Home » Modeling » M2T (model-to-text transformation) » [acceleo]Accessing UML elements in SysML Model
[acceleo]Accessing UML elements in SysML Model [message #638635] Thu, 11 November 2010 21:13 Go to next message
Bill Kinahan is currently offline Bill KinahanFriend
I'm using acceleo to generate a simple simulation from a SysML model I am constructing, but I'm having difficulty accessing elements of the model that are part of UML and not specifically SysML extensions (e.g., package, stanrad port, etc.).
How can I get at these elements of my model? Do I need to include another resource in my acceleo model? my SysML model?
Thanks in advance for the help,
Bill
Re: [acceleo]Accessing UML elements in SysML Model [message #638639 is a reply to message #638635] Thu, 11 November 2010 21:57 Go to previous messageGo to next message
Never mind. I think I figured it out. I added the path to the UML meta model in the module statement. Its not clear from the syntax in the OMG spec that you can list multiple meta models, but apparently you can.
Re: [acceleo]Accessing UML elements in SysML Model [message #638808 is a reply to message #638635] Fri, 12 November 2010 16:07 Go to previous messageGo to next message
Stephane Begaudeau is currently offline Stephane BegaudeauFriend
Glad to hear that you have solved your problem. And yes, Acceleo supports multiple input metamodel.
Stéphane Bégaudeau, Obeo.
Re: [acceleo]Accessing UML elements in SysML Model [message #639151 is a reply to message #638808] Mon, 15 November 2010 12:21 Go to previous message
Laurent Goubet is currently offline Laurent GoubetFriend
--------------080101090100070704030500
Bill,
See also my answer to your other thread, and please refrain from posting
multiple identical questions.
Laurent Goubet
Obeo
On 12/11/2010 17:07, Stephane Begaudeau wrote:
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------080101090100070704030500--
Previous Topic:[acceleo]Accessing UML elements in SysML Model
Next Topic:[Acceleo 3] Howto use a model in memory
Current Time: Thu Oct 28 12:33:38 GMT 2021
Powered by FUDForum. Page generated in 0.01577 seconds
