Home » Modeling » EMF » [Teneo] Latest build depends on Hibernate 3.6, introducing binary incompatability
[Teneo] Latest build depends on Hibernate 3.6, introducing binary incompatability [message #638906] Sat, 13 November 2010 03:50 Go to next message
Martin Taal is currently offline Martin TaalFriend
The build of today introduces a strong dependency on Hibernate 3.6 and the jpa persistence 2.0 jar file. The upgrade
means that a binary incompatibility has be introduced and that users of Teneo are forced to use the jpa persistence jar
2.0 or higher and Hibernate 3.6.
The binary incompatibility is created because the HbEntityDataStore supports the EntityManagerFactory interface which
introduced a getProperties method which already existed in the HbEntityDataStore (with a different signature).
The original HbDataStore.getProperties method has been renamed to: HbDataStore.getDataStoreProperties. In addition a new
dataStore.setDataStoreProperties has been introduced.
The binary incompatibility is inconvenient but it is only in one location. This api is normally only used at
initialization time. So I expect that the impact is small and it should be easy to solve this for anyone using Teneo.
JPA 2.0 has been out there for a while, so it makes sense to upgrade to it.
In parallel I have upgraded the hibernate version on the elver.org update site (http://www.elver.org/eclipse/update) to
offer the latest version of Hibernate.
The above statement is also present on the Teneo Hibernate landing page in the wiki:
http://wiki.eclipse.org/Teneo/Hibernate
http://wiki.eclipse.org/Teneo/Hibernate/BackwardCompatibilit y
The previous versions of Teneo are available on a parallel update site, see this page:
http://wiki.eclipse.org/Teneo/Hibernate/Download_and_Install
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Latest build depends on Hibernate 3.6, introducing binary incompatability [message #638929 is a reply to message #638906] Sat, 13 November 2010 12:34 Go to previous message
Thomas Schindl is currently offline Thomas SchindlFriend
Hi Martin,
Thank you very much, we'll probably switch over in the next days and
report our findings.
Tom
Am 13.11.10 04:50, schrieb Martin Taal:
> the jpa persistence 2.0 jar file. The upgrade means that a binary
> use the jpa persistence jar 2.0 or higher and Hibernate 3.6.
> supports the EntityManagerFactory interface which introduced a
> location. This api is normally only used at initialization time. So I
> anyone using Teneo.
> update site (http://www.elver.org/eclipse/update) to offer the latest
> in the wiki:
> see this page:
Previous Topic:[CDO] java.lang.IllegalArgumentException: id instanceof CDOIDTemp
Next Topic:Teneo 1.1.1 java.lang.SecurityException
Current Time: Sun Mar 29 07:11:24 GMT 2020
Powered by FUDForum. Page generated in 0.02422 seconds
