problems with the workspace handling in RCP/Eclipse [message #639916] |
Thu, 18 November 2010 12:16 |
Nico Stieler Messages: 13 Registered: November 2010 |
Junior Member |
Dear Eclipse RCP people,
we are developing a product based on RCP and eclipse. We have some problems with the workspace handling:
• When starting the product the first time: it doesn't ask the user to choose the workspace. Instead it takes a default workspace : ./workspace.
• When use the function "switch workspace", it does restart
eclipse and add the entered workspace to the workspaces I can select
on "switch workspace", but it does not switch the workspace
I tried a lot of things to solve this:
• -data @noDefault, to force the product to ask the user for a workspace, but it does not work (errorlog1)
( Dani (daniel_mergert@ch.ibm.com) said that, you should simply remove "-data", but that's no solution: in this case it is just creating a default workspace)
• Set the workspace when the product is starting (code2) this
is working, but it's not a nice solution
• Many other things without any positive result.
What to do?
• Maybe using a different application super class or
interface.
Thanks a lot,
Nico Stieler
Re: problems with the workspace handling in RCP/Eclipse [message #639939 is a reply to message #639916] |
Thu, 18 November 2010 13:25 |
Dani Megert Messages: 3802 Registered: July 2009 |
> on "switch workspace", but it does not switch the workspace :(
> ( Dani (mailto:daniel_mergert@ch.ibm.com) said that, you should simply
At least the default eclipse.exe asks for the workspace.
Dani
> (code2) this
> What to do?
> interface.
> Thanks a lot,
> Best regards,
> Nico Stieler
FUDForum. Page generated in 0.03082 seconds
