Home » Modeling » Epsilon » [EWL] Accessing model
[EWL] Accessing model [message #639813] Wed, 17 November 2010 22:29 Go to next message
Henning is currently offline HenningFriend
Member
I want to refactor my model utilizing EWL but I'm a little stuck on how to delete model elements. In my ETL files I called deleteElement(obj) on my loaded model, but how can I do that with EWL?
I also realized that I cannot use imports in EWL files, however, this would be a great benefit because I could reuse some of my ETL operations!
Henning
Re: [EWL] Accessing model [message #639816 is a reply to message #639813] Wed, 17 November 2010 22:36 Go to previous message
Dimitrios Kolovos is currently offline Dimitrios KolovosFriend
Hi Henning,
Henning wrote:
The implicit name of the loaded model in EWL is "Model". As such, to
delete an element you can call Model.deleteElement(obj) as usual.
EWL supports importing EOL files - like all other Epsilon languages. If
you have your operations inside a .etl file I'd suggest putting them in
a .eol file and then importing it from both your .etl and .ewl file.
> Henning
Dimitris
Previous Topic:Link constraints using Emphatic etc
Next Topic:A Problem Deploying a Plug-in with ETL
Current Time: Tue Apr 16 14:33:12 GMT 2024
Powered by FUDForum. Page generated in 0.24293 seconds
