Home » Modeling » Graphiti » Save as ... Image, without editor(is it plan ?)
Save as ... Image, without editor [message #638807] |
Fri, 12 November 2010 16:06  |
Tristan Faure Messages: 448 Registered: July 2009 |
Hi !
I'm very interesting in Graphiti and I would like to know if it exists (or if it is plan to develop) an equivalent to the GMF OffscrenEditPartFactory ?
This mechanism allows plugins to render a diagram and export it in image file (for example) without opening the editor.
Another example from GMF is the class CopyToImageUtil allowing developers to automatically export a diagram at a specific folder.
Tristan FAURE
Re: Save as ... Image, without editor [message #664319 is a reply to message #664292] |
Fri, 08 April 2011 11:33   |
J. Weimar Messages: 8 Registered: March 2011 Location: Germany |
Dear Micheal, for your information, after extensive copying form the sources, I have created my custom feature which can save the diagram as an image with the properties I need. Code cleanup and documentation can still be improved, but I refactored the method initScaledImage to also work efficiently for scale factor 1.0.
Best regards, Jörg.
* <copyright>
* Copyright (c) 2005, 2010 SAP AG.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* SAP AG - initial API, implementation and documentation
* </copyright>
package de.jweimar.mockup.mockplug.export;
import java.io.ByteArrayInputStream;
import java.io.ByteArrayOutputStream;
import java.io.InputStream;
import org.eclipse.core.resources.IFile;
import org.eclipse.core.resources.IFolder;
import org.eclipse.core.resources.IProject;
import org.eclipse.core.resources.IResource;
import org.eclipse.core.resources.IWorkspace;
import org.eclipse.core.resources.IWorkspaceRoot;
import org.eclipse.core.resources.ResourcesPlugin;
import org.eclipse.core.runtime.CoreException;
import org.eclipse.core.runtime.IProgressMonitor;
import org.eclipse.core.runtime.IStatus;
import org.eclipse.core.runtime.Status;
import org.eclipse.draw2d.Graphics;
import org.eclipse.draw2d.IFigure;
import org.eclipse.draw2d.SWTGraphics;
import org.eclipse.draw2d.geometry.Rectangle;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.gef.EditPart;
import org.eclipse.gef.GraphicalEditPart;
import org.eclipse.gef.GraphicalViewer;
import org.eclipse.gef.LayerConstants;
import org.eclipse.gef.editparts.LayerManager;
import org.eclipse.graphiti.features.IFeatureProvider;
import org.eclipse.graphiti.features.context.ICustomContext;
import org.eclipse.graphiti.features.custom.AbstractCustomFeature;
import org.eclipse.graphiti.internal.util.T;
import org.eclipse.graphiti.ui.internal.editor.DiagramEditorInternal;
import org.eclipse.graphiti.ui.internal.editor.GFFigureCanvas;
import org.eclipse.graphiti.ui.internal.fixed.FixedScaledGraphics;
import org.eclipse.graphiti.ui.internal.services.GraphitiUiInternal;
import org.eclipse.jface.dialogs.MessageDialog;
import org.eclipse.jface.dialogs.ProgressMonitorDialog;
import org.eclipse.swt.SWT;
import org.eclipse.swt.SWTException;
import org.eclipse.swt.graphics.GC;
import org.eclipse.swt.graphics.Image;
import org.eclipse.swt.graphics.ImageData;
import org.eclipse.swt.graphics.ImageLoader;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.ui.actions.WorkspaceModifyOperation;
* @author weimar Most code copied from
* org.eclipse.graphiti.ui.internal.util.ui.
* print.AbstractFigureSelectionDialog
public class PreviewExporter extends AbstractCustomFeature {
// initial values
protected GraphicalViewer _graphicalViewer;
protected final String folderName = "export";
protected final String fileName = "preview.jpg";
protected final double scale = 1.5;
* <code>_allFigure</code> represents a figure that contains all printable
* layers
protected IFigure _allFigure;
protected boolean _insideInternalModify = false;
// selected values
* Image corresponding to the whole diagram (scaled version)
private Image _image;
public PreviewExporter(IFeatureProvider fp) {
super(fp);
* (non-Javadoc)
* @see
* org.eclipse.graphiti.features.custom.AbstractCustomFeature#canExecute
* (org.eclipse.graphiti.features.context.ICustomContext)
public boolean canExecute(ICustomContext context) {
// TODO Auto-generated method stub
return true;
public String getDescription() {
return "Export preview to " + folderName + "/" + fileName;
public String getName() {
return "&Preview";
@SuppressWarnings("restriction")
public void execute(ICustomContext context) {
IFile destination;
try {
destination = createDirectoryResource(
this.getDiagram().eResource(), folderName)
.getFile(fileName);
} catch (CoreException e) {
e.printStackTrace();
return;
// get the graphical Viewer
_graphicalViewer = (GraphicalViewer) ((DiagramEditorInternal) super
.getDiagramEditor()).getAdapter(GraphicalViewer.class);
_allFigure = determineRootFigure();
// create the image
setScaledImage(scale);
startSaveAsImageWithoutDialog(_image, destination);
* creates or returns a folder in the root directory of the current project
* (as given by the resource)
* @param diagramResource
* used only to determine the current project.
* @param folderName
* name of the (top level) folder in the project.
* @return the folder, which is created if it did not exist.
