Home » Eclipse Projects » EclipseLink » em.persist trigger duplicate insertion
em.persist trigger duplicate insertion [message #638162] |
Wed, 10 November 2010 09:20 |
Edmondo Messages: 11 Registered: October 2010 |
Good morning everybody,
I am currently using eclipse link 2.0 for helios and I run in this problem.
I have a Curve which has a list of security. Each security has a list of possible source of information.
package gotware.finance.curves;
import gotware.dataobject.messaging.CopiableForTransmission;
import gotware.dataobject.messaging.MessagingInformationHolder;
import gotware.factories.NotifiersFactory;
import gotware.finance.base.Security;
import gotware.finance.currency.Currency;
import gotware.interfaces.Notifier;
import gotware.messaging.MessagingConstants;
import java.io.Serializable;
import java.util.ArrayList;
import java.util.Iterator;
import java.util.List;
import javax.persistence.CascadeType;
import javax.persistence.Embedded;
import javax.persistence.Entity;
import javax.persistence.FetchType;
import javax.persistence.Id;
import javax.persistence.ManyToMany;
import javax.persistence.ManyToOne;
import javax.persistence.OneToMany;
import javax.persistence.OrderBy;
import javax.persistence.Transient;
* Entity implementation class for Entity: Curve
@Entity
public class Curve implements Serializable, CopiableForTransmission {
@Id
private String curveName;
private String description;
private static final long serialVersionUID = 1L;
@ManyToOne(cascade=CascadeType.ALL,fetch=FetchType.EAGER)
private Currency currency;
@ManyToMany(mappedBy = "associatedCurves",fetch = FetchType.EAGER, cascade = CascadeType.ALL)
private List<Security> securityList = new ArrayList<Security>();
@OneToMany(fetch=FetchType.EAGER,cascade=CascadeType.ALL,mappedBy="curve")
@OrderBy("time desc")
private List<CurvePoint> curvePoints;
@Transient
Notifier notifier;
// Real-time related data
@Embedded
MessagingInformationHolder messagingInformationHolder;
public Curve(){
super();
public Curve(List<Security> securityList) {
super();
this.securityList=securityList;
public Object cloneWithoutReferences() {
try {
Curve newCurve = (Curve) this.clone();
// Removing transient and not serializable fields
newCurve.setNotifier(null);
List<Security> securityList= newCurve.getSecurityList();
for (int i = 0; i < securityList.size(); i++) {
Security sec = securityList.get(i);
Security newSec = (Security) sec.cloneWithoutReferences();
securityList.set(i, newSec);
return newCurve;
} catch (CloneNotSupportedException e) {
e.printStackTrace();
return null;
public Currency getCurrency() {
return currency;
public String getCurveName() {
return curveName;
public List<CurvePoint> getCurvePoints() {
return curvePoints;
public String getDescription() {
return description;
public List<String> getLabels(){
// TODO This method should be overwritten by special implementation of the curve class to provide the label of the x axis of the curve
List<String> labels = new ArrayList<String>();
Iterator<Security> securityIterator = securityList.iterator();
while (securityIterator.hasNext()) {
Security security = securityIterator.next();
labels.add(security.getName());
return labels;
public MessagingInformationHolder getMessagingInformationHolder() {
return messagingInformationHolder;
public Notifier getNotifier() {
return notifier;
public List<Security> getSecurityList() {
return securityList;
public void initNotifier(){
if(messagingInformationHolder!=null){
notifier = NotifiersFactory.getDefaultNotifier(messagingInformationHolder.getConnectionFactoryName(), messagingInformationHolder.getTopicName());
public void recomputeNewCurve(){
// TODO: to be ovverridden in specific curves implementation updating values array
// This should modify curvePoints array
Iterator<Security> iterSec = securityList.iterator();
// TODO : remove this sample code
for(int i=0;i<securityList.size();i++){
Security security = securityList.get(i);
if(curvePoints.size()>i){
CurvePoint point = curvePoints.get(i);
point.setValue(security.getMarketData().getLastPrice());
public void setCurrency(Currency currency) {
this.currency = currency;
public void setCurveName(String curveName) {
this.curveName = curveName;
public void setCurvePoints(List<CurvePoint> curvePoints) {
this.curvePoints = curvePoints;
public void setDescription(String description) {
this.description = description;
public void setMessagingInformationHolder(
MessagingInformationHolder messagingInformationHolder) {
this.messagingInformationHolder = messagingInformationHolder;
initNotifier();
public void setNotifier(Notifier notifier) {
this.notifier = notifier;
public void setSecurityList(List<Security> securityList) {
this.securityList = securityList;
public void update(Security security){
recomputeNewCurve();
Curve notificationCurve = (Curve) this.cloneWithoutReferences();
notifier.notifyUpdate(MessagingConstants.MESSAGE_TYPE_GOTWARECURVE, notificationCurve);
Then I have a Security:
* To change this template, choose Tools | Templates
* and open the template in the editor.
