Home » Modeling » Papyrus » rename a papyrus model(question)
rename a papyrus model [message #639383] Tue, 16 November 2010 10:46 Go to next message
Andrea Sindico is currently offline Andrea SindicoFriend
Hi all,
I am a new Papyrus user. During my first attempts I can't manage to rename a papyrus model. There is not a refactor menu and the rename menu actually breaks some relationship between the model and the other files.
Could you please suggest me the right way?
Re: rename a papyrus model [message #639434 is a reply to message #639383] Tue, 16 November 2010 14:31 Go to previous messageGo to next message
Remi Schnekenburger is currently offline Remi SchnekenburgerFriend
Hi Andrea,
what do you want to do?
1. If you want to rename the model element, you can rename it in the Property View, when the model is selected in the Model Explorer.
You can also select the element in the model explorer and press F2 or use the rename... action. No relationship should be broken, as the relation between elements is not based on their names, but their unique identifier.
2. if you want to rename the files themselves, the better way is to use the "Save As..." Ability.
Both seems to work in the latest version. Which one are you currently using?
HTH,
RĂ©mi
Remi Schnekenburger
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Re: rename a papyrus model [message #640623 is a reply to message #639434] Mon, 22 November 2010 16:04 Go to previous message
Hi all,
I am sorry for my last question. It seems i had a broken Eclipse version since it works fine now I have installed it again.
Thank you for your kind answers
Andrea
Previous Topic:"Repository moved permanently ..."
Next Topic:How to model UML qualifier?
Current Time: Tue Aug 04 08:55:19 GMT 2020
Powered by FUDForum. Page generated in 0.01521 seconds
