Re: Simple question I hope - limiting axis label lengths [message #633859 is a reply to message #633693] |
Tue, 19 October 2010 15:54 |
Mark,
Select the third tab of the chart wizard and select the axis you want to
set and then click the label button. There is an ellipsis field in the
dialog.
Jason
On 10/18/2010 7:01 PM, Mark Victory wrote:
> I hope this is a simple question.
> The axis labels (not the axis Title) in one of my charts can be really
> long.
> Can I tell the chart to limit the space for the axis labels to some
> percent of the chart or some absolute width. Or is there some way to
> tell the Chart to display "n" characters and then use ellipses?
> Thanks a lot,
> Mark
Re: Simple question I hope - limiting axis label lengths [message #634129 is a reply to message #633926] |
Wed, 20 October 2010 15:32 |
Mark,
You are correct. The chart engine calculates whether to display the
labels based on size. One work around would be to set the label font
size small and then the engine would render all the labels and you could
enter a script like:
function beforeDrawAxisLabel( axis, label, icsc )
importPackage(Packages.org.eclipse.birt.chart.model.attribut e);
importPackage(Packages.java.text);
//LINEAR_LITERAL
//LOGARITHMIC_LITERAL
//TEXT_LITERAL
//DATE_TIME_LITERAL
if (axis.getType() == AxisType.TEXT_LITERAL)
var currval =label.getCaption().getValue();
var newval = currval.substring(0, 3);
newval=newval+"..";
label.getCaption().setValue(newval);
label.getCaption().getFont().setSize(8);
To change each label and the size of the label. Look at the second
chart in the attached example.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.21"
id="1">
<property name="comments">Copyright (c) 2007 <<Your Company
Name here>></property>
<property name="createdBy">Eclipse BIRT Designer Version
2.5.2.v20100208 Build <2.5.2.v20100210-0630></property>
<html-property name="description">Creates a blank report with no
predefined content.</html-property>
<property name="units">in</property>
<text-property name="displayName">Blank Report</text-property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="layoutPreference">auto layout</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="6">
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
<property name="OdaConnProfileName"></property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Data Set" id="7">
<list-property name="columnHints">
<structure>
<property name="columnName">CUSTOMERNUMBER</property>
<text-property
name="displayName">CUSTOMERNUMBER</text-property>
</structure>
<structure>
<property name="columnName">CUSTOMERNAME</property>
<text-property
name="displayName">CUSTOMERNAME</text-property>
</structure>
<structure>
<property name="columnName">CONTACTLASTNAME</property>
<text-property
name="displayName">CONTACTLASTNAME</text-property>
</structure>
<structure>
<property name="columnName">CONTACTFIRSTNAME</property>
<text-property
name="displayName">CONTACTFIRSTNAME</text-property>
</structure>
<structure>
<property name="columnName">PHONE</property>
<text-property name="displayName">PHONE</text-property>
</structure>
<structure>
<property name="columnName">ADDRESSLINE1</property>
<text-property
name="displayName">ADDRESSLINE1</text-property>
</structure>
<structure>
<property name="columnName">ADDRESSLINE2</property>
<text-property
name="displayName">ADDRESSLINE2</text-property>
</structure>
<structure>
<property name="columnName">CITY</property>
<text-property name="displayName">CITY</text-property>
</structure>
<structure>
<property name="columnName">STATE</property>
<text-property name="displayName">STATE</text-property>
</structure>
<structure>
<property name="columnName">POSTALCODE</property>
<text-property
name="displayName">POSTALCODE</text-property>
</structure>
<structure>
<property name="columnName">COUNTRY</property>
<text-property
name="displayName">COUNTRY</text-property>
</structure>
<structure>
<property
name="columnName">SALESREPEMPLOYEENUMBER</property>
<text-property
name="displayName">SALESREPEMPLOYEENUMBER</text-property>
</structure>
<structure>
<property name="columnName">CREDITLIMIT</property>
<text-property
name="displayName">CREDITLIMIT</text-property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">CUSTOMERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">CUSTOMERNAME</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">CONTACTLASTNAME</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">CONTACTFIRSTNAME</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">PHONE</property>
