Re: How to pass parameter to scripted data source [message #639228 is a reply to message #639130] |
Mon, 15 November 2010 16:07 |
Vijay,
How are you using the parameter in the scripted datasource. You can add
a dataset parmeter to a scripted datasource and link it to a report
parameter and then reference the parameter in script like:
inputParams["mydatasetparameter"].value
You should also be able to reference the report parmeter using
params["myparameterName"].value
Jason
On 11/15/2010 6:59 AM, vijay kumar wrote:
> HI i am working on one sample example on using scripted data source.I am
> able to run sucessfully .In next step want to pass parameters.After
> google i found that we we need to use params["myparameterName"]); But
> this is not giving any result when i preview the result.
> So can any one help me on this regard.
> Thank you in advance
> Vijay Kumar Bolisetti
FUDForum. Page generated in 0.01631 seconds