* @throws CoreException
private IFolder createDirectoryResource(Resource diagramResource,
String folderName) throws CoreException {
IWorkspace workspace = ResourcesPlugin.getWorkspace();
IWorkspaceRoot root = workspace.getRoot();
IProject project = root.getProject(diagramResource.getURI().segment(1));
IFolder folder = project.getFolder(folderName);
// at this point, no resources have been created
if (!project.exists()) {
return null;
// project.create(null);
if (!project.isOpen())
project.open(null);
if (!folder.exists())
folder.create(IResource.NONE, true, null);
return folder;
* copied from UiService and modified.
public byte[] createImage(Image image, int format) throws Exception {
ByteArrayOutputStream result = new ByteArrayOutputStream();
try {
ImageData imDat = image.getImageData();
ImageLoader imageLoader = new ImageLoader();
imageLoader.data = new ImageData[] { imDat };
try {
imageLoader.save(result, format);
} catch (SWTException e) {
String error = "Depth: " + Integer.toString(image.getImageData().depth) + "\n" + "X: " //$NON-NLS-1$ //$NON-NLS-2$ //$NON-NLS-3$
+ Integer.toString(image.getImageData().x)
+ "\n" + "Y: " + Integer.toString(image.getImageData().y); //$NON-NLS-1$ //$NON-NLS-2$
throw new IllegalStateException(error, e);
} finally {
image.dispose();
return result.toByteArray();
public void startSaveAsImageWithoutDialog(Image im, IFile destination) {
final Shell shell = GraphitiUiInternal.getWorkbenchService().getShell();
try {
WorkspaceModifyOperation operation;
int imageFormat = SWT.IMAGE_JPEG;
byte image[] = createImage(im, imageFormat);
operation = getSaveToFileOp(destination, image);
new ProgressMonitorDialog(shell).run(false, false, operation);
} catch (Exception e) {
String message = "Can not save image: "; //$NON-NLS-1$
MessageDialog.openError(shell,
"Can not save image", message + e.getMessage()); //$NON-NLS-1$
* Returns a WorkspeceModifyOperation, which saves the given contents to a
* File with the given filename.
* @param filename
* The name of the file, where to save the contents.
* @param contents
* The contents to save into the file.
* @throws Exception
* On any errors that occur. copied from UiService
private WorkspaceModifyOperation getSaveToFileOp(final IFile destination,
final byte contents[]) throws Exception {
WorkspaceModifyOperation operation = new WorkspaceModifyOperation() {
protected void execute(IProgressMonitor monitor)
try {
InputStream source = new ByteArrayInputStream(contents);
if (!destination.exists()) {
destination.create(source, IResource.NONE, null);
} else {
destination.setContents(source, IResource.NONE, null);
// convert exceptions to CoreExceptions
Status status = new Status(
IStatus.ERROR,
"de.jweimar.mockup", IStatus.ERROR, "Can not save image as file: " //$NON-NLS-1$
+ e.getMessage(), e);
throw new CoreException(status);
return operation;
private IFigure determineRootFigure() {
// Code snipped copied from AbstractFigureSelectionDialog
org.eclipse.swt.widgets.Control control = _graphicalViewer.getControl();
if (control instanceof GFFigureCanvas) {
GFFigureCanvas canvas = (GFFigureCanvas) control;
canvas.regainSpace();
EditPart rootEditPart = _graphicalViewer.getRootEditPart();
if (!(rootEditPart instanceof GraphicalEditPart))
return null;
// determine _allFigure
GraphicalEditPart graphicalRootEditPart = (GraphicalEditPart) rootEditPart;
IFigure rootFigure = ((LayerManager) graphicalRootEditPart)
.getLayer(LayerConstants.PRINTABLE_LAYERS);
if (rootFigure == null)
return null;
return rootFigure;
public void setScaledImage(double scaleFactor) {
cleanUp();
_image = null;
double upperBoundPixels = 3000.0d;
initScaledImage(scaleFactor, upperBoundPixels);
private void initScaledImage(double scaleFactor, double upperBoundPixels) {
GC gc = null;
// if the scale factor is too high, the operating system will
// not be able to provide a handle,
// because the Image would require too much space. "no more
// Handles"-Exception or "out of Memory" Error
// will be thrown
if (scaleFactor * _allFigure.getBounds().width > upperBoundPixels
|| scaleFactor * _allFigure.getBounds().height > upperBoundPixels) {
scaleFactor = Math.min(upperBoundPixels
/ _allFigure.getBounds().width, upperBoundPixels
/ _allFigure.getBounds().height);
_image = new Image(Display.getDefault(),
(int) (_allFigure.getBounds().width * scaleFactor),
(int) (scaleFactor * _allFigure.getBounds().height));
gc = new GC(_image);
Graphics graphics = null;
if (scaleFactor != 1.0) {
FixedScaledGraphics fsg = new FixedScaledGraphics(new SWTGraphics(
gc));
fsg.scale(scaleFactor);
graphics = fsg;
} else {
graphics = new SWTGraphics(gc);
/* move all figures into the positive region */
EditPart contents = _graphicalViewer.getContents();
if (contents instanceof GraphicalEditPart) {
IFigure contentsFigure = ((GraphicalEditPart) contents).getFigure();
Rectangle contentBounds = contentsFigure.getBounds();
graphics.translate(-contentBounds.x, -contentBounds.y);
_allFigure.paint(graphics);
if (gc != null)
gc.dispose();
if (graphics != null)
graphics.dispose();
public Image getScaledImage() {
return _image;
public void cleanUp() {
if (_image != null)
_image.dispose();
Current Time: Fri Jan 22 17:31:22 GMT 2021
Powered by FUDForum. Page generated in 0.02067 seconds
