Home » Modeling » M2T (model-to-text transformation) » Java Indexer running unnecessarily(Indexing directories not related to any project)
Java Indexer running unnecessarily [message #635022] Mon, 25 October 2010 12:50 Go to next message
Mark Hagan is currently offline Mark HaganFriend
I am running eclipse Galileo which is often very slow. I see in the following example event details in error log view which may be one contributing factor:-
"The Java indexing could not index V:/weblogic-10.3.2.0/modules/com.bea.core.repackaged.springf ramework.spring_1.0.0.0_2-5-3.jar|com/bea/core/repackaged/sp ringframework/transaction/annotation/Transactional.class. This .class file doesn't follow the class file format specification. Please report this issue against the .class file vendor"
This path is not on the build path or mentioned in any workspace project. Why is eclipse going through these dirs? Is there any way to stop it? I have many dirs on this V:\ drive that are not relevant to eclipse and I do not want eclipse wasting time indexing them.
Re: Java Indexer running unnecessarily [message #635024 is a reply to message #635022] Mon, 25 October 2010 12:52 Go to previous messageGo to next message
Sorry this has been put in the wrong forum. I thought I was in JDT. Can this be moved there or do I have to repost?
Re: Java Indexer running unnecessarily [message #635194 is a reply to message #635022] Mon, 25 October 2010 22:31 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
I guess this question was raised in the wrong newsgroup.
Am 25.10.10 14:50, schrieb Mark Hagan:
Re: Java Indexer running unnecessarily [message #635245 is a reply to message #635194] Tue, 26 October 2010 07:42 Go to previous messageGo to next message
Dani Megert is currently offline Dani MegertFriend
Eclipse is not going through directories. The JAR is most likely on your
build path. If not directly then indirectly via a MANIFEST.MF entry in
one of the directly referenced JARs.
Dani
>> Is there any way to
Re: Java Indexer running unnecessarily [message #635268 is a reply to message #635245] Tue, 26 October 2010 08:47 Go to previous message
Thanks Dani. Yes that's what it turned out to be. I stripped the build path right down and it seemed to perform a bit better with less errors in the log.
Previous Topic:[Acceleo] Can Acceleo support @text-explicit syntax ?
Next Topic:[Acceleo 3 / Helios] Cannot lauch transformation
Current Time: Wed Oct 20 11:33:03 GMT 2021
Powered by FUDForum. Page generated in 0.01574 seconds
