Re: [CDO] generating dawn genmodel [message #638988 is a reply to message #638869] |
Sun, 14 November 2010 13:11 |
Martin Fluegge Messages: 141 Registered: July 2009 |
Hi Ronald,
comments below.
Am 12.11.2010 21:20, schrieb Ronald Krijgsheld:
> Hi Martin,
> below the stacktrace.
> I'm not really sure if I understand your question on what I'm trying to
> generate. I simply right click on a genmodel to generate the
> corresponding dawngemodel. So, I suppose that can only generate a dawn
> genmodel for editor support. Later, we'll need a CDO enabled GMF editor
> or a CDO enabled Graphiti editor.
Not exactly. Dawn currently supports generating extensions for GMF
editors and EMF (tree-based) editors, although the latter is still work
in progress.
To gain the required information the Dawn GenModel decorates the other
generator models. So the Dawn GenModel can hold a reference to the EMF
genmodel (*.genmodel) and/or the GMF genmodel (*.gengmf).
To add the GMF related information the context menu on the *.gmfgen must
be used invoked whereas you must use the context menu entry in the
*genmodel to add the information for the tree-based editor. That's why I
asked what kind of editor extension you tried to generated.
I admit that this handling is not perfect yet. Soon, I am going to
create a wizard which will make the workflow a bit more understandable.
But however. There was indeed a bug in the creation procedure which is
now fixed. It should work with the next build. If not, please let me know.
Martin
> But first I just wanted to see what code is generated and how I need to
> change my existing code to make use of the generated dawn code. First
> things first :)
> Ronald
> Caused by: org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos
> ticWrappedException: java.io.FileNotFoundException:
> C:\projects\systemize\newsvn\pmw\trunk\com.cmic.pmw.foundati
> on\model\Foundation.dawngenmodel
> pecified)
> at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe
> mandLoadException(ResourceSetImpl.java:315)
> at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo
> adHelper(ResourceSetImpl.java:274)
> at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou
> rce(ResourceSetImpl.java:397)
> at org.eclipse.emf.cdo.dawn.codegen.actions.GenerateDawnGenMode
> lAction.getDawnGenModelResource(GenerateDawnGenModelAction.j ava:205)
> lAction.access$3(GenerateDawnGenModelAction.java:201)
> lAction$1.run(GenerateDawnGenModelAction.java:80)
> at org.eclipse.jface.operation.ModalContext$ModalContextThread.
> run(ModalContext.java:121)
> Caused by: java.io.FileNotFoundException:
> on\model\Foundation.dawngenmodel (The system cannot find the file
> specified)
> at java.io.FileInputStream.open(Native Method)
> at java.io.FileInputStream.<init>(Unknown Source)
> at org.eclipse.emf.ecore.resource.impl.FileURIHandlerImpl.creat
> eInputStream(FileURIHandlerImpl.java:105)
> at org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterIm
> pl.createInputStream(ExtensibleURIConverterImpl.java:301)
> at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour
> ceImpl.java:1254)
> ad(ResourceSetImpl.java:255)
> adHelper(ResourceSetImpl.java:270)
> ... 5 more
Re: [CDO] generating dawn genmodel [message #639049 is a reply to message #638988] |
Mon, 15 November 2010 06:05 |
Am 14.11.2010 14:11, schrieb Martin Flügge:
> Hi Ronald,
> comments below.
>> Hi Martin,
> in progress.
I wonder if it's a good design to add dependencies on various third party technologies (GMF, Grafiti, ...) to a single Dawn plugin. Does that mean that a user who only wants to generate a CDO'ified EMF tree editor has to install GMF?
Cheers
/Eike
http://www.esc-net.de
> Cheers,
> Martin
>> things first :)
>> Thanks,
>> Ronald
>> pecified)
>> specified)
>> ceImpl.java:1254)
>> ... 5 more
Cheers
/Eike
FUDForum. Page generated in 0.03368 seconds
