When using custom config.ini file, product export doesn't create bundles.info [message #637470] |
Fri, 05 November 2010 17:06 |
Ryan Messages: 74 Registered: July 2009 Location: Indiana |
Member |
I've got a product definition that uses a custom config.ini, and on an export, the bundles.info file is not generated. If I select "Generate a default config.ini file", the export does create the required bundles.info. Here's the part I don't understand, if I use that generated config.ini as a custom config.ini, it doesn't make the bundles.info file. So, how do I get the product export to create the bundles.info file when using a custom config.ini file?
Other than changing the config.ini setting, the .product file does not change between exports.
contents of generated config.ini, which I used as a custom config.ini (actual file has correct application, product and splash names/paths)
#Product Runtime Configuration File
eclipse.application=%Application%
osgi.bundles.defaultStartLevel=4
eclipse.product=%Product%
osgi.splashPath=platform:/base/plugins/%splashplugin%
osgi.bundles=org.eclipse.equinox.simpleconfigurator@1:start
org.eclipse.equinox.simpleconfigurator.configUrl=file:org.eclipse.equinox.simpleconfigurator/bundles.info
Edit:
We also use PDE build in a headless fashion and the same problem happens there as well. Using a custom config.ini that is the same as the generated one, the bundles.info isn't generated. But using the option in the .product file to generate the config.ini, the bundles.info is created.
Edit2:
My main build is done using 3.5.2, but i just tried the export with 3.6.1 (still using my 3.5.2 target) and I got the same issue. I also tried creating a new branding plugin from scratch with new .product files and the observed the same issue. On our headless build, it'll be easy to just copy over the config.ini that I need, but quite a bit more pain when an exporting from the GUI.
[Updated on: Fri, 05 November 2010 21:18] Report message to a moderator
Re: When using custom config.ini file, product export doesn't create bundles.info [message #637564 is a reply to message #637470] |
Sat, 06 November 2010 18:05 |
Member |
Bug report here: https://bugs.eclipse.org/bugs/show_bug.cgi?id=329616
Looks like in the ProductGenerator classes generate() method
//configuration/config.ini
String custom = findConfigFile(productFile, config.getOs());
if (custom != null) {
try {
Utils.copyFile(custom, rootLocation + "/configuration/config.ini"); //$NON-NLS-1$
} catch (IOException e) {
//ignore
} else {
createConfigIni(config, rootLocation);
So if you've specified a custom config, createConfigIni() is not called in generate()
So this block of code in createConfigIni() is never executed:
if ((configStyle & CONFIG_STYLE_SIMPLE) > 0) {
printSimpleBundles(buffer, config, configDir, configStyle);
} else {
//When update configurator is present or when feature based product
if ((configStyle & CONFIG_STYLE_UPDATE) > 0) {
printUpdateBundles(buffer, configStyle);
} else {
printAllBundles(buffer, config, configStyle);
Its the printSimpleBundles() call that generates the bundles.info file.
[Updated on: Sat, 06 November 2010 19:48] Report message to a moderator
FUDForum. Page generated in 0.03528 seconds
