Home » Modeling » EMF » Non-changeable containment references
Non-changeable containment references [message #633119] Fri, 15 October 2010 12:33 Go to next message
J.-P. Pellet is currently offline J.-P. PelletFriend
Member
I found out something counterintuitive about non-changeable containment
EReferences.
Say class A has such a reference on an instance of class B:
* @model changeable="false" containment="true"
B getB();
As there's no generated setter setB(), I set the value of the
corresponding field directly in the constructor by assignment, "b =
whatever". So far, so good. Now, if I try saving the container object
"a", I'll get an exception that the referenced object b is not in the
resource set.
I would expect the system to realize that as the "b" reference in A in a
containment reference, then adding a to a resource set would also add
a.b transitively. To fix that, I had to make the feature changeable and
call the generated setter (which I can still hide with
suppressedSetVisibility="true").
Am I doing this correctly? Is there no way to keep the feature really
non-changeable and still as indicating containment, and get this to work
with serialization?
Best,
J.-P.
Re: Non-changeable containment references [message #633123 is a reply to message #633119] Fri, 15 October 2010 12:39 Go to previous messageGo to next message
J.-P.
I imagine it can't be easy to populate a non-changeable containment
reference. More comments below...
J.-P. Pellet wrote:
> containment EReferences.
> B getB();
It's not sounding good to me.
> Now, if I try saving the container object "a", I'll get an exception
> that the referenced object b is not in the resource set.
Given that the opposite hasn't been set, i.e., eContainer is null, I'd
expect that.
> a containment reference, then adding a to a resource set would also
> add a.b transitively.
That's normally the case, but it's the case by virtue of the eContainer
being populated.
> To fix that, I had to make the feature changeable and call the
Yes and if you looked at what the setter does, you'd see it does more
than just assign to the field.
> work with serialization?
What exactly will happen during deserialization? If you write it out,
you should expect to read it back in...
> Best,
> J.-P.
Re: Non-changeable containment references [message #633124 is a reply to message #633123] Fri, 15 October 2010 12:51 Go to previous messageGo to next message
Member
> being populated.
I see.
Hmm, indeed. Thanks for pointing this out... But now I'm confused: this
implies that non-changeable features simply cannot be deserialized, right?
Re: Non-changeable containment references [message #633150 is a reply to message #633124] Fri, 15 October 2010 13:46 Go to previous messageGo to next message
J.-P.,
Yes, one would generally expect that isTransient is true when
isChangeable is false.
>> being populated.
> I see.
> this implies that non-changeable features simply cannot be
Re: Non-changeable containment references [message #633183 is a reply to message #633150] Fri, 15 October 2010 14:47 Go to previous message
Member
Thanks for the clarification, Ed!
Previous Topic:Custom ResourceLocator for the generated Validator
Next Topic:model loading standalone application
Current Time: Mon Feb 24 12:21:14 GMT 2020
Powered by FUDForum. Page generated in 0.05253 seconds
