Home » Eclipse Projects » Eclipse Communications Framework (ECF) » ECF as TCP Socket Server ?
ECF as TCP Socket Server ? [message #637526] |
Sat, 06 November 2010 07:37  |
--------------080506030209070909040107
I'm curious if this is a use-case for ECF:
I have to manage a TCP Socket Server where a bunch of mobile devices are
using this to push informations to the server
they will then be picked up and made avalialble through server-only or
also remote OSGI services (Riena clients)
I dont know if ECF is great to be used as a TCP Socket Connection Server ?
on the other way I also have to send out data to the devices
- using email
- using web-services
- using https
which all should be no problem
so I think ECF woul be very helpful to make all of this run but I'm not
sure about the TCP Connection server - thx for all infos (or examples)
how to solve this
I'm using so many eclipse projects, so perhaps now its time to start
with ECF ;-)
ekke (ekkehard gentz)
independent software-architect
senior erp-consultant
eclipse | osgi | equinox | mdsd | oaw | emf | uml | blackberry
max-josefs-platz 30, D-83022 rosenheim, germany
mailto:ekke@ekkes-corner.org
homepage (de): http://gentz-software.de
blog (en): http://ekkes-corner.org
project lead: http://redview.org and http://red-open.org
eclipse committer: Runtime Project Riena - http://eclipse.org/riena
twitter: @ekkescorner
skype: ekkes-corner
Steuer-Nr: 156/220/30931 FA Rosenheim, UST-ID: DE189929490
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta http-equiv="content-type" content="text/html; charset=ISO-8859-15">
</head>
<body text="#000000" bgcolor="#ffffff">
I'm curious if this is a use-case for ECF:<br>
<br>
are using this to push informations to the server<br>
or also remote OSGI services (Riena clients)<br>
<br>
Server ?<br>
<br>
on the other way I also have to send out data to the devices<br>
- using email<br>
- using web-services<br>
- using https<br>
which all should be no problem<br>
<br>
not sure about the TCP Connection server - thx for all infos (or
examples) how to solve this<br>
<br>
with ECF ;-)<br>
<div class="moz-signature">-- <br>
<p style="margin-bottom: 0cm;"> <font ,="" color="#808080"
face="Verdana, sans-serif"> <font size="4">
ekke (ekkehard gentz)<br>
</font> <font size="3"> independent software-architect<br>
senior erp-consultant<br>
</font> <font size="2">
blackberry<br>
max-josefs-platz 30, D-83022 rosenheim, germany<br>
<a class="moz-txt-link-freetext" href="mailto:ekke@ekkes-corner.org">mailto:ekke@ekkes-corner.org</a><br>
homepage (de): <a class="moz-txt-link-freetext" href="http://gentz-software.de">http://gentz-software.de</a><br>
blog (en): <a class="moz-txt-link-freetext" href="http://ekkes-corner.org">http://ekkes-corner.org</a><br>
project lead: <a class="moz-txt-link-freetext" href="http://redview.org">http://redview.org</a> and <a class="moz-txt-link-freetext" href="http://red-open.org">http://red-open.org</a><br>
<a class="moz-txt-link-freetext" href="http://eclipse.org/riena">http://eclipse.org/riena</a><br>
twitter: @ekkescorner<br>
skype: ekkes-corner<br>
</font> <font size="1"> Steuer-Nr: 156/220/30931 FA
Rosenheim, UST-ID: DE189929490<br>
</font> </font> </p>
</div>
</body>
</html>
--------------080506030209070909040107--
ekke
independent software architect
blog: http://ekkes-corner.org
Re: ECF as TCP Socket Server ? [message #637724 is a reply to message #637587] |
Mon, 08 November 2010 13:42   |
--------------020402000604020902010307
Am 07.11.10 12:36, schrieb Markus Alexander Kuppe:
>> - using email
>> - using https
>> how to solve this
> I guess to answer your questions, more details about the application are
> needed. As far as I understand it, non-OSGi mobile clients are supposed
> to communicate with an OSGi runtime over a TCP socket.
are there any examples where ECF is interacting using TCP Sockets ?
> Access to the
> same data should be made available via OSGi remote services. There are
> also going to be secondary communication channel
> (asynchronous/synchronous) to communicate with the mobile clients.