</structure>
<structure>
<property name="position">6</property>
<property name="name">ADDRESSLINE1</property>
</structure>
<structure>
<property name="position">7</property>
<property name="name">ADDRESSLINE2</property>
</structure>
<structure>
<property name="position">8</property>
<property name="name">CITY</property>
</structure>
<structure>
<property name="position">9</property>
<property name="name">STATE</property>
</structure>
<structure>
<property name="position">10</property>
<property name="name">POSTALCODE</property>
</structure>
<structure>
<property name="position">11</property>
<property name="name">COUNTRY</property>
</structure>
<structure>
<property name="position">12</property>
<property
name="name">SALESREPEMPLOYEENUMBER</property>
</structure>
<structure>
<property name="position">13</property>
<property name="name">CREDITLIMIT</property>
<property name="dataType">float</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">CUSTOMERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">CUSTOMERNAME</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">CONTACTLASTNAME</property>
</structure>
<structure>
<property name="nativeName">CONTACTFIRSTNAME</property>
</structure>
<structure>
<property name="nativeName">PHONE</property>
</structure>
<structure>
<property name="nativeName">ADDRESSLINE1</property>
</structure>
<structure>
<property name="nativeName">ADDRESSLINE2</property>
</structure>
<structure>
<property name="nativeName">CITY</property>
</structure>
<structure>
<property name="nativeName">STATE</property>
</structure>
<structure>
<property name="nativeName">POSTALCODE</property>
</structure>
<structure>
<property name="nativeName">COUNTRY</property>
</structure>
<structure>
<property name="name">SALESREPEMPLOYEENUMBER</property>
<property
name="nativeName">SALESREPEMPLOYEENUMBER</property>
</structure>
<structure>
<property name="nativeName">CREDITLIMIT</property>
<property name="nativeDataType">8</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select *
from CLASSICMODELS.CUSTOMERS]]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>CUSTOMERNUMBER</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>CUSTOMERNUMBER</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>CUSTOMERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>CUSTOMERNAME</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>50</design:precision>
<design:uiHints>
<design:displayName>CUSTOMERNAME</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CUSTOMERNAME</design:label>
<design:displaySize>50</design:displaySize>
<design:attributes>
<design:name>CONTACTLASTNAME</design:name>
<design:position>3</design:position>
<design:uiHints>
<design:displayName>CONTACTLASTNAME</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CONTACTLASTNAME</design:label>
<design:attributes>
<design:name>CONTACTFIRSTNAME</design:name>
<design:position>4</design:position>
<design:uiHints>
<design:displayName>CONTACTFIRSTNAME</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CONTACTFIRSTNAME</design:label>
<design:attributes>
<design:name>PHONE</design:name>
<design:position>5</design:position>
<design:uiHints>
<design:displayName>PHONE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PHONE</design:label>
<design:attributes>
<design:name>ADDRESSLINE1</design:name>
<design:position>6</design:position>
<design:uiHints>
<design:displayName>ADDRESSLINE1</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ADDRESSLINE1</design:label>
<design:attributes>
<design:name>ADDRESSLINE2</design:name>
<design:position>7</design:position>
<design:uiHints>
<design:displayName>ADDRESSLINE2</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ADDRESSLINE2</design:label>
<design:attributes>
<design:name>CITY</design:name>
<design:position>8</design:position>
<design:uiHints>
<design:displayName>CITY</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CITY</design:label>
<design:attributes>
<design:name>STATE</design:name>
<design:position>9</design:position>
<design:uiHints>
<design:displayName>STATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>STATE</design:label>
<design:attributes>
<design:name>POSTALCODE</design:name>
