Home » Modeling » EMF » Generating both an RCP and IDE-hosted editor
Generating both an RCP and IDE-hosted editor [message #638752] Fri, 12 November 2010 13:24 Go to next message
Michael Spertus is currently offline Michael SpertusFriend
Member
I have types that I want to edit both within my IDE (i.e., non-RCP) and also within RCP applications. However, those appear to be mutually exclusive code generation options. I certainly don't want to have to generate, rename, and manually make changes to one of the editors as my model evolves. What is the best approach for me to take?
Mike
Re: Generating both an RCP and IDE-hosted editor [message #638767 is a reply to message #638752] Fri, 12 November 2010 13:57 Go to previous message
Mike,
If you look at what's generated, it's generally unaffected by any
changes in your model, so only if the templates change is there a need
to regenerate them. So the best I can suggest is you change the
GenModel to target different projects (change Editor Directory and
Editor Plug-in ID) at the time you want to regenerated. It doesn't
matter that the two different projects contain identically named classes.
> Mike
Ed Merks
Previous Topic:EMF Helios Dev Environment
Next Topic:XMI Serialization - Pure EObject instead of my Business Object
Current Time: Mon Aug 10 12:26:26 GMT 2020
Powered by FUDForum. Page generated in 0.01949 seconds
