Annoying parameters, methods autocompletes [message #633365] |
Sun, 17 October 2010 01:08 |
RDP9 Messages: 2 Registered: October 2010 |
I am using Eclipse Helios.
When I am typing a code, Eclipse automatically completes the code when I write methods and other stuff. This is annoying for me, as I want to write all the code by myself, not that the IDE writes it for me by completing it. However, I like when it popsup the suggestion box so I can see what method, etc. I can use.
For example, the closing parenthesis and brackets, etc.
Every time I write an opening bracket or parenthesis, Eclipse automatically closes it and put my cursor where I suppose to write the code between the brackets or parenthesis.
But I already disabled that feature (specifically for auto closing).
I want to disable the features that adds parameters to the methods and closes the parenthesis of the methods.
This is what happens that I do not like:
- I write: frame. (the Proposals box popsup, which is fine for me).
-Then continue: frame.setVisible( [when I write the "(" it closes automatically and puts the parameter type that I am suppose to write)
-The final outcome: frame.setVisible(Boolean) [the underlined part is what I DO NOT like and want to disable]
only when I make a mistake when writing setVisible is that the autocomplete doesn't completes it, but I won't be making grammar mistakes always just because of that.
If you could help me by telling me where I can disable it, and what I have to write, check, uncheck or whatever have to be done to disable that feature.
Thank you.
Re: Annoying parameters, methods autocompletes [message #633402 is a reply to message #633365] |
Sun, 17 October 2010 13:37 |
David Wegener Messages: 1445 Registered: July 2009 |
> Thank you.
You are looking for the Insert single proposals automatically and Fill
method arguments options under the Java->Editor->Content Assist
preferences.
FUDForum. Page generated in 0.03365 seconds
