Strange pause/lockup in HTML editor [message #637193] |
Thu, 04 November 2010 14:40 |
Chris Gage Messages: 74 Registered: July 2009 |
Member |
I have noticed a strange behavior in the HTML editor, and was able to find a case where it does not happen, and where it happens consistently ...
If I create a new HTML file with the 'new' wizard, and simply click 'finish' after naming it, I get a minimal default HTML file in the editor. If I then move the cursor to after the body tag and type <h3> I get what I expect which is <h3></h3>
If, however after naming the html file I press 'next' and select 'HTMl 4.01 Strict', and click 'Finish' and then do the same as before, ie type <h3> - something very different happens. After I type the 'h' character, Eclipse hangs - without apparently using any CPU - and completely blocks the UI for about 30-45 seconds - and then proceeds as normal. This only seems to happen the first time for each editing session on that file, after that it works OK. If I save and close the file, and then re-edit it, the first time I enter <h I get the same 30-45 second hang.
Can anyone explain this?
FUDForum. Page generated in 0.02072 seconds