<design:position>10</design:position>
<design:precision>15</design:precision>
<design:uiHints>
<design:displayName>POSTALCODE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>POSTALCODE</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>COUNTRY</design:name>
<design:position>11</design:position>
<design:uiHints>
<design:displayName>COUNTRY</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>COUNTRY</design:label>
<design:attributes>
<design:name>SALESREPEMPLOYEENUMBER</design:name>
<design:position>12</design:position>
<design:uiHints>
<design:displayName>SALESREPEMPLOYEENUMBER</design:displayName >
</design:uiHints>
<design:usageHints>
<design:label>SALESREPEMPLOYEENUMBER</design:label>
<design:attributes>
<design:name>CREDITLIMIT</design:name>
<design:position>13</design:position>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>CREDITLIMIT</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CREDITLIMIT</design:label>
<design:displaySize>22</design:displaySize>
</design:resultSetColumns>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
</data-sets>
<cubes>
<tabular-cube name="Data Cube" id="9">
<property name="dimensions">
<tabular-dimension name="Group" id="12">
<property
name="defaultHierarchy">NewTabularHierarchy</property>
<property name="hierarchies">
<tabular-hierarchy name="NewTabularHierarchy"
id="13">
<property name="levels">
<tabular-level name="COUNTRY" id="14">
<property
<property
</tabular-level>
<tabular-level name="STATE" id="15">
<property
<property
</tabular-level>
</property>
</tabular-hierarchy>
</property>
</tabular-dimension>
</property>
<property name="measureGroups">
<tabular-measure-group name="Summary Field" id="10">
<property name="measures">
<tabular-measure name="CREDITLIMIT" id="11">
<expression
name="measureExpression">dataSetRow["CREDITLIMIT"]</expression >
</tabular-measure>
</property>
</tabular-measure-group>
</property>
<property name="dataSet">Data Set</property>
</tabular-cube>
</cubes>
<styles>
<style name="crosstab-cell" id="4">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="5">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<property name="topMargin">1in</property>
<property name="leftMargin">1.25in</property>
<property name="bottomMargin">1in</property>
<property name="rightMargin">1.25in</property>
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<extended-item extensionName="Chart" name="NewChart" id="8">
<xml-property
name="xmlRepresentation"><![CDATA[<model:ChartWithAxes
xmlns:attribute="http://www.birt.eclipse.org/ChartModelAttribute"
xmlns:data="http://www.birt.eclipse.org/ChartModelData"
xmlns:layout="http://www.birt.eclipse.org/ChartModelLayout"
xmlns:model="http://www.birt.eclipse.org/ChartModel"
xmlns:type="http://www.birt.eclipse.org/ChartModelType">
<Type>Bar Chart</Type>
<SubType>Side-by-side</SubType>
<Description>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Description>
<Block>
<Children xsi:type="layout:TitleBlock">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
<Height>0.0</Height>
</Bounds>
<Anchor>North</Anchor>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Bottom>3.0</Bottom>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Rowspan>-1</Rowspan>
<Columnspan>-1</Columnspan>
<Outline>
<Style>Solid</Style>
<Thickness>1</Thickness>
<Color>
<Transparency>255</Transparency>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
<Visible>true</Visible>
</Outline>
<Label>
<Caption>
<Value>Bar Chart Title</Value>
<Font>
<Size>16.0</Size>
<Bold>true</Bold>
<Alignment>
<horizontalAlignment>Center</horizontalAlignment>
<verticalAlignment>Center</verticalAlignment>
</Alignment>
<Rotation>18.0</Rotation>
</Font>
</Caption>
<Background xsi:type="attribute:ColorDefinition">
<Transparency>0</Transparency>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>254</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<ShadowColor>
<Red>204</Red>
<Green>254</Green>
<Blue>204</Blue>
</ShadowColor>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Bottom>0.0</Bottom>
<Right>3.0</Right>
</Insets>
</Label>
</Children>
<Children xsi:type="layout:Plot">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<HorizontalSpacing>5</HorizontalSpacing>
<VerticalSpacing>5</VerticalSpacing>
<ClientArea>
<Red>204</Red>
<Green>254</Green>
<Blue>254</Blue>
</Background>
<Outline>
