Home » Eclipse Projects » Standard Widget Toolkit (SWT) » [SOLVED] Setting limit to Sash position doesn't work on Mac OS X(Setting minimum width to SashForm children)
[SOLVED] Setting limit to Sash position doesn't work on Mac OS X [message #633984] |
Wed, 20 October 2010 07:36 |
Albert Pikus Messages: 70 Registered: October 2009 |
Member |
Hi, everybody,
I have encountered a strange behavior when setting minimum composite width when moving sash. I have two composites inside a SWT.HORIZONTAL style SashForm. When I want to set a limit how far to the right Sash can be moved, I'm using a code, which works on Windows and GTK, but when running this code on Mac OS X (10.6), once the sash is moved to this limit, "West-East" cursor won't appear anymore when hovering with a mouse over it, and Sash cannot be no longer moved. If I resize the shell, cursor reappears and Sash can be moved again.
Here is the snippet that can be used to reproduce this behavior:
import java.lang.reflect.Field;
import org.eclipse.swt.SWT;
import org.eclipse.swt.custom.SashForm;
import org.eclipse.swt.events.SelectionAdapter;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.graphics.Color;
import org.eclipse.swt.layout.FormAttachment;
import org.eclipse.swt.layout.FormData;
import org.eclipse.swt.layout.FormLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Sash;
import org.eclipse.swt.widgets.Shell;
public class SashFormTest
// Minimum width of right composite
final static int MIN_WIDTH = 200;
public static void main (String [] args)
Display display = new Display ();
final Shell shell = new Shell(display);
shell.setLayout(new FormLayout());
shell.setText("SashFormTest");
final SashForm sashForm = new SashForm(shell, SWT.HORIZONTAL);
sashForm.setLayout(new FormLayout());
FormData formData = new FormData();
formData.top = new FormAttachment(0, 0);
formData.bottom = new FormAttachment(100, 0);
formData.left = new FormAttachment(0, 0);
formData.right = new FormAttachment(100, 0);
sashForm.setLayoutData(formData);
Composite leftComposite = new Composite(sashForm, SWT.NONE);
leftComposite.setLayout(new FormLayout());
leftComposite.setLayoutData(formData);
leftComposite.setBackground(new Color(shell.getDisplay(), 255, 0, 0));
Composite rightComposite = new Composite(sashForm, SWT.NONE);
rightComposite.setLayout(new FormLayout());
rightComposite.setLayoutData(formData);
rightComposite.setBackground(new Color(shell.getDisplay(), 0, 255, 0));
sashForm.setWeights(new int[] {30, 70});
shell.setSize(500, 200);
// Get sashes using reflection
Sash[] sashes = getSashes(sashForm);
Sash sash = sashes[0];
// Composite on the right side of the sash
// is always at least 200 px wide, when sash is moved
sash.addSelectionListener(new SelectionAdapter ()
public void widgetSelected(SelectionEvent event)
if (event.x >= shell.getBounds().width - MIN_WIDTH)
int shellWidth = shell.getBounds().width;
// Calculate new ratio for sashes weights
double ratio = (double)shellWidth / Math.abs(shell.getBounds().width - MIN_WIDTH);
double percent = 100 / ratio;
int percentRounded = (int) Math.floor(percent);
sashForm.setWeights(new int[]{percentRounded, 100 - percentRounded});
sashForm.layout();
shell.open ();
while (!shell.isDisposed ())
if (!display.readAndDispatch())
display.sleep ();
display.dispose ();
private static Sash[] getSashes(SashForm sf)
Field fields[] = sf.getClass().getDeclaredFields();
for (int i = 0; i < fields.length; ++i)
if (fields[i].getName().equals("sashes"))
try
fields[i].setAccessible(true);
return (Sash[]) fields[i].get(sf);
catch (IllegalAccessException e)
e.printStackTrace();
return null;
I'm not sure if there is any better way to achieve this, but I couldn't find any other means to limit how far a Sash can be moved. Nevertheless, I can't see a reason why this wouldn't work. Am I missing something obvious here? Any suggestion would be helpful,
best regards,
Albert
[Updated on: Fri, 22 October 2010 12:24] Report message to a moderator
Re: Setting limit to Sash position doesn't work on Mac OS X [message #634602 is a reply to message #634563] |
Fri, 22 October 2010 12:22 |
Member |
Hi, Lakshmi,
thank you for your quick answer, putting sashForm.layout(); inside an asyncExec() really fixed the problem. I'll report a bug on Eclipse Bugzilla.
I didn't look at the SashForm hierarchy, so I was completely unaware that SashForm is a Composite and I was using reflection instead of simple call to SashForm.getChildren() in order to get the sash.
Thanks again, best regards,
Albert
[Updated on: Fri, 22 October 2010 14:09] Report message to a moderator
Current Time: Thu Apr 25 16:19:17 GMT 2024
Powered by FUDForum. Page generated in 0.03153 seconds
