[Acceleo/EMF] Problem in Main.java after refactoring one meta-model into two [message #639820] |
Wed, 17 November 2010 18:03  |
I just refactored my meta-model by splitting it into two separate ecore files, one for application-specific components and one for platform-specific components.
I loaded the resources from the application-specific meta-model into the platform-specific meta-model, created a single genmodel that contains both meta-models, and successfully generated the model editor plugin and started the new Eclipse. In my existing mtl file templates, I added the module imports to the top line of the mtl files to successfully wire the new dependencies.
However, one last problem remains that is stumping me. I recreated a new clean main.mtl and Main.java files.
Inside Main.java, there is a method called registerPackages. In the method, there are a bunch of calls to: resourceSet.getPackageRegistry().put(packagepath...)
They are all unresolved. Is there something obvious I'm missing?
Thanks for any help!
[Updated on: Wed, 17 November 2010 18:50] by Moderator
Re: [Acceleo/EMF] Problem in Main.java after refactoring one meta-model into two [message #640454 is a reply to message #640255] |
Mon, 22 November 2010 03:12   |
--------------030607070700010808010908
Hi Jeff,
I must admit I'm quite confused right now.
Could you briefly describe which projects you have in which Eclipse
workspace? If you followed one of the EMF tutorials I can think of when
defining your metamodel (the project that contains your genmodel), you
should have something resembling this :
"main" Eclipse, the first you launch :
com.xyz
|- src
| |- com
| |- xyz
| |- XYZPackage
|- model
|- xyz.ecore
|- xyz.genmodel
com.xyz.edit
com.xyz.editor
Then, in the "runtime" Eclipse, the one you launch from the "main", you
should have all of the projects that depend on the "xyz" model,
including your Acceleo project.
You shouldn't have _twice_ your metamodel project (containing your
"XYZPackage"), it should only exist in the "main" Eclipse workspace.
Laurent Goubet
Obeo
On 19/11/2010 19:44, glenviewjeff wrote:
> I found something that will likely indicate the problem, I just don't
> know how to fix it. I bet it stems from my ignorance of Eclipse/plugin
> development.
> In my project that contains the genmodel, I opened up the filesystem to
> look at the bin directory. I noticed that it contains a structure like
> this: bin\com\xyz\package123.
> However, the project in the child Eclipse that contains the installed
> model editor shows in its bin directory a different structure as I said
> in my previously posted message. (bin\package123)
> Also, I noticed that if I double click on one of the class files in the
> child Eclipse, Eclipse reports that it can't find the file.
> This is probably the wrong forum to be asking this question, but how
> does the plug-in dependency get updated in the Child Eclipse?
> Thanks for your help!
> Jeff
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------030607070700010808010908--
FUDForum. Page generated in 1.09277 seconds