> Why do you need the secondary channels? Why not use asynchronous
> communication for all interactions between the OSGi runtime and the
> mobile clients?
I'm working on a server receiving infos from mobile clients
and also pushing infos out to mobile clients
the ways how to transport the data differ from the mobile platform
per ex. integrating BlackBerry (thats what I'm working on as first)
if data was pushed to the devices this must be done using BlackBerry
infrastructure
and I can use the BIS (BlackBerry Internet Service) using https
or if customer has a BES (BlackBerry Enterprise Server) using webservices
such push-data is only about small-sized text pushes - and BB will
deliver them with guarantee to the end device
then - depending from the kind of information pushed - the device
connects thru http / https to a webserver to get the data in detail
or - the data was sent using email attachment where I also can rely on
the BB infrastructure
there are other use-cases (logging) where devices can log thru tcp
socket to a logserver (in my case a Lilith Logmonitor)
on other platforms communication ways are different because there's
nothing like a BB PushService with guaranteed delivery available
> Can you detail what the Riena clients are supposed to do?
I'm always using Riena RCP (RAP) clients for my enterprise business
applications if I need a rich client
there are usecases where such a rich client sends information to the
server thru OSGI service causing the server to push to mobile devices
and/or to provide more data
>> with ECF ;-)
> It's always the right time to start with ECF. ;-)
if there would be an example how an ECF server could interact with TCP
Socket connections this would be great
ekke
> Markus
skype: ekkes-corner
<html>
<head>
<meta content="text/html; charset=ISO-8859-15"
http-equiv="Content-Type">
</head>
<blockquote cite="mid:ib62o2$slk$1@news.eclipse.org" type="cite">
<pre wrap="">On 11/06/2010 08:37 AM, ekke wrote:
</pre>
<blockquote type="cite">
<pre wrap="">I'm curious if this is a use-case for ECF:
- using email
- using https
how to solve this
</pre>
</blockquote>
<pre wrap="">
to communicate with an OSGi runtime over a TCP socket. </pre>
</blockquote>
are there any examples where ECF is interacting using TCP Sockets ?<br>
<pre wrap="">Access to the
mobile clients? </pre>
</blockquote>
I'm working on a server receiving infos from mobile clients<br>
and also pushing infos out to mobile clients<br>
<br>
the ways how to transport the data differ from the mobile platform<br>
<br>
per ex. integrating BlackBerry (thats what I'm working on as first)<br>
infrastructure<br>
and I can use the BIS (BlackBerry Internet Service) using https<br>
webservices<br>
<br>
deliver them with guarantee to the end device<br>
<br>
connects thru http / https to a webserver to get the data in detail<br>
on the BB infrastructure<br>
<br>
socket to a logserver (in my case a Lilith Logmonitor)<br>
<br>
--<br>
nothing like a BB PushService with guaranteed delivery available<br>
<pre wrap="">Can you detail what the Riena clients are supposed to do?
</pre>
</blockquote>
applications if I need a rich client<br>
devices and/or to provide more data<br>
<pre wrap=""></pre>
<pre wrap="">I'm using so many eclipse projects, so perhaps now its time to start
with ECF ;-)
</pre>
</blockquote>
<pre wrap="">
</pre>
</blockquote>
TCP Socket connections this would be great<br>
<br>
ekke<br>
<pre wrap="">
Markus
</pre>
</blockquote>
<br>
<br>
blackberry<br>
</div>
</body>
</html>
--------------020402000604020902010307--
ekke
Re: ECF as TCP Socket Server ? [message #637725 is a reply to message #637724] |
Mon, 08 November 2010 14:45   |
--------------010104090705010408050800
Am 08.11.10 14:42, schrieb ekke:
>>> - using email
>>> - using https
>>> how to solve this
>> Access to the
>> mobile clients?
