Home » Modeling » TMF (Xtext) » Loading a resource
Loading a resource [message #639116] Mon, 15 November 2010 11:15 Go to next message
Robin  is currently offline Robin Friend
I was trying to play around with the code given in the xtext Tutorial under Processing Xtext Models, Loading a Resource ( http://www.eclipse.org/Xtext/documentation/latest/xtext.html #processing_Xtext_models), but I cannot get it to work.
		// DomainmodelStandaloneSetup.doSetup();
		new DomainmodelStandaloneSetup().createInjectorAndDoEMFRegistration();
		ResourceSet rs = new ResourceSetImpl();
		File file = new File("C:/runtime-EclipseApplication/gettingstarted/my2.dmodel");
		Resource resource = rs.getResource(URI.createURI(file.toURI().toString()), true);
//		Resource resource = rs.getResource(URI.createURI("./my2.dmodel"), true);
		EObject eobject = resource.getContents().get(0);
		DomainModel domainModel = (DomainModel) eobject;
		EList<AbstractElement> elements = domainModel.getElements();
		for (AbstractElement abstractElement : elements) {
		  if (abstractElement instanceof Entity) {
		    Entity entity = ((Entity)abstractElement);
		    System.out.println("entity "
		     + entity.getName()
		     + " extends "
		     + entity.getSuperType().getName());
I get this error:
Exception in thread "main" java.lang.RuntimeException: Cannot create a resource for 'file:/C:/runtime-EclipseApplication/gettingstarted/my2.dmodel'; a registered resource factory is needed
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:394)
	at org.eclipse.xtext.example.Test.main(Test.java:26)
from the line:
I created the Java file in the org.eclipse.xtext.example.domainmodel project, in the package org.eclipse.xtext.example.
What am I missing?? Confused
Regard, Robin
Re: Loading a resource [message #639371 is a reply to message #639116] Tue, 16 November 2010 09:53 Go to previous messageGo to next message
Jan Koehnlein is currently offline Jan KoehnleinFriend
Are you running your code from within Eclipse (not in a separate JVM)?
If so, you shouldn't call the DomainmodelStandaloneSetup. Otherwise, use
a debugger to make sure the line
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "dmodel",
resourceFactory);
in DomainmdodelStandaloneSetupGenerated is called. This is where the
resource factory should be registered.
Am 15.11.10 12:16, schrieb Robin:
> new DomainmodelStandaloneSetup().createInjectorAndDoEMFRegistrat ion();
> File file = new
> File("C:/runtime-EclipseApplication/gettingstarted/my2.dmodel ");
> Resource resource =
> + entity.getName()
> + " extends "
> I get this error:
> resource for
> 'file:/C:/runtime-EclipseApplication/gettingstarted/my2.dmod el'; a
> at
> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:394)
> from the line:
> Resource resource =
> What am I missing?? :?
> Regard, Robin
Get professional support from the Xtext committers at www.typefox.io
Re: Loading a resource [message #643566 is a reply to message #639371] Tue, 07 December 2010 13:15 Go to previous messageGo to next message
Since I am using the code generated by the MWE2 generation, I am running the Test.java in the same workspace. I don't see why this should be a problem, since nothing is actually running, when I run the Test.java.
How should I do this properly?? It doesn't say in the tutorial ( http://www.eclipse.org/Xtext/documentation/latest/xtext.html #processing_Xtext_models).
The line
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put("dmodel ", resourceFactory);
in DomainmodelStandaloneSetupGenerated is called. I debugged it. But still then the ResourceSetImpl.getResource method falls through every case and eventually throws the RuntimeException. So, somehow the Resource is not properly registered??
I have absolutely no clue... Sad
Re: Loading a resource [message #644567 is a reply to message #643566] Mon, 13 December 2010 10:12 Go to previous messageGo to next message
Anyone?? Just some thoughts or clues to help me get in the right direction, please?? Sad
Re: Loading a resource [message #644773 is a reply to message #644567] Tue, 14 December 2010 08:28 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
Hi Robin
did you try to use this URI:
rs.getResource(URI.createURI("my2.dmodel"), true);
Basically you code looks ok. However, I'd assume that the file uri has
to use two slashes: file://c:/..
Sebastian
Am 13.12.10 11:12, schrieb Robin:
> direction, please?? :(
Re: Loading a resource [message #644837 is a reply to message #639116] Tue, 14 December 2010 12:15 Go to previous messageGo to next message
Eisfeld Andrej is currently offline Eisfeld AndrejFriend
Hi Robin,
maybe you could try this:
File file = new File("C:\\runtime-EclipseApplication\\gettingstarted\\my2.dmodel");
regards
Andy
Re: Loading a resource [message #646769 is a reply to message #639116] Thu, 30 December 2010 21:59 Go to previous messageGo to next message
Hi!
