Home » Eclipse Projects » Eclipse Platform » eclipse helios crashing and crashing (i am using eclipse helios and it get crashed few mintues after i start working please help me out )
eclipse helios crashing and crashing [message #636603] Tue, 02 November 2010 07:46 Go to next message
vicky  is currently offline vicky Friend
here is my eclipse.ini
-startup
plugins/org.eclipse.equinox.launcher_1.1.0.v20100507.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.win32.win32.x86_1.1.0.v 20100503
-product
org.eclipse.epp.package.jee.product
--launcher.defaultAction
openFile
--launcher.XXMaxPermSize
1024M
-showsplash
org.eclipse.platform
1024M
openFile
-vmargs
-Dosgi.requiredJavaVersion=1.5
-Xms40m
-Xmx512m
i have increased permgen space to 1024m but still no use i am unable to use it
Re: eclipse helios crashing and crashing [message #636604 is a reply to message #636603] Tue, 02 November 2010 07:56 Go to previous messageGo to next message
Animesh Kumar is currently offline Animesh KumarFriend
Member
Try using the following as your VM argumesnts:-
-Xmx512m
-Xms128m
-XX:PermSize=32m
-XX:MaxPermSize=384m
This would prevent the permgen space error, which i think is the reason for crashing of your IDE.
Hope this helps.
Animesh
Re: eclipse helios crashing and crashing [message #636605 is a reply to message #636604] Tue, 02 November 2010 07:58 Go to previous messageGo to next message
should i change it in eclipse.ini?
Re: eclipse helios crashing and crashing [message #636608 is a reply to message #636605] Tue, 02 November 2010 08:01 Go to previous messageGo to next message
Member
You can do that in Debug Configurations or Run Configurations in Eclipse. That would do.
In the main menu Run -> Run Configurations-> Arguments tab in it. You can change the VM Arguments there.
These values will automatically get reflected in the eclipse.ini
Animesh
[Updated on: Tue, 02 November 2010 08:05]
Report message to a moderator
Re: eclipse helios crashing and crashing [message #636611 is a reply to message #636608] Tue, 02 November 2010 08:27 Go to previous messageGo to next message
Mauro Molinari is currently offline Mauro MolinariFriend
No, it would not. To make those arguments be passed to the VM running
Eclipse itself, they have to be put in eclipse.ini or passed to
eclipse.exe on the command line.
To Vicky: are you using Sun's JRE 1.6.0_21 to run Eclipse? If so,
re-download and re-install it or upgrade to 1.6.0_22, since the bundle
originally released for 1.6.0_21 had a problem with the Oracle
re-branding that prevented Eclipse to recognize that VM as a Sun one, so
the permgen parameter as specified by --launcher.XXMaxPermSize 1024M in
eclipse.ini didn't work.
See: https://bugs.eclipse.org/bugs/show_bug.cgi?id=319514
Mauro.
Re: eclipse helios crashing and crashing [message #636657 is a reply to message #636608] Tue, 02 November 2010 11:06 Go to previous message
thanks
Previous Topic:Security Applet Alert in Eclipse
Next Topic:working with WS-BPEL with eclipse and maven
Current Time: Fri Mar 05 08:30:34 GMT 2021
Powered by FUDForum. Page generated in 0.02713 seconds