> infrastructure
forgot to mention that the other way around where the mobile device (BB)
sends informations to the server
(like "arrived at customer site" or GPS coordinates)
in many of these cases a TCP Socket connection was used
but perhaps to send an image or video this was sent using email w
attachment to the server - its easier to handle because then BB does
solve all the problems which could happen sending large files from
mobile device
>>> with ECF ;-)
> ekke
>> Markus
skype: ekkes-corner
<html>
<head>
</head>
<blockquote cite="mid:ib8uh3$euc$1@news.eclipse.org" type="cite">
</pre>
- using email
- using https
how to solve this
</pre>
</blockquote>
<pre wrap="">I guess to answer your questions, more details about the application are
</blockquote>
?<br>
</blockquote>
<br>
<br>
first)<br>
BlackBerry infrastructure<br>
webservices<br>
<br>
<br>
detail<br>
rely on the BB infrastructure<br>
<br>
<br>
</blockquote>
(BB) sends informations to the server<br>
(like "arrived at customer site" or GPS coordinates)<br>
in many of these cases a TCP Socket connection was used<br>
mobile device<br>
<blockquote cite="mid:ib8uh3$euc$1@news.eclipse.org" type="cite"> --<br>
there's nothing like a BB PushService with guaranteed delivery
available<br>
</pre>
</blockquote>
business applications if I need a rich client<br>
the server thru OSGI service causing the server to push to mobile
with ECF ;-)
</pre>
</blockquote>
<pre wrap="">It's always the right time to start with ECF. ;-)
</pre>
</blockquote>
<br>
ekke<br>
<pre wrap="">Markus
</pre>
</blockquote>
<br>
</blockquote>
<br>
blackberry<br>
</div>
</body>
</html>
--------------010104090705010408050800--
ekke
Re: ECF as TCP Socket Server ? [message #637785 is a reply to message #637526] |
Mon, 08 November 2010 20:29   |
Scott Lewis Messages: 1038 Registered: July 2009 |
Hi Ekke,
The short answer is 'yes', ECF does have a TCP socket server.
Longer Answer: ECF has what we call a 'generic' provider, that's based upon TCP sockets. Specifically, the class implementing this is in this bundle: org.eclipse.ecf.provider, with this class name:
org.eclipse.ecf.provider.generic.TCPServerSOContainer
We use this provider for lots of things...e.g. it supports remote services, shared object api, datashare api (messaging channels), and others. There is also another bundle, specifically for using the ECF generic server as a server: org.eclipse.ecf.server.generic. This has some IApplication impl classes for starting/running ECF generic servers as OSGi applications.
Further, I've personally done some work on using remote services to manage ECF generic servers...i.e. to create/start/stop new TCPServerSOContainers at runtime. If you are interested in this please contact me directly at slewis at composent.com.
Note one thing...it's also possible to run the ECF generic provider client and/or server *outside* of an OSGi runtime context...e.g. for running on blackberry, android, or some other types of clients.
Re: ECF as TCP Socket Server ? [message #637787 is a reply to message #637785] |
Mon, 08 November 2010 20:33   |
Hi Ekke,
I forgot to mention: it's also completely possible to create your own provider...i.e. your own TCP socket-based implementation...i.e. either based upon the ECF generic stuff or from scratch. Then can use/reuse other parts of ECF (i.e. implement only some of the ECF apis...only the ones you care about for your particular use case).
Scott
Scott Lewis wrote on Mon, 08 November 2010 15:29 | Hi Ekke,
Re: ECF as TCP Socket Server ? [message #637899 is a reply to message #637787] |
Tue, 09 November 2010 09:46  |
--------------050809060908010500020507
hi scott,
sounds good :)
....will take a look at this next days
ekke
Am 08.11.10 21:33, schrieb Scott Lewis:
> Hi Ekke,
> Scott
>> Hi Ekke,
skype: ekkes-corner
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
<title></title>
</head>
hi scott,<br>
<br>
sounds good :)<br>
...will take a look at this next days<br>
<br>
ekke<br>
<br>
<blockquote cite="mid:ib9mkd$mqm$1@news.eclipse.org" type="cite">Hi
Ekke,
<br>
<br>
<br>
<br>
Scott
<br>
<br>
<br>
<br>
<br>
<br>
<blockquote type="cite">Hi Ekke,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
applications.
<br>
<br>
<br>
<br>
types of clients.
<br>
</blockquote>
<br>
<br>
</blockquote>
<br>
<br>
blackberry<br>
</div>
</body>
</html>
--------------050809060908010500020507--
ekke
Current Time: Thu Jan 21 22:28:42 GMT 2021
Powered by FUDForum. Page generated in 0.02829 seconds
