(LocalizedReportItemExecutor.ja va:34) at
> org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking
> LM.layoutNodes(HTMLBlockStackingLM.java:65) at
> org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.la
> youtChildren(HTMLStackingLM.java:26) at
> org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.la
> yout(HTMLAbstractLM.java:140) at
> org.eclipse.birt.report.engine.layout.html.HTMLInlineStackin
> gLM.resumeLayout(HTMLInlineStackingLM.java:111) at
> gLM.layoutNodes(HTMLInlineStackingLM.java:160) at
> LM.layoutNodes(HTMLBlockStackingLM.java:70) at
> org.eclipse.birt.report.engine.layout.html.HTMLTableLM.layou
> tChildren(HTMLTableLM.java:132) at
> org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout
> (HTMLPageLM.java:90) at
> org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE
> ngine.layout(HTMLReportLayoutEngine.java:99) at
> org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR
> un(RunAndRenderTask.java:180) at
> org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run
> (RunAndRenderTask.java:77) at
> org.eclipse.birt.report.service.ReportEngineService.runAndRe
> nderReport(ReportEngineService.java:920) at
> org.eclipse.birt.report.service.BirtViewerReportService.runA
> ndRenderReport(BirtViewerReportService.java:973) at
> org.eclipse.birt.report.service.actionhandler.BirtGetPageAll
> ActionHandler.__execute(BirtGetPageAllActionHandler.java:131 ) at
> org.eclipse.birt.report.service.actionhandler.AbstractBaseAc
> tionHandler.execute(AbstractBaseActionHandler.java:90) at
> org.eclipse.birt.report.soapengine.processor.AbstractBaseDoc
> umentProcessor.__executeAction(AbstractBaseDocumentProcessor .java:47)
> at org.eclipse.birt.report.soapengine.processor.AbstractBaseCom
> ponentProcessor.executeAction
> (AbstractBaseComponentProcessor.java:143) at
> org.eclipse.birt.report.soapengine.processor.BirtDocumentPro
> cessor.handleGetPageAll(BirtDocumentProcessor.java:183) at
> sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce
> ssorImpl.java:39) at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe
> thodAccessorImpl.java:25) at
> java.lang.reflect.Method.invoke(Method.java:597) at
> ponentProcessor.process(AbstractBaseComponentProcessor.java: 112) at
> org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingI
> mpl.getUpdatedObjects(BirtSoapBindingImpl.java:
> 66) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at
> ssorImpl.java:39) at sun.reflect.DelegatingMethodAccessorImpl.invoke
> (DelegatingMethodAccessorImpl.java:25) at
> org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCP
> rovider.java:397) at
> org.apache.axis.providers.java.RPCProvider.processMessage
> (RPCProvider.java:186) at
> org.apache.axis.providers.java.JavaProvider.invoke(JavaProvi
> der.java:323) at
> org.apache.axis.strategies.InvocationStrategy.visit(Invocati
> onStrategy.java:32) at
> org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118) at
> org.apache.axis.SimpleChain.invoke(SimpleChain.java:83) at
> org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService .java:454)
> at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281 ) at
> org.apache.axis.transport.http.AxisServlet.doPost(AxisServle t.java:699)
> at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer
> vlet.doPost(BirtSoapMessageDispatcherServlet.java:265) at
> javax.servlet.http.HttpServlet.service(HttpServlet.java:
> 727) at org.apache.axis.transport.http.AxisServletBase.service(AxisS
> ervletBase.java:327) at
> javax.servlet.http.HttpServlet.service(HttpServlet.java:820) at
> org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.service
> (BirtSoapMessageDispatcherServlet.java:122) at
> org.eclipse.equinox.http.registry.internal.ServletManager$Se
> rvletWrapper.service(ServletManager.java:180) at
