Home » Archived » BPMN Modeler » Run BPMN Modeler
Run BPMN Modeler [message #634198] Wed, 20 October 2010 18:40 Go to next message
No real name is currently offline No real nameFriend
I have installed the BPMN modeler. Not sure how to run it from eclipse. I have an existing application. I would like to select a package and generate a BPMN model. I right click on the project but do not see any options to generate BPMN
Re: Run BPMN Modeler [message #663989 is a reply to message #634198] Thu, 07 April 2011 06:05 Go to previous messageGo to next message
Paul Keryon is currently offline Paul KeryonFriend
In the meantime try to double click on a .bpmn_diagram file, the editor should pop up
Re: Run BPMN Modeler [message #669757 is a reply to message #663989] Wed, 11 May 2011 12:18 Go to previous message
Sathish Kumar Subramanian is currently offline Sathish Kumar SubramanianFriend
If the plugin is installed properly, you should be able to see BPMN Diagram in the Project Creation Wizard,
New -> Other -> BPMN Diagram
After opening the diagram, you can start creating your own design using .bpmn_diagram file.
Previous Topic:Adding a Pool using the BPMNVisual2ProcessGenerator
Next Topic:Catch Events
Current Time: Tue Aug 11 22:35:49 GMT 2020
Powered by FUDForum. Page generated in 0.02206 seconds
