| Re: ambiguous methods differ only by (generic) return type [message #635214 is a reply to message #634867] |
Tue, 26 October 2010 02:33  |
Brian Vosburgh Messages: 137 Registered: July 2009 |
| Stephan Herrmann wrote on Sun, 24 October 2010 13:53 | | Brian Vosburgh wrote on Sat, 23 October 2010 07:12 | I have the following interfaces:
public interface Bar {
String getSomething();
public interface SubBar extends Bar {
String getSomethingElse();
public interface Foo {
<T extends Bar> Iterable<T> bars();
public interface SubFoo extends Foo {
<T extends SubBar> Iterable<T> bars();
I'm not sure whether SubFoo's declaration of bars() should be allowed, but the compiler seems to have no complaint.
IMHO it should complain "The return type is incompatible with Foo.bars(int)",
essentially because Iterable<SubBar> is not conform to Iterable<Bar>.
Anyway, the compiler's behavior doesn't seem kosher to me,
so I suggest you file a bug where we can further track this issue.
thanks,
Stephan
PS:
As for your example, may you need this:
Iterable<? extends Bar> bars();
Iterable<? extends SubBar> bars();
I have entered a bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=328669
As to your suggested code: That type of code is helpful in some places but not so much in others. :-) Also, the compiler complains about the @Override annotation:
Multiple markers at this line
- The method bars() of type SubFoo must override a superclass method
- implements Foo.bars
Pretty funny pair of contradicting messages. :-)
Anyway, if I remove the @Override annotation, the new code compiles fine.
Brian
FUDForum. Page generated in 0.01864 seconds