> org.eclipse.equinox.http.servlet.internal.ServletRegistratio
> n.service(ServletRegistration.java:
> 61) at org.eclipse.equinox.http.servlet.internal.ProxyServlet.proce
> ssAlias(ProxyServlet.java:126) at
> org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi
> ce(ProxyServlet.java:60) at
> org.eclipse.equinox.http.jetty.internal.HttpServerManager$In
> ternalHttpServiceServlet.service(HttpServerManager.java:318) at
> org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder .java:511)
> at org.mortbay.jetty.servlet.ServletHandler.handle
> (ServletHandler.java:390) at
> org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandl
> er.java:182) at
> org.mortbay.jetty.handler.ContextHandler.handle(ContextHandl
> er.java:765) at org.mortbay.jetty.handler.HandlerWrapper.handle
> (HandlerWrapper.java:152) at
> org.mortbay.jetty.Server.handle(Server.java:326) at
> org.mortbay.jetty.HttpConnection.handleRequest(HttpConnectio n.java:542)
> at org.mortbay.jetty.HttpConnection$RequestHandler.content(Http
> Connection.java:939) at
> org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:756) at
> org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java: 212) at
> org.mortbay.jetty.HttpConnection.handle(HttpConnection.java: 404) at
> org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEn
> dPoint.java:409) at
> org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThr
> eadPool.java:582) Caused by: java.lang.NullPointerException at
> com.xxx.xxx.reporting.rptbuilders.ItemReportProductScriptedD
> ataSetEH.open(ItemReportProductScriptedDataSetEH.java:30) at
> 96) ... 81 more
> - org.eclipse.birt.report.engine.api.EngineException: There are errors
> evaluating script "reporting/dsType_substance.png": ReferenceError:
> "reporting" is not defined. (<inline>#1) at
> org.eclipse.birt.report.engine.executor.ExecutionContext.add
> Exception(ExecutionContext.java:1195) at
> Exception(ExecutionContext.java:1155) at
> org.eclipse.birt.report.engine.executor.ReportItemExecutor.e
> valuateString(ReportItemExecutor.java:302) at
> org.eclipse.birt.report.engine.executor.ImageItemExecutor.ha
> ndleFileExpressionImage(ImageItemExecutor.java:279) at
> ndleImage(ImageItemExecutor.java:148) at
> org.eclipse.birt.report.engine.executor.ImageItemExecutor.ex
> ecute(ImageItemExecutor.java:106) at
> org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.ex ecute
> (HTMLAbstractLM.java:466) at
> ecute(HTMLAbstractLM.java:474) at
> org.eclipse.birt.report.engine.layout.html.HTMLListingBandLM
> .intializeHeaderContent(HTMLListingBandLM.java:98) at
> .initialize(HTMLListingBandLM.java:50) at
> org.eclipse.birt.report.engine.layout.html.HTMLTableBandLM.i
> nitialize(HTMLTableBandLM.java:44) at
> org.eclipse.birt.report.engine.layout.html.HTMLLayoutManager
> Factory.createLayoutManager(HTMLLayoutManagerFactory.java:40 ) at
> ngine.createLayoutManager
> (HTMLReportLayoutEngine.java:137) at
> LM.layoutNodes(HTMLBlockStackingLM.java:68) at
> org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.la youtChildren
> der.java:323) at
> er.java:182) at
> dPoint.java:409) at
> org.eclipse.birt.core.exception.CoreException: There are errors
> org.eclipse.birt.report.engine.javascript.JavascriptEngine.e
> valuate(JavascriptEngine.java:287) at
> org.eclipse.birt.core.script.ScriptContext.evaluate(ScriptCo
> ntext.java:154) at
> org.eclipse.birt.report.engine.executor.ExecutionContext.eva
> luate(ExecutionContext.java:740) at
> org.eclipse.birt.report.engine.executor.ExecutionContext.eva luate
> (ExecutionContext.java:669) at
> valuateString(ReportItemExecutor.java:297) ... 87 more Caused by:
> org.mozilla.javascript.EcmaError: ReferenceError: "reporting" is not
> org.mozilla.javascript.ScriptRuntime.constructError(ScriptRu
> ntime.java:3654) at
> ntime.java:3632) at