package gotware.finance.base;
import gotware.finance.curves.Curve;
import javax.persistence.Inheritance;
import javax.persistence.InheritanceType;
import javax.validation.constraints.NotNull;
* @author porcu
@Entity
@Inheritance(strategy = InheritanceType.SINGLE_TABLE)
public abstract class Security implements Serializable,CopiableForTransmission {
@Id
protected String name;
protected String market;
protected String description;
protected int maturity;
@NotNull
@OneToMany(mappedBy = "security", fetch = FetchType.EAGER, cascade = CascadeType.ALL)
@OrderBy("priority desc")
protected List<Source> sources;
@ManyToMany(fetch = FetchType.EAGER, cascade = CascadeType.ALL)
protected List<Curve> associatedCurves;
@Transient
MarketData marketData = new MarketData();
@Transient
protected List<Source> activeSources = new ArrayList<Source>();
public Security() {
public Security(String name, String market) {
this.name = name;
this.market = market;
public Security(String name, String market, String ticker) {
this.name = name;
public Security(String name, String market, String ticker,
this.name = name;
public void addActiveSource(Source source){
activeSources.add(source);
try {
Security newSec = (Security) this.clone();
newSec.setAssociatedCurves(null);
return newSec;
return null;
public List<Curve> getAssociatedCurves() {
return associatedCurves;
return description;
public String getMarket() {
return market;
public MarketData getMarketData() {
return marketData;
public int getMaturity() {
return maturity;
public String getName() {
return name;
public List<Source> getSources() {
return sources;
public Source removeActiveSource(Source source){
if(!activeSources.remove(source)) {
return null;
return source;
public void setAssociatedCurves(List<Curve> associatedCurves) {
this.associatedCurves = associatedCurves;
public void setMarket(String market) {
public void setMarketData(MarketData marketData) {
this.marketData = marketData;
public void setMaturity(int maturity) {
this.maturity = maturity;
public void setName(String name) {
this.name = name;
public void setSources(List<Source> sources) {
this.sources = sources;
public void update() {
Iterator<Curve> curveIterator = associatedCurves.iterator();
while (curveIterator.hasNext()) {
Curve curve = curveIterator.next();
curve.update(this);
and a class Source
import javax.persistence.Column;
* Entity implementation class for Entity: Ticker
@Entity
public class Source implements Serializable {
public enum DataProvider implements Serializable {
BLOOMBERG,
REUTERS,
OTHER
@Id
private String tickerName;
@NotNull
@Column(unique=true)
private int priority=0;
@NotNull
private DataProvider dataProvider;
@ManyToOne(fetch=FetchType.EAGER)
private Security security;
@Transient
boolean active=false;
public Source() {
super();
* @param tickerName
* @param priority
* @param dataProvider
public Source(String tickerName, int priority, DataProvider dataProvider) {
super();
this.tickerName = tickerName;
this.priority = priority;
this.dataProvider = dataProvider;
* @param tickerName
* @param priority
* @param security
public Source(String tickerName, int priority, DataProvider dataProvider,
Security security) {
super();
this.security = security;
public DataProvider getDataProvider() {
return dataProvider;
public int getPriority() {
return priority;
public Security getSecurity() {
return security;
public String getTickerName() {
return tickerName;
public boolean isActive() {
return active;
public void setActive(boolean active) {
this.active = active;
public void setDataProvider(DataProvider dataProvider) {
public void setPriority(int priority) {
public void setSecurity(Security security) {
public void setTickerName(String tickerName) {
When I run the following code:
