Re: itemProviderAdapterFactories [message #636386 is a reply to message #636359] |
Sun, 31 October 2010 22:36 |
Ed Merks Messages: 33140 Registered: July 2009 |
Mike,
Unfortunately we don't yet support merging of the plugin.xml so either
you add things manually, or you delete it and regenerate it. Of course
if you have things under source code control. (how could you not?) you
should be able to merge in your own changes quite painlessly...
Michael Spertus wrote:
> Thanks for the response, Ed. Following your advice, I was able to fix
> the problem by deleting plugin.xml and regenerating. Do I only need to
> delete and regenerate the xxx.edit plugin.xml when I add packages to
> my model, or should I delete all of them?
> Unfortunately, I customize the generated plugin.xml, so deleting,
> regenerating, and recustomizing is painful. Is there a recommended
> way of handling this?
> Thanks again,
> Mike
Ed Merks
FUDForum. Page generated in 0.03221 seconds
