How to contribute configurations programmatically [message #634807] |
Sat, 23 October 2010 18:49  |
Hi to all,
I have to contribute some preconfigured eclipse-versions for the developers of our company.
So I looked for a possibility to configure for things like:
-CodeFormatting
-JDK-Settings
-Show heapmonitor
-Configuring CVS-Servers
and many others.
I developed plugins and headless applications to config and create distributions and establish an mirror in our intranet.
Actually I do some configurations just by editing property-files in the .metadata-path, but I'm not very happy with it, because if these configurations change, I don't notice and I guess not all configurations are possible with this technique
Would be better to use a API for this, but I didn't find anything I can use. Didn't I search at the right place?
What way should I go to preconfigure these settings?
Hope you can help me,
best regards
Markus
Re: How to contribute configurations programmatically [message #635420 is a reply to message #635018] |
Tue, 26 October 2010 17:50   |
Hi Paul,
thank you for your answer.
I have still questions:
Can you please give me a hint, were I can find all items I can configure with this solution?
Is this a feature save technique or may the settings be incompatible changed in following releases?
I guess it's very similar to my solution, only difference is that my changes are noticed after eclipse restarts and has to be done manually at each workspace - is there any further difference?
Thanks in advance
Best regards
Markus
FUDForum. Page generated in 0.02248 seconds