private CurvePoint createCurvePoint(int i, Curve curve){
CurvePoint curvePoint = new CurvePoint();
int index = 1230 + i+1;
curvePoint.setGotwareTicker("GOTX"+(i+1));
Calendar calendar = new GregorianCalendar(2010,i,1);
curvePoint.setTime(calendar.getTime());
curvePoint.setCurve(curve);
curvePoint.setValue(new BigDecimal(i).divide(BigDecimal.TEN,3,RoundingMode.FLOOR));
return curvePoint;
private EoniaSwap createEonia(int i){
EoniaSwap eonia1 = new EoniaSwap();
eonia1.setDescription("Daily fixing compounded over period stipulated");
eonia1.setName("Eonia " + (i+1) + " month swap");
String tickerName = "EUSWE" + (i+1) + "Z Curncy";
Source source = new Source(tickerName,0,Source.DataProvider.BLOOMBERG,eonia1);
List<Source> sources = new ArrayList<Source>();
sources.add(source);
eonia1.setSources(sources);
eonia1.setMaturity(i);
BigDecimal bigDecimal1= new BigDecimal(i).divide(BigDecimal.TEN,3,RoundingMode.FLOOR);
eonia1.getMarketData().setLastPrice(bigDecimal1);
return eonia1;
public void test(){
Currency currency = new Currency(GotwareDatabaseConstants.CURRENCY_AREA_EURO);
Curve eoniaCurve = new Curve(securityList);
MessagingInformationHolder messagingInformationHolder = new MessagingInformationHolder("/GotwareTopic/MarketData","TopicConnectionFactory");
eoniaCurve.setMessagingInformationHolder(messagingInformationHolder);
List<Curve> curves = new ArrayList<Curve>();
curves.add(eoniaCurve);
for(int k=0;k<2;k++){
EoniaSwap eoniaSwap = createEonia(k);
securityList.add(eoniaSwap);
eoniaSwap.setAssociatedCurves(new ArrayList<Curve>(curves));
//em.persist(eoniaSwap);
eoniaCurve.setCurveName("Our first curve");
eoniaCurve.setCurrency(currency);
List<CurvePoint> curvePoints = new ArrayList<CurvePoint>();
for(int k=0;k<8;k++){
CurvePoint curvePoint = createCurvePoint(k,eoniaCurve);
curvePoints.add(curvePoint);
eoniaCurve.setCurvePoints(curvePoints);
currency.setCurves(curves);
//em.persist(eoniaCurve);
em.persist(currency);
//em.flush();
I get this error:
PLUS FIN: TX beforeCompletion callback, status=STATUS_ACTIVE
PLUS FIN: begin unit of work commit
PLUS FIN: TX beginTransaction, status=STATUS_ACTIVE
LE PLUS FIN: Execute query InsertObjectQuery(gotware.finance.ois.EoniaSwap@301d54bf)
LE PLUS FIN: reconnecting to external connection pool
FIN: INSERT IGNORE INTO SECURITY (NAME, MARKET, MATURITY, DESCRIPTION, DTYPE) VALUES (?, ?, ?, ?, ?)
bind => [Eonia 2 month swap, null, 1, Daily fixing compounded over period stipulated, EoniaSwap]
LE PLUS FIN: Execute query InsertObjectQuery(gotware.finance.ois.EoniaSwap@2192bcac)
bind => [Eonia 1 month swap, null, 0, Daily fixing compounded over period stipulated, EoniaSwap]
LE PLUS FIN: Execute query InsertObjectQuery(gotware.finance.base.Source@55a6e046)
LE PLUS FIN: Execute query WriteObjectQuery(gotware.finance.ois.EoniaSwap@301d54bf)
FIN: INSERT IGNORE INTO SOURCE (TICKERNAME, DATAPROVIDER, PRIORITY, SECURITY_NAME) VALUES (?, ?, ?, ?)
bind => [EUSWE2Z Curncy, 0, 0, Eonia 2 month swap]
LE PLUS FIN: Execute query InsertObjectQuery(gotware.finance.base.Source@72afc3e8)
LE PLUS FIN: Execute query WriteObjectQuery(gotware.finance.ois.EoniaSwap@2192bcac)
bind => [EUSWE1Z Curncy, 0, 0, Eonia 1 month swap]
FIN: VALUES(1)
ATTENTION: Local Exception Stack:
Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.0.1.v20100213-r6600): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: java.sql.SQLIntegrityConstraintViolationException: The statement was aborted because it would have caused a duplicate key value in a unique or primary key constraint or unique index identified by 'SQL101109154551780' defined on 'SOURCE'.
Error Code: -1
Call: INSERT IGNORE INTO SOURCE (TICKERNAME, DATAPROVIDER, PRIORITY, SECURITY_NAME) VALUES (?, ?, ?, ?)
