Re: Property Expansion for Environment Variables [message #637094 is a reply to message #637039] |
Thu, 04 November 2010 07:29 |
I guess we could do it similar to how ant does it. I.e. ${env:someEnv} or perhaps even better, as Eclipse 'variables',
${env_var:someEnv}. The class where everything happens is name ExpandingProperties.
- thomas
On 11/03/2010 10:51 PM, Johannes Utzig wrote:
> I'm currently working on fixing
> http://issues.hudson-ci.org/browse/HUDSON-7978 for the Hudson plugin.
> I want to avoid to write ALL environment variables as JVM properties in
> the command line because that would get huge. However, all necessary
> values are set as environment variables of the buckminster process.
> Is there currently a way to have properties replaced by environment
> variables?
> If not, what's your opinion in including envVars into the property
> expansion?
> Best regards,
> Johannes
Re: Property Expansion for Environment Variables [message #637525 is a reply to message #637267] |
Sat, 06 November 2010 07:20 |
Hi Johannes,
There are two ways of resolving this. Either you add all properties to the property sets that you want to use like you
suggest, or you let the ExpandingProperties recognize the ${env_var: prefix}. The advantage with the former is that it
is simple and that the environment is included when iterating over the keys in the map. The advantage of the latter is
that it will keep the map small (there's some copying going on) and is in line with current Eclipse functionality. My
vote is on the latter because the use of env_var is uncommon (you're the first one asking for it the four years
Buckminster has been active ;-) ) and we might have an urge to enable more prefixes.
Perhaps we should even consider having the ExpandingProperties consult the Eclipse property expander when we encounter a
prefix? That way all the eclipse specific properties would work. What do you think?
- thomas
On 11/04/2010 07:19 PM, Johannes Utzig wrote:
> Hi again,
> I was having a look at the sources and was wondering what's the right
> place to add these environment variables.
> Would the static initializer of the RMContext be sufficient? It creates
> the staticAdditions for the globalPropertyAdditions.
> I was thinking of adding something like this to the initializer:
> Map<String, String> env = System.getenv();
> for (Entry<String, String> environmentVariable : env.entrySet()) {
> additions.put("env_var:" + environmentVariable.getKey(),
> environmentVariable.getValue()); //$NON-NLS-1$
> Would that be the right place and right way to enable environment
> variables for script files?
> Best regards,
> Johannes
Re: Property Expansion for Environment Variables [message #637570 is a reply to message #637525] |
Sat, 06 November 2010 23:53 |
Johannes Utzig Messages: 329 Registered: July 2009 |
Hi Thomas,
please see comments below
Am 06.11.2010 08:20, schrieb Thomas Hallgren:
> Hi Johannes,
> the property sets that you want to use like you suggest, or you let the
> the former is that it is simple and that the environment is included
> in line with current Eclipse functionality. My vote is on the latter
> it the four years Buckminster has been active ;-) ) and we might have an
> the Eclipse property expander when we encounter a prefix? That way all
> - thomas
What you say makes a lot of sense to me. Also consulting the Eclipse
property expander makes it very easy for users to contribute completely
new kinds of (dynamic) properties by creating an extension for
org.eclipse.core.variables.(dynamic/static)Variables and therefore
participating with very little effort in the buckminster property
expansion process.
The env_var prefix is contributed by org.eclipse.debug.core which is
part of a regular buckminster installation anyway, so no additional
bundles would be required for the desired functionality.
So far so good, but there's a few things I'm a little uncertain about:
1. API consistency
ExpandingProperties is often regarded as a simple Map from what I can
see in the source. Consulting the StringVariableManager during the
expansion but ignoring it during the other API methods might behave a
little inconsistent for API consumers. E.g.
"keySet() doesn't return my env_var:FOOBAR but 'expand' replaces the
value just fine"
Including the new variable scope in all methods might on the other hand
negate the advantage of keeping the map small.
2. The implementation
Using the StringVariableManager seems straight forward enough:
VariablesPlugin.getDefault().getStringVariableManager().perf ormStringSubstitution(expression,
false);
But ExpandingProperties is one of the core classes of Buckminster. It's
widely used and it seems a rather sophisticated implementation to me.
However, there don't seem to be any real unit tests in place for this
and I'm somewhat concerned of what I could break if include the
StringVariableManager there. Especially if you prefer to not only
include it in the property expansion, but keep the API consistent with
the new property scopes (because that'd mean to adjust quite a few of
the methods at once).
To wrap it up:
If you think env_vars and custom vars are corner cases and the Eclipse
mechanism should only be consulted during the actual expansion but
ignored in all other methodes, then I'd assume my changes should be made
around here in ExpandingProperties#checkedExpand :
Object propVal = (props instanceof ExpandingProperties<?>) ?
((ExpandingProperties<?>) props).getExpandedProperty(propKey,
recursionGuard + 1) : props.get(propKey);
But if you'd prefer that the other methods also include the additional
variable scopes for sake of consistency, then I'm afraid I'll need some
advice on how to apply the changes without breaking any of the classes
that depend on ExpandingProperties :-/
Johannes
Re: Property Expansion for Environment Variables [message #637576 is a reply to message #637570] |
Sun, 07 November 2010 08:16 |
On 11/07/2010 12:53 AM, Johannes Utzig wrote:
> To wrap it up:
I do, since you have no way of finding all the Eclipse variables. You will find several prefixes similar to
workspace_loc where ${workspace_loc:xxx} may resolve to all resources in your workspace depending on the value of xxx.
Adding everything to a map would thus make that map very big. I don't think that's feasible.
I think that the solution should focus on:
T getExpandedProperty(String key, int recursionGuard) {
return convertValue(map.get(key), recursionGuard);
If map.get(key) returns null then try the eclipse variable.
- thomas
FUDForum. Page generated in 0.02803 seconds