Thanks for the replies. Sadly none is working.
gives
Exception in thread "main" java.lang.RuntimeException: Cannot create a resource for 'my2.dmodel'; a registered resource factory is needed
File file = new File("//C:/runtime-EclipseApplication/gettingstarted/my2.dmodel");
gives
File file = new File("file://C:/runtime-EclipseApplication/gettingstarted/my2.dmodel");
also gives
Exception in thread "main" java.lang.RuntimeException: Cannot create a resource for 'file:/C:/eclipsew/org.eclipse.xtext.example.domainmodel/file:/C:/runtime-EclipseApplication/gettingstarted/my2.dmodel'; a registered resource factory is needed
maybe like this:
Resource resource = rs.getResource(URI.createURI("file://C:/runtime-EclipseApplication/gettingstarted/my2.dmodel"), true);
gives
Exception in thread "main" java.lang.RuntimeException: Cannot create a resource for 'file://C:/runtime-EclipseApplication/gettingstarted/my2.dmodel'; a registered resource factory is needed
or
also gives
Well, I guess it is not the File or URI object since this is valid. The factory simply seems not to be registered. How can that be??? Confused
Regards, Robin
Re: Loading a resource [message #646770 is a reply to message #646769] Thu, 30 December 2010 22:15 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
hello robin,
can you post your complete code loading the model. seems you are not callling standalonesetup.
this code works nicely for me
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.xtext.example.DomainmodelStandaloneSetup;
import org.eclipse.xtext.example.domainmodel.DomainModel;
public class Test {
		Resource resource = rs.getResource(URI.createURI("./src/test.dmodel"), true);
		DomainModel model = (DomainModel) resource.getContents().get(0);
		System.out.println(model.getElements().size());
~Christian
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: Loading a resource [message #654227 is a reply to message #646770] Mon, 14 February 2011 16:43 Go to previous messageGo to next message
Okay, trying again...
I plain tried your code (with the needed modifications of course), but it doesn't work. I think it's not a coding problem but more a how to do things kind of problem.
I am running the Test.java from here: org.eclipse.xtext.example.domainmodel\src\org\eclipse\xtext\ example\Test.java
Directly in the domainmodel, because the generated classes are there available. Maybe this is the wrong way??
Isn't there a full tutorial that covers the "whole way" of working with a DSL in xtext?? That truly would be great.
Regards, Robin
Re: Loading a resource [message #654257 is a reply to message #654227] Mon, 14 February 2011 19:19 Go to previous messageGo to next message
hi,
can you share a runnable example
~Christian
Re: Loading a resource [message #654820 is a reply to message #654257] Thu, 17 February 2011 10:00 Go to previous messageGo to next message
Well, OK, there isn't much, but I put the workspace and the runtime directory in an archive:
http://dl.dropbox.com/u/5602365/workspace_and_runtime.zip
My configuration is set up like this:
- the workspace is located on my machine at: C:\eclipsew
- the runtime environment is located on my machine at: C:\runtime-EclipseApplication
- eclipse-SDK-3.6-xtext-1.0.1-win32 is installed at: C:\eclipse
The test files are:
C:\eclipsew\org.eclipse.xtext.example.domainmodel\src\org\ec lipse\xtext\example\Test.java
and
C:\eclipsew\org.eclipse.xtext.example.domainmodel\src\org\ec lipse\xtext\example\Test2.java
Test.java is very messy and contains a lot of trying out but mostly just commented out code, Test2.java is the one with the code Christian provided.
Thanks for having a look!
Regards, Robin
Re: Loading a resource [message #654957 is a reply to message #654820] Thu, 17 February 2011 18:18 Go to previous messageGo to next message
the problem is simple but hard to find Smile you file extension is "dmodel " (ending with a blank) but your files have od course the extension "dmodel". so changing your workflow to
var grammarURI = "classpath:/org/eclipse/xtext/example/Domainmodel.xtext"
var file.extensions = "dmodel"
var projectName = "org.eclipse.xtext.example.domainmodel"
var runtimeProject = "../${projectName}"
might solve the problems Wink Note: you may have to merge plugin.xml and plugin.xml_gen
Feel free to file an enhancement request for a validation rule that complains on whitespace in the file extension.
~Christian
[Updated on: Thu, 17 February 2011 18:19]
Report message to a moderator
Re: Loading a resource [message #657564 is a reply to message #654957] Thu, 03 March 2011 10:15 Go to previous messageGo to next message
Fa Za is currently offline Fa ZaFriend
I 'd know if the org.eclipse.xtext.example.domainmodel.DomainModel interface is generated automatically or added manually because I don't find it in my project after generation in the src-gen folder
thanks
Re: Loading a resource [message #659956 is a reply to message #657564] Wed, 16 March 2011 11:13 Go to previous messageGo to next message
Christian, thank you so much. It works now. I just changed
var file.extensions = "dmodel "
to
in GenerateDomainmodel.mwe2.
@Faiez: I have the DomainModel.java interface in org.eclipse.xtext.example.domainmodel belonging to the src-gen folder. So it is generated automatically.
Regards, Robin
Re: Loading a resource [message #901064 is a reply to message #659956] Thu, 09 August 2012 15:17 Go to previous messageGo to next message
Lau sy is currently offline Lau syFriend
That's the key......change the extension
But why?
I read the xtext tutorial again and again but not find the source......
Robin wrote on Wed, 16 March 2011 07:13
to
Regards, Robin
Re: Loading a resource [message #901071 is a reply to message #901064] Thu, 09 August 2012 15:33 Go to previous message
Having a trailing blank got a big mess with internal registries -
giving a blank as file extension does not work in most OS but in java
storing it as a key in a hash map does work well
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Previous Topic:SyntacticSequencer
Next Topic:Xtext standalone application beginner tutorial
Current Time: Thu Jan 28 12:28:02 GMT 2021
Powered by FUDForum. Page generated in 0.02830 seconds