Query: InsertObjectQuery(gotware.finance.base.Source@72afc3e8)
at org.eclipse.persistence.exceptions.DatabaseException.sqlException(DatabaseException.java:324)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeDirectNoSelect(DatabaseAccessor.java:801)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeNoSelect(DatabaseAccessor.java:867)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.basicExecuteCall(DatabaseAccessor.java:587)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeCall(DatabaseAccessor.java:530)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeCall(AbstractSession.java:914)
at org.eclipse.persistence.internal.sessions.IsolatedClientSession.executeCall(IsolatedClientSession.java:131)
at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeCall(DatasourceCallQueryMechanism.java:205)
at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeCall(DatasourceCallQueryMechanism.java:191)
at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.insertObject(DatasourceCallQueryMechanism.java:334)
at org.eclipse.persistence.internal.queries.StatementQueryMechanism.insertObject(StatementQueryMechanism.java:162)
at org.eclipse.persistence.internal.queries.StatementQueryMechanism.insertObject(StatementQueryMechanism.java:177)
at org.eclipse.persistence.internal.queries.DatabaseQueryMechanism.insertObjectForWrite(DatabaseQueryMechanism.java:461)
at org.eclipse.persistence.queries.InsertObjectQuery.executeCommit(InsertObjectQuery.java:80)
at org.eclipse.persistence.queries.InsertObjectQuery.executeCommitWithChangeSet(InsertObjectQuery.java:90)
at org.eclipse.persistence.internal.queries.DatabaseQueryMechanism.executeWriteWithChangeSet(DatabaseQueryMechanism.java:286)
at org.eclipse.persistence.queries.WriteObjectQuery.executeDatabaseQuery(WriteObjectQuery.java:58)
at org.eclipse.persistence.queries.DatabaseQuery.execute(DatabaseQuery.java:675)
at org.eclipse.persistence.queries.DatabaseQuery.executeInUnitOfWork(DatabaseQuery.java:589)
at org.eclipse.persistence.queries.ObjectLevelModifyQuery.executeInUnitOfWorkObjectLevelModifyQuery(ObjectLevelModifyQuery.java:109)
at org.eclipse.persistence.queries.ObjectLevelModifyQuery.executeInUnitOfWork(ObjectLevelModifyQuery.java:86)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.internalExecuteQuery(UnitOfWorkImpl.java:2857)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1225)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1207)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1167)
at org.eclipse.persistence.internal.sessions.CommitManager.commitNewObjectsForClassWithChangeSet(CommitManager.java:197)
at org.eclipse.persistence.internal.sessions.CommitManager.commitAllObjectsForClassWithChangeSet(CommitManager.java:164)
at org.eclipse.persistence.internal.sessions.CommitManager.commitAllObjectsWithChangeSet(CommitManager.java:116)
at org.eclipse.persistence.internal.sessions.AbstractSession.writeAllObjectsWithChangeSet(AbstractSession.java:3260)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.commitToDatabase(UnitOfWorkImpl.java:1403)
at org.eclipse.persistence.internal.sessions.RepeatableWriteUnitOfWork.commitToDatabase(RepeatableWriteUnitOfWork.java:547)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.commitToDatabaseWithChangeSet(UnitOfWorkImpl.java:1508)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.issueSQLbeforeCompletion(UnitOfWorkImpl.java:3128)
at org.eclipse.persistence.internal.sessions.RepeatableWriteUnitOfWork.issueSQLbeforeCompletion(RepeatableWriteUnitOfWork.java:268)
at org.eclipse.persistence.transaction.AbstractSynchronizationListener.beforeCompletion(AbstractSynchronizationListener.java:157)
at org.eclipse.persistence.transaction.JTASynchronizationListener.beforeCompletion(JTASynchronizationListener.java:68)
at com.sun.jts.jta.SynchronizationImpl.before_completion(SynchronizationImpl.java:99)
at com.sun.jts.CosTransactions.RegisteredSyncs.distributeBefore(RegisteredSyncs.java:158)
at com.sun.jts.CosTransactions.TopCoordinator.beforeCompletion(TopCoordinator.java:2551)
at com.sun.jts.CosTransactions.CoordinatorTerm.commit(CoordinatorTerm.java:278)
at com.sun.jts.CosTransactions.TerminatorImpl.commit(TerminatorImpl.java:251)
