Home » Eclipse Projects » Eclipse Platform » How to contribute configurations programmatically
How to contribute configurations programmatically [message #634807] Sat, 23 October 2010 18:49 Go to next message
Markus Oley is currently offline Markus OleyFriend
Hi to all,
I have to contribute some preconfigured eclipse-versions for the developers of our company.
So I looked for a possibility to configure for things like:
-CodeFormatting
-JDK-Settings
-Show heapmonitor
-Configuring CVS-Servers
and many others.
I developed plugins and headless applications to config and create distributions and establish an mirror in our intranet.
Actually I do some configurations just by editing property-files in the .metadata-path, but I'm not very happy with it, because if these configurations change, I don't notice and I guess not all configurations are possible with this technique
Would be better to use a API for this, but I didn't find anything I can use. Didn't I search at the right place?
What way should I go to preconfigure these settings?
Hope you can help me,
best regards
Markus
Re: How to contribute configurations programmatically [message #635018 is a reply to message #634807] Mon, 25 October 2010 12:28 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
For many workspace level properties, you can use your product's
plugin_customization.ini file to provide defaults (see
eclipse/plugins/org.eclipse.sdk_3.6.0.v201006080911/plugin_c ustomization.ini
for an example).
For some things, like default update sites, they can be provided by a
p2.inf file for your product. This works if you are building your
product using PDE build and p2.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: How to contribute configurations programmatically [message #635420 is a reply to message #635018] Tue, 26 October 2010 17:50 Go to previous messageGo to next message
Hi Paul,
thank you for your answer.
I have still questions:
Can you please give me a hint, were I can find all items I can configure with this solution?
Is this a feature save technique or may the settings be incompatible changed in following releases?
I guess it's very similar to my solution, only difference is that my changes are noticed after eclipse restarts and has to be done manually at each workspace - is there any further difference?
Thanks in advance
Best regards
Markus
Re: How to contribute configurations programmatically [message #635579 is a reply to message #635420] Wed, 27 October 2010 12:13 Go to previous messageGo to next message
Markus Oley wrote:
> Hi Paul,
> with this solution?
It's the list of preferences, and you can only find them by working
through the code.
Preferences published as API will be available, like:
org.eclipse.ui.IWorkbenchPreferenceConstants. Each bundle or component
can choose to make preferences API by publishing them as constants.
plugin_customization.ini will be distributed as part of the build and
run on every start. It can also be passed in as a runtime parameter (so
if you really wanted to customize the standard Eclipse SDK product).
The p2.inf solution (for creating default update sites, for example) is
done at build time and will also appear for users on every start.
PW
Paul Webster
Re: How to contribute configurations programmatically [message #635823 is a reply to message #635579] Thu, 28 October 2010 09:25 Go to previous message
Thank you
Previous Topic:.eclipse folder issues
Next Topic:problem in user defined order of jar files during exporting
Current Time: Mon Mar 08 10:15:30 GMT 2021
Powered by FUDForum. Page generated in 0.01940 seconds
