[JSP Component] Help with generation plugin [message #638017] |
Tue, 09 November 2010 16:01 |
Toñi Reina Messages: 209 Registered: July 2009 |
--------------090005000601000705010900
Hi all,
I'm testing the JSP Component. The Discoverer, works fine, but I have
problems with the generator.
The test I'm doing is to generate a .jspxmi file from a web site.
Then, I launch a Run Configuration for Acceleo, but, unfortunately, the
only generated stuff is an empty directory with no jsp files.
I have attached a screenshot of the launch configuration to see if I'm
doing something wrong. I have tested both runners, the Acceleo Plug-in
application and the Java Application, but the result is the same, no jsp
files are generated.
To
Re: [JSP Component] Help with generation plugin [message #638182 is a reply to message #638139] |
Wed, 10 November 2010 09:56 |
thanks for your interest.
I have woven my answers between your questions
El 10/11/2010 8:38, Fabien escribió:
> your launch configuration seems to be all right (it should work whatever
> the Runner chosen).
> I will need some informations to help you:
> - first of all, does the JSP discoverer really worked fine ? --> right
> click on the .jspxmi file, and "open with ... MoDisco Model browser",
> please check there are some "Page" instances in the model.
Yes, the discoverer worked fine. I can open the .jspxmi file, and it has
pages, jsp directives, ... Furthermore, in order to check if the problem
was due to the concrete file, I also tested the .mtl file with the
org.eclipse.modisco.jee.jsp.discoverer.tests.jspxmi included in the
org.eclipse.modisco.jee.jsp.generation.tests project. So I think the
problem is not due to the concrete file.
All of them cause the same result: no file is generated.
> - when you launch the generation, have a look into the "error log" view
> to find any error message.
Before launching the generation, I delete the log and clear the log
viewer, to be sure the error messages belong to the generation. However,
after the generation (I can see the message Launching Generate Jsp at
the bottom of Eclispe), there are any error messages.
> Fabien.
Toñi
FUDForum. Page generated in 0.03335 seconds