at com.sun.jts.CosTransactions.CurrentImpl.commit(CurrentImpl.java:623)
at com.sun.jts.jta.TransactionManagerImpl.commit(TransactionManagerImpl.java:318)
at com.sun.enterprise.transaction.jts.JavaEETransactionManagerJTSDelegate.commitDistributedTransaction(JavaEETransactionManagerJTSDelegate.java:160)
at com.sun.enterprise.transaction.JavaEETransactionManagerSimplified.commit(JavaEETransactionManagerSimplified.java:843)
at com.sun.ejb.containers.BaseContainer.completeNewTx(BaseContainer.java:5040)
at com.sun.ejb.containers.BaseContainer.postInvokeTx(BaseContainer.java:4819)
at com.sun.ejb.containers.AbstractSingletonContainer.createSingletonEJB(AbstractSingletonContainer.java:538)
at com.sun.ejb.containers.AbstractSingletonContainer.access$100(AbstractSingletonContainer.java:74)
at com.sun.ejb.containers.AbstractSingletonContainer$SingletonContextFactory.create(AbstractSingletonContainer.java:696)
at com.sun.ejb.containers.AbstractSingletonContainer.instantiateSingletonInstance(AbstractSingletonContainer.java:444)
at org.glassfish.ejb.startup.SingletonLifeCycleManager.initializeSingleton(SingletonLifeCycleManager.java:213)
at org.glassfish.ejb.startup.SingletonLifeCycleManager.initializeSingleton(SingletonLifeCycleManager.java:174)
at org.glassfish.ejb.startup.SingletonLifeCycleManager.doStartup(SingletonLifeCycleManager.java:152)
at org.glassfish.ejb.startup.EjbApplication.start(EjbApplication.java:150)
at org.glassfish.internal.data.EngineRef.start(EngineRef.java:126)
at org.glassfish.internal.data.ModuleInfo.start(ModuleInfo.java:241)
at org.glassfish.internal.data.ApplicationInfo.start(ApplicationInfo.java:236)
at com.sun.enterprise.v3.server.ApplicationLifecycle.deploy(ApplicationLifecycle.java:339)
at com.sun.enterprise.v3.server.ApplicationLifecycle.deploy(ApplicationLifecycle.java:183)
at org.glassfish.deployment.admin.DeployCommand.execute(DeployCommand.java:272)
at com.sun.enterprise.v3.admin.CommandRunnerImpl$1.execute(CommandRunnerImpl.java:305)
at com.sun.enterprise.v3.admin.CommandRunnerImpl.doCommand(CommandRunnerImpl.java:320)
at com.sun.enterprise.v3.admin.CommandRunnerImpl.doCommand(CommandRunnerImpl.java:1176)
at com.sun.enterprise.v3.admin.CommandRunnerImpl.access$900(CommandRunnerImpl.java:83)
at com.sun.enterprise.v3.admin.CommandRunnerImpl$ExecutionContext.execute(CommandRunnerImpl.java:1235)
at com.sun.enterprise.v3.admin.CommandRunnerImpl$ExecutionContext.execute(CommandRunnerImpl.java:1224)
at com.sun.enterprise.v3.admin.AdminAdapter.doCommand(AdminAdapter.java:365)
at com.sun.enterprise.v3.admin.AdminAdapter.service(AdminAdapter.java:204)
at com.sun.grizzly.tcp.http11.GrizzlyAdapter.service(GrizzlyAdapter.java:166)
at com.sun.enterprise.v3.server.HK2Dispatcher.dispath(HK2Dispatcher.java:100)
at com.sun.enterprise.v3.services.impl.ContainerMapper.service(ContainerMapper.java:245)
at com.sun.grizzly.http.ProcessorTask.invokeAdapter(ProcessorTask.java:791)
at com.sun.grizzly.http.ProcessorTask.doProcess(ProcessorTask.java:693)
at com.sun.grizzly.http.ProcessorTask.process(ProcessorTask.java:954)
at com.sun.grizzly.http.DefaultProtocolFilter.execute(DefaultProtocolFilter.java:170)
at com.sun.grizzly.DefaultProtocolChain.executeProtocolFilter(DefaultProtocolChain.java:135)
at com.sun.grizzly.DefaultProtocolChain.execute(DefaultProtocolChain.java:102)
at com.sun.grizzly.DefaultProtocolChain.execute(DefaultProtocolChain.java:88)
at com.sun.grizzly.http.HttpProtocolChain.execute(HttpProtocolChain.java:76)
at com.sun.grizzly.ProtocolChainContextTask.doCall(ProtocolChainContextTask.java:53)
at com.sun.grizzly.SelectionKeyContextTask.call(SelectionKeyContextTask.java:57)
at com.sun.grizzly.ContextTask.run(ContextTask.java:69)
at com.sun.grizzly.util.AbstractThreadPool$Worker.doWork(AbstractThreadPool.java:330)
at com.sun.grizzly.util.AbstractThreadPool$Worker.run(AbstractThreadPool.java:309)
at java.lang.Thread.run(Thread.java:619)
Caused by: java.sql.SQLIntegrityConstraintViolationException: The statement was aborted because it would have caused a duplicate key value in a unique or primary key constraint or unique index identified by 'SQL101109154551780' defined on 'SOURCE'.
