Re: Problem BIRT and WindowBuilder Pro [message #638564 is a reply to message #638483] |
Thu, 11 November 2010 16:07 |
Agustin,
I just tried this and did not get an issue. What I did is started with
the birt all in one download eclipse-reporting-helios-SR1-win32 and then
used the update manager to add the WB Pro. I added all the features
from WB Pro and it worked well.
Jason
On 11/11/2010 8:08 AM, agustin wrote:
> My instalation of Eclipse is for develpment report (BIRT) and I have
> installed WIndowBuilder Pro. I want to make an UI for access to reports.
> Since I installed WB Pro, BIRT don´t work. The preview is blank and when
> I try a report in the internal browser, eclipse is thinking in a blank
> frame, but the report don't make it.
> I installed GWT designer, Swing designer and SWT designer, all packages.
> My O.S. is Windows Vista and Eclipse es Version Helios (and BIRT 2.6.1).
> I have gone uninstall one application for one and BIRT don' work until
> all packages were uninstalled.
> Do you know why is this? Any idea?
> Thanks. Grettings from Spain.
Re: Problem BIRT and WindowBuilder Pro [message #638770 is a reply to message #638692] |
Fri, 12 November 2010 14:26 |
Did you start with the BIRT allinone download?
Jason
On 11/12/2010 3:45 AM, agustin wrote:
> Well, I've inspected .log file and I see nothing. I've repeated the
> instalation in linux with a simple report and it the same. But I realize
> that blank screen isn't frozen but eclipse run very very slow.
> Thanks
FUDForum. Page generated in 0.05333 seconds
