Re: BIRT Error [message #639702 is a reply to message #639631] |
Wed, 17 November 2010 14:05 |
Neo,
can you post the design? Are the runtime versions of your development
and deployment environments the same?
Jason
On 11/17/2010 4:51 AM, Neo wrote:
> I created a BIRT report which is working fine in local server.
> But when I had uploaded it into the internet server. The report gave me
> the following. Would you please tell me what more should I do?
> Following is the error
> <html>
> <head>
> <title>Error</title>
> <META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=utf-8">
> </head>
> <body>
> <div id="birt_errorPage" style="color:red">
> <span id="error_icon" style="cursor:pointer" onclick="if
> (document.getElementById('error_detail').style.display == 'none') {
> document.getElementById('error_icon').innerHTML = '- ';
> document.getElementById('error_detail').style.display = 'block'; }else {
> document.getElementById('error_icon').innerHTML = '+ ';
> document.getElementById('error_detail').style.display = 'none'; }" > +
> </span>
> The report file : does not exist or contains errors.<br>
> <pre id="error_detail" style="display:none;" >
> org.eclipse.birt.report.exception.ViewerException: The report file :
> does not exist or contains errors.<br> at
> org.eclipse.birt.report.context.ViewerAttributeBean.getDesig
> nHandle(ViewerAttributeBean.java:647) <br> at
> org.eclipse.birt.report.context.ViewerAttributeBean.__init(V
> iewerAttributeBean.java:224) <br> at
> org.eclipse.birt.report.context.BaseAttributeBean.init(BaseA
> ttributeBean.java:233) <br> at
> org.eclipse.birt.report.context.ViewerAttributeBean.<init>(ViewerAttributeBean.java:118)
> <br> at org.eclipse.birt.report.context.BirtContext.__init(BirtConte
> xt.java:44) <br> at
> org.eclipse.birt.report.context.BaseContext.<init>(BaseContext.java:69)
> <br> at
> org.eclipse.birt.report.context.BirtContext.<init>(BirtContext.java:30)
> <br> at org.eclipse.birt.report.servlet.ViewerServlet.__getContext(V
> iewerServlet.java:150) <br> at
> org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer
> vlet.doPost(BirtSoapMessageDispatcherServlet.java:243) <br> at
> javax.servlet.http.HttpServlet.service(HttpServlet.java:710) <br> at
> org.apache.axis.transport.http.AxisServletBase.service(AxisS
> ervletBase.java:327) <br> at
> javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
> <br> at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer
> vlet.service(BirtSoapMessageDispatcherServlet.java:122) <br> at
> org.apache.catalina.core.ApplicationFilterChain.internalDoFi
> lter(ApplicationFilterChain.java:290) <br> at
> org.apache.catalina.core.ApplicationFilterChain.doFilter(App
> licationFilterChain.java:206) <br> at
> org.eclipse.birt.report.filter.ViewerFilter.doFilter(ViewerF
> ilter.java:68) <br> at
> lter(ApplicationFilterChain.java:235) <br> at
> org.apache.catalina.core.StandardWrapperValve.invoke(Standar
> dWrapperValve.java:233) <br> at
> org.apache.catalina.core.StandardContextValve.invoke(Standar
> dContextValve.java:175) <br> at
> org.apache.catalina.core.StandardHostValve.invoke(StandardHo
> stValve.java:128) <br> at
> org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo
> rtValve.java:102) <br> at
> org.apache.catalina.core.StandardEngineValve.invoke(Standard
> EngineValve.java:109) <br> at
> org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd
> apter.java:263) <br> at
> org.apache.coyote.http11.Http11Processor.process(Http11Proce
> ssor.java:844) <br> at
> org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand
> ler.process(Http11Protocol.java:584) <br> at
> org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoin t.java:447)
> <br> at java.lang.Thread.run(Thread.java:619)<br></pre>
Re: BIRT Error [message #639753 is a reply to message #639712] |
Wed, 17 November 2010 16:42 |
Thanks for updating.
On 11/17/2010 9:59 AM, Neo wrote:
> Hi jason,
> it was a relative path problem. I solved it on my own.
> One more I found out is usage of "\" and "/".
> It was a UNIX server where we have to use "/".
> I had used "\\".
> These two I found out, I thought I will share so that it may be useful
> for others when you are solving all the issues on BIRT.
> Kind Regards,
Re: BIRT Error [message #647146 is a reply to message #639712] |
Tue, 04 January 2011 18:23 |
James Mising name Messages: 26 Registered: November 2010 |
Hello, having the same issue and may be from the same cause. where did you have an issue with your slashes? Was it in web.xml or some kind of xml configuration and what did you do to fix?
I think it has to do with a BIRT_VIEWER_WORKING_FOLDER setting which I am not real sure how to set the path to root for both unix and windows.
James
[Updated on: Tue, 04 January 2011 18:25] Report message to a moderator
FUDForum. Page generated in 0.04829 seconds
