Home » Modeling » EMF » Substitution groups without importing from XSD
Substitution groups without importing from XSD [message #633184] Fri, 15 October 2010 14:57 Go to next message
J.-P. Pellet is currently offline J.-P. PelletFriend
Member
Hi again,
I want to avoid the xsi:type attribute of elements in my written XML.
I've read that this can be done with substitution groups. However, I
can't seem to get this to work. I would like to specify the necessary
data form annotated Java, not from XSD. How can I do that?
I tried adding an ExtendedMetaData with a "name -> $mytagname" line and
defining an ElementHandler for saving, with no luck...
J.-P.
Re: Substitution groups without importing from XSD [message #633222 is a reply to message #633184] Fri, 15 October 2010 17:51 Go to previous messageGo to next message
J.-P.,
It's very tricky to get right. I'd suggest starting with a schema,
generating the Java, and then looking at the annotations in the
generated Java to be sure about all the little details. After that you
can continue by modifying the Java and the annotations.
J.-P. Pellet wrote:
> Hi again,
> and defining an ElementHandler for saving, with no luck...
> Cheers,
> J.-P.
Ed Merks
Re: Substitution groups without importing from XSD [message #633577 is a reply to message #633222] Mon, 18 October 2010 12:44 Go to previous messageGo to next message
Member
Ed,
I followed your advice, and indeed, it's very tricky. It would be great
if all of this could be done with a simple annotation on the feature
that contains elements where we want to remove this xsi:type attribute.
Here's what I did to make it work, feel free to comment on what I
misunderstood.
GOAL: Given an abstract superclass SuperA with two subclasses SubA and
SubB. Another class Other holds a collections of concrete instances of
SuperA, and instead of getting the xsi:type attribute on the generated
XML, we wish to use the names of the concrete classes in the element
directly.
STEPS:
1. Be sure to have a DocumentRoot class, as some of the meta information
goes there.
2. In the superA feature of DocumentRoot, named after the abstract
superclass SuperA, add the ExtendedMetaData annotation (an annotation
with source http:///org/eclipse/emf/ecore/util/ExtendedMetaData), and
add the following entries (substituting 'superA'):
kind -> element
name -> superA
namespace -> ##targetNamespace
3. In each of the features of DocumentRoot named after the concrete
subclasses, add the following ExtendedMetaData entries:
kind -> element
name -> subX
affiliation -> superA
4. Finally, add the following ExtendedMetaData entries on the feature
referencing SuperA instances in the class Other:
kind -> element
name -> superA
5. Make sure that the following save options are set properly:
OPTION_EXTENDED_META_DATA -> Boolean.TRUE
OPTION_ELEMENT_HANDLER -> new ElementHandlerImpl(false)
6. Make sure that the following load option is set properly:
OPTION_SUPPRESS_DOCUMENT_ROOT -> Boolean.TRUE
This seems to work for me. In a kind of black-box way, but still, it
works...
J.-P.
On 15.10.10 19:51, Ed Merks wrote:
> J.-P.,
> J.-P. Pellet wrote:
>> Hi again,
>> Cheers,
>> J.-P.
Re: Substitution groups without importing from XSD [message #633580 is a reply to message #633577] Mon, 18 October 2010 12:54 Go to previous message
J.-P.,
Comments below.
J.-P. Pellet wrote:
> Ed,
> great if all of this could be done with a simple annotation on the
> feature that contains elements where we want to remove this xsi:type
> attribute.
My cup runneth over from all the things that would be so nice to have...
> misunderstood.
> directly.
> STEPS:
> information goes there.
Yes, the mapping of the feature names is based on global element
declarations, which are mapped to the document root.
> kind -> element
> name -> superA
A global element declarations.
> kind -> element
> name -> subX
Another that's in the substitution group of the previous.
> kind -> element
> name -> superA
An reference to the global element declarations.
The option to save in a way that does the mapping down to the
substitution group.
And option to load without the document root showing up
> works...
Very complex, but corresponding perfectly to XML Schema...
> Cheers,
> J.-P.
>> J.-P.,
>> J.-P. Pellet wrote:
>>> Hi again,
>>> Cheers,
>>> J.-P.
Ed Merks
Previous Topic:Abstract class with InstanceTypeName and Reflective Serialization
Next Topic:[EMF-OCL-Java] OCL Query on Ecore model from Java.
Current Time: Thu Jul 16 18:28:20 GMT 2020
Powered by FUDForum. Page generated in 0.01659 seconds