at org.apache.derby.client.am.SQLExceptionFactory40.getSQLException(Unknown Source)
at org.apache.derby.client.am.SqlException.getSQLException(Unknown Source)
at org.apache.derby.client.am.PreparedStatement.executeUpdate(Unknown Source)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeDirectNoSelect(DatabaseAccessor.java:792)
... 84 more
Caused by: org.apache.derby.client.am.SqlException: The statement was aborted because it would have caused a duplicate key value in a unique or primary key constraint or unique index identified by 'SQL101109154551780' defined on 'SOURCE'.
at org.apache.derby.client.am.Statement.completeExecute(Unknown Source)
at org.apache.derby.client.net.NetStatementReply.parseEXCSQLSTTreply(Unknown Source)
at org.apache.derby.client.net.NetStatementReply.readExecute(Unknown Source)
at org.apache.derby.client.net.StatementReply.readExecute(Unknown Source)
at org.apache.derby.client.net.NetPreparedStatement.readExecute_(Unknown Source)
at org.apache.derby.client.am.PreparedStatement.readExecute(Unknown Source)
at org.apache.derby.client.am.PreparedStatement.flowExecute(Unknown Source)
at org.apache.derby.client.am.PreparedStatement.executeUpdateX(Unknown Source)
... 86 more
This is my persistence xml
<persistence version="2.0"
xmlns="http://java.sun.com/xml/ns/persistence" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://java.sun.com/xml/ns/persistence http://java.sun.com/xml/ns/persistence/persistence_2_0.xsd">
<persistence-unit name="Gotware-jpa">
<jta-data-source>jdbc/gottexDataSource</jta-data-source>
<class>gotware.finance.ois.Ois</class>
<class>gotware.finance.ois.EoniaSwap</class>
<class>gotware.finance.fra.ForwardRateAgreement</class>
<class>gotware.finance.euribors.Euribor</class>
<class>gotware.finance.curves.Curve</class>
<class>gotware.finance.currency.Currency</class>
<class>gotware.finance.base.Security</class>
<class>gotware.finance.curves.CurvePoint</class>
<class>gotware.finance.base.Source</class>
<class>gotware.dataobject.messaging.MessagingInformationHolder</class>
<exclude-unlisted-classes>false</exclude-unlisted-classes>
<shared-cache-mode>NONE</shared-cache-mode>
<properties>
<property name="eclipselink.logging.thread" value="true" />
<property name="eclipselink.logging.timestamp" value="true" />
<property name="eclipselink.logging.exceptions" value="true" />
<property name="eclipselink.logging.connection" value="true" />
<property name="eclipselink.logging.level" value="FINEST" />
<property name="eclipselink.weaving.fetchgroups" value="true"/>
</properties>
</persistence-unit>
</persistence>
Any idea? Is there an error in how the CascadeTypes are set??
Best Regards
Edmondo Porcu
Re: em.persist trigger duplicate insertion [message #638225 is a reply to message #638162] |
Wed, 10 November 2010 15:02 |
Chris Delahunt Messages: 1389 Registered: July 2009 |
No, not a cascade setting problem. The error is saying there is a problem with the insert statement:
"INSERT IGNORE INTO SOURCE (TICKERNAME, DATAPROVIDER, PRIORITY, SECURITY_NAME) VALUES (?, ?, ?, ?)
bind => [EUSWE1Z Curncy, 0, 0, Eonia 1 month swap]" due to the 'SQL101109154551780' constraint being violated. You will need to check the database to see what the 'SQL101109154551780' constraint is, but I would check what the Source table primary keys are, and that a row with TICKERNAME = "EUSWE1Z Curncy" does not already exist, or that there aren't unique constraints on the DATAPROVIDER or PRIORITY fields.
Best Regards,
Chris
Current Time: Sat Apr 20 01:50:00 GMT 2024
Powered by FUDForum. Page generated in 0.04141 seconds
