Re: IllegalAccessError when using JNDI Url on Birt 2.5.1 [message #635693 is a reply to message #635549] |
Wed, 27 October 2010 17:55 |
Hector,
Where is the driver when you have the issue? In the drivers directory
of the JDBC plugin?
Jason
On 10/27/2010 6:19 AM, Hector Moneo wrote:
> Our application is relying on Birt 2.5.1 runtime for the report
> generation. We are in the process of moving from JDBC to JNDI
> as the connection method for the Birt datasource. The JNDI url is set on
> run time using the reportContext. We have come across the DB drivers
> cannot be loaded into the same classpath as Birt runtime, since we are
> getting IllegalAccessError when BIRT is internally preparing the sql
> Statement. The problem does not happen if the DB driver is loader in a
> higher classpath, i.e.
> at the Application Server level.
> This behaviour seems neither DB ( with Oracle, SQL Server and DB2 we are
> always getting IllegalAccessException) nor Application
> Server related (we get the same results on Tomcat 6.0 and WAS 7.0) Our
> application is using App. Server pooling and we have never come across
> this problem, so it does not either seem to be an application issue.
> So basically I would like to understand why it is happenning and if
> there is a better way of fixing the issue than loading the drivers at
> the application server classpath.
> I attach an stack trace of the problem when testing on tomcat 6 and SQL
> Server.
> If you need further information, plese let me know. Best regards,
> Hector
> --------------------------------- Stack trace
> Caused by: java.lang.IllegalAccessError: tried to access method
> com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.<init >
> (Lcom/microsoft/sqlserver/jdbc/SQLServerConnection;Ljava/lan
> g/String;II)V from class com.microsoft.sqlserver.jdbc.SQLServerConnection
> at com.microsoft.sqlserver.jdbc.SQLServerConnection.prepareStat
> ement(SQLServerConnection.java:1864)
> ement(SQLServerConnection.java:1566)
> at org.apache.tomcat.dbcp.dbcp.DelegatingConnection.prepareStat
> ement(DelegatingConnection.java:248)
> at org.apache.tomcat.dbcp.dbcp.PoolingDataSource$PoolGuardConne
> ctionWrapper.prepareStatement(PoolingDataSource.java:302)
> at org.eclipse.birt.report.data.oda.jdbc.Statement.prepare(Stat
> ement.java:142)
> at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQu
> ery.doPrepare(OdaQuery.java:229)
> ery.prepare(OdaQuery.java:186)
> at org.eclipse.birt.data.engine.odaconsumer.Connection.prepareO
> daQuery(Connection.java:281)
> at org.eclipse.birt.data.engine.odaconsumer.Connection.prepareS
> tatement(Connection.java:181)
> at org.eclipse.birt.data.engine.executor.DataSource.prepareStat
> ement(DataSource.java:269)
> at org.eclipse.birt.data.engine.executor.DataSourceQuery.prepar
> e(DataSourceQuery.java:270)
> at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery$OdaDSQu
> eryExecutor.prepareOdiQuery(PreparedOdaDSQuery.java:350)
> at org.eclipse.birt.data.engine.impl.QueryExecutor.prepareExecu
> tion(QueryExecutor.java:337)
> at org.eclipse.birt.data.engine.impl.PreparedQuery.doPrepare(Pr
> eparedQuery.java:448)
> at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.pr
> oduceQueryResults(PreparedDataSourceQuery.java:190)
> at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.ex
> ecute(PreparedDataSourceQuery.java:178)
> at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery.execute
> (PreparedOdaDSQuery.java:144)
> at org.eclipse.birt.report.data.adapter.impl.DataRequestSession
> Impl.execute(DataRequestSessionImpl.java:511)
> at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExec
> uteQuery(DteDataEngine.java:145)
> at org.eclipse.birt.report.engine.data.dte.DataGenerationEngine
> .doExecuteQuery(DataGenerationEngine.java:71)
> at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.e
> xecute(AbstractDataEngine.java:254)
> at org.eclipse.birt.report.engine.executor.ExecutionContext.exe
> cuteQuery(ExecutionContext.java:1818)
> at org.eclipse.birt.report.engine.executor.QueryItemExecutor.ex
> ecuteQuery(QueryItemExecutor.java:80)
> at org.eclipse.birt.report.engine.executor.TableItemExecutor.ex
> ecute(TableItemExecutor.java:62)
> at org.eclipse.birt.report.engine.internal.executor.wrap.Wrappe
> dReportItemExecutor.execute(WrappedReportItemExecutor.java:4 6)
> at org.eclipse.birt.report.engine.internal.executor.emitter.Rep
> ortItemEmitterExecutor.execute(ReportItemEmitterExecutor.jav a:46)
> at org.eclipse.birt.report.engine.internal.executor.dup.Suppres
> sDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor .java:43)
> at org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking
> LM.layoutNodes(HTMLBlockStackingLM.java:65)
> at org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.la
> youtChildren(HTMLStackingLM.java:26)
> at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.la
> yout(HTMLAbstractLM.java:137)
> at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackin
> gLM.resumeLayout(HTMLInlineStackingLM.java:111)
> gLM.layoutNodes(HTMLInlineStackingLM.java:160)
> LM.layoutNodes(HTMLBlockStackingLM.java:70)
> at org.eclipse.birt.report.engine.layout.html.HTMLTableLM.layou
> tChildren(HTMLTableLM.java:132)
> at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout
> (HTMLPageLM.java:90)
> at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE
> ngine.layout(HTMLReportLayoutEngine.java:99)
> at org.eclipse.birt.report.engine.presentation.ReportDocumentBu
> ilder.build(ReportDocumentBuilder.java:258)
> at org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTas k.java:243)
> ... 24 more
Re: IllegalAccessError when using JNDI Url on Birt 2.5.1 [message #635910 is a reply to message #635811] |
Thu, 28 October 2010 14:48 |
Hector,
Can you try setting the jdbc driver classpath in the application context
config.getAppContext().put("OdaJDBCDriverClassPath",
"c:/birt/mysql/mysql-connector-java-5.0.4-bin.jar");
Jason
On 10/28/2010 4:26 AM, Hector Moneo wrote:
> We tested with different scenarios:
> * Placing the driver in the plugin directory and we got the the
> IllegalAccessError
> * Placing the driver on the application WAR lib directory (WEB-INF\lib)
> and we got the same error
> * Placing the driver on an external location, and loading it to the app
> server classpath on the startup server script (This is the solution
> which worked).
> i.e. for Tomcat we modified the "setclasspath.bat" so we added the
> following line:
> SET CLASSPATH=%CLASSPATH%;D:\lib\SQLServerDriver.jar;
> The "setclasspath.bat" is executed when starting the server
> Regards,
> Hector
Re: IllegalAccessError when using JNDI Url on Birt 2.5.1 [message #636995 is a reply to message #636899] |
Wed, 03 November 2010 16:52 |
Hector,
I can not reproduce the error. Any chance you can open a bug for this?
Jason
On 11/3/2010 5:29 AM, Hector Moneo wrote:
> Hi Jason,
> I tried
> config.getAppContext().put(EngineConstants.APPCONTEXT_CLASSL OADER_KEY,
> YourClassThatLoadsTheEngine.class.getClassLoader());
> but got the same IllegalAccessError
> Regards,
> Hector
FUDForum. Page generated in 0.04581 seconds