> org.mozilla.javascript.ScriptRuntime.notFoundError(ScriptRun
> time.java:3717) at
> org.mozilla.javascript.ScriptRuntime.nameOrFunction(ScriptRu
> ntime.java:1758) at
> org.mozilla.javascript.ScriptRuntime.name(ScriptRuntime.java :1697) at
> org.mozilla.javascript.gen.c14._c0(<inline>:1) at
> org.mozilla.javascript.gen.c14.call(<inline>) at
> org.mozilla.javascript.ContextFactory.doTopCall(ContextFacto
> ry.java:398) at
> org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime .java:3065)
> at org.mozilla.javascript.gen.c14.call(<inline>) at
> org.mozilla.javascript.gen.c14.exec(<inline>) at
> valuate(JavascriptEngine.java:282) ... 91 more
> evaluating script "reporting/dsType_material.png": ReferenceError:
> der.java:323) at
> er.java:182) at
> dPoint.java:409) at
> ntext.java:154) at
> ntime.java:3654) at
> ntime.java:3632) at
> time.java:3717) at
> ntime.java:1758) at
> org.mozilla.javascript.gen.c15._c0(<inline>:1) at
> org.mozilla.javascript.gen.c15.call(<inline>) at
> ry.java:398) at
> at org.mozilla.javascript.gen.c15.call(<inline>) at
> org.mozilla.javascript.gen.c15.exec(<inline>) at
> der.java:323) at
> er.java:182) at
> dPoint.java:409) at
> com.xxx.xxx.reporting.rptbuilders.ItemReportSupplierScripted
> DataSetEH.open(ItemReportSupplierScriptedDataSetEH.java:30) at
> 96) ... 81 more
> der.java:323) at
> er.java:182) at
> dPoint.java:409) at
> com.xxx.xxx.reporting.rptbuilders.ds.DSDetailScriptedDataSet
> EH.open(DSDetailScriptedDataSetEH.java:29) at
> ScriptExecutor.handleOpen(ScriptDataSetScriptExecutor.java:9 6) ... 81 more
> ScriptExecutor.handleFetch(ScriptDataSetScriptExecutor.java: 150) at
> org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime.fetch
> (ScriptDataSetRuntime.java:103) at
> ptDSQueryExecutor$CustomDataSet.fetch(PreparedScriptDSQuery. java:260)
> at org.eclipse.birt.data.engine.executor.cache.OdiAdapter.fetch
> (OdiAdapter.java:165) at
> org.eclipse.birt.data.engine.executor.cache.RowResultSet.nex
> t(RowResultSet.java:105) at
> org.eclipse.birt.data.engine.executor.cache.ExpandableRowRes ultSet.next
> (ExpandableRowResultSet.java:63) at
> .populateData(SmartCacheHelper.java:316) at
> .initInstance(SmartCacheHelper.java:
> 285) at org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper
> .getResultSetCache(SmartCacheHelper.java:246) at
> org.eclipse.birt.data.engine.executor.cache.SmartCache.<init
> >(SmartCache.java:72) at
> org.eclipse.birt.data.engine.executor.transform.pass.PassUti
> l.populateOdiResultSet(PassUtil.java:110) at
> l.pass(PassUtil.java:62) at
> org.eclipse.birt.data.engine.executor.transform.pass.PassMan
> ager.doSinglePass(PassManager.java:214) at
> ager.prepareDataSetResultSet(PassManager.java:97) at
> ager.pass(PassManager.java:128) at
> ager.populateResultSet(PassManager.java:77) at
> org.eclipse.birt.data.engine.executor.transform.ResultSetPop
> ulator.populateResultSet(ResultSetPopulator.java:198) at
> org.eclipse.birt.data.engine.executor.transform.CachedResult Set.
> <init>(CachedResultSet.java:192) at
> org.eclipse.birt.data.engine.executor.CandidateQuery.execute
> (CandidateQuery.java:106) at
> ptDSQueryExecutor.executeOdiQuery(PreparedScriptDSQuery.java :226) at
> org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExec uteQuery
Re: Error: <unused> is not recognized! by using version 2.6.1 [message #640947 is a reply to message #640798] |
Tue, 23 November 2010 16:02 |
Can you open a bug for this?
Jason
On 11/23/2010 3:43 AM, Peng wrote:
> the dsType_substance.png is located under xxx.war/images/reporting/ and
> reporting related classes/design-files are under
> xxx.war/WEB-INF/lib/xxx.jar, wenn i run the report within server, the
> image is shown correct in the generated pdf report.
> Peng
Current Time: Thu Apr 25 08:59:26 GMT 2024
Powered by FUDForum. Page generated in 0.05061 seconds
