Re: plug-in will not reinstall [message #636487 is a reply to message #636367] |
Mon, 01 November 2010 14:52 |
On 2010.10.31 11:22, Rick wrote:
> I'm using the Blackberry JDE plugin with Eclipse 3.5. One of the
> simulators had a problem so I removed it using the "Help -> Install New
> Software" menu. However, now it will not reinstall. Eclipse is "acting"
> like it is expecting the presence of a file or directory when it doesn't
> appear that anything has been done.
> [snip]
> Any pointers would be appreciated. Thanks.
My suggestion would be to get another copy of Eclipse and start over
installing the BlackBerry plug-in set which is very (and apparently
totally) intrusive. As I don't attempt to do anything else but
BlackBerry with my BlackBerry Eclipse, this solution works for me. I
keep my Android and JEE Eclipse work separate too, so I usually have 3
or 4 ('cause I also like to do a few things with a separate Helios
install too which in theory won't work for Android) around on each
development host I use.
Hope this comment is somewhat helpful.
FUDForum. Page generated in 0.07589 seconds