<Thickness>0</Thickness>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>0.0</Left>
<Right>0.0</Right>
</Insets>
</ClientArea>
</Children>
<Children xsi:type="layout:Legend">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
<Visible>false</Visible>
</Outline>
<Red>254</Red>
<Green>254</Green>
<Blue>153</Blue>
</Background>
<ClientArea>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>2.0</Top>
<Left>2.0</Left>
<Bottom>2.0</Bottom>
<Right>2.0</Right>
</Insets>
</ClientArea>
<Text>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Text>
<Orientation>Vertical</Orientation>
<Direction>Top_Bottom</Direction>
<Separator>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Separator>
<Position>Right</Position>
<ItemType>Series</ItemType>
<Title>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Above</TitlePosition>
<ShowValue>true</ShowValue>
<WrappingSize>0.0</WrappingSize>
<MaxPercent>0.333</MaxPercent>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>433.49999999759996</Width>
<Height>239.9999999976</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
</Block>
<Dimension>Two_Dimensional</Dimension>
<Units>Points</Units>
<SeriesThickness>10.0</SeriesThickness>
<SampleData>
<BaseSampleData>
<DataSetRepresentation>A, B, C</DataSetRepresentation>
</BaseSampleData>
<OrthogonalSampleData>
<DataSetRepresentation>5,4,12</DataSetRepresentation>
<SeriesDefinitionIndex>0</SeriesDefinitionIndex>
</OrthogonalSampleData>
</SampleData>
<Interactivity/>
<EmptyMessage>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</EmptyMessage>
<Axes>
<Type>Text</Type>
<Title>
<Caption>
<Value>X-Axis Title</Value>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
<Rotation>-21.0</Rotation>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>254</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Below</TitlePosition>
<AssociatedAxes>
<Type>Linear</Type>
<Title>
<Caption>
<Value>Y-Axis Title</Value>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
<Rotation>67.0</Rotation>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>254</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Left</TitlePosition>
<SeriesDefinitions>
<Query>
<Definition></Definition>
</Query>
<SeriesPalette>
<Entries xsi:type="attribute:ColorDefinition">
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
</Entries>
<Red>242</Red>
<Green>88</Green>
<Blue>106</Blue>
</Entries>
<Red>232</Red>
<Green>172</Green>
<Blue>57</Blue>
</Entries>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
<Red>192</Red>
<Green>192</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>192</Green>
<Blue>128</Blue>
&l
Re: Simple question I hope - limiting axis label lengths [message #634474 is a reply to message #634415] |
Thu, 21 October 2010 20:16 |
I think I understand. In the example I was building the chart engine
was turning off labels because they were to big. In your case this is
not happening but you are getting to much space? You can send me a
screen shot at jasonweathersby at windstream dot net. You can change
the bounds of the chart before rendering it in script. Send me the
image and I will build a quick example.
btw the ellipsis is a minimum number of characters not a maximum. This
may be the issue.
Jason
On 10/21/2010 11:37 AM, Mark Victory wrote:
> Thanks Jason,
> Unless I'm just misunderstanding your last reply.......
> The problem is not that the Labels don't display. They do.
> And with the code added to the beforeDrawAxisLabel method, they display
> shorter and with the elipses.
> The problem is that the chart seems to have calculated how much width it
> needs for the Axis label area before the labels are shortened so there
> is now lots of empty space where the full length labels would be
> displayed and the actual chart area is smaller than necessary.
> I wish I could paste a screen shot. :)
> Any idea why the Ellipses setting for the chart is not working?
Re: Simple question I hope - limiting axis label lengths [message #634692 is a reply to message #634474] |
Fri, 22 October 2010 18:04 |
See this example:
http://www.birt-exchange.org/org/devshare/designing-birt-rep orts/1272-long-category-labels-on-bar-chart-scripts/
Jason
> screen shot at jasonweathersby at windstream dot net. You can change the
> bounds of the chart before rendering it in script. Send me the image and
> may be the issue.
> Jason
>> Thanks Jason,
FUDForum. Page generated in 0.03642 seconds
