Home » Modeling » M2T (model-to-text transformation) » [Acceleo 3 / MTL] Problems when wrapping java methods in MTL
[Acceleo 3 / MTL] Problems when wrapping java methods in MTL [message #633081] Fri, 15 October 2010 10:12 Go to next message
Emilio Salazar is currently offline Emilio SalazarFriend
Dear all,
I want to call a java method from my MTL code. Therefore, I've used the Acceleo 3 wizard to generate the MTL's wrapper. Nevertheless, the generated MTL wrapper doesn't compiles.
The java method specification which I need to call is:
public static Object getNestedValue (Element self, List<String> NameValues)
and the MTL wrapper generated by the wizard is:
[query public getNestedValue(arg0 : Element, arg1 : Sequence(OclAny)) : OclAny
= invoke('Reflexion.Debug', 'getNestedValue(org.eclipse.uml2.uml.Element, java.util.List)', Sequence{arg0, arg1}) /]
As it's said before, the problem is that this wrapper doesn't compiles. I get the next error:
Type mismatch. No common supertype: (Element), (Sequence(OclAny)) debug.mtl /org.eclipse.acceleo.module.sample/src/org/eclipse/acceleo/m odule/sample/files line 7 Acceleo Problem
I think that the problem is that "java.util.List" doesn't match with the MTL's Sequence (in this case, of strings) type. But I were not able to discover which java type matches with Sequence type.
So, I'm a bit confusing. Any help will be welcome.
Thank you in advance.
Emilio.
Re: [Acceleo 3 / MTL] Problems when wrapping java methods in MTL [message #633098 is a reply to message #633081] Fri, 15 October 2010 11:04 Go to previous messageGo to next message
Laurent Goubet is currently offline Laurent GoubetFriend
--------------040104050507070604010009
Hi Emilio,
The problem you have is that OCL doesn't allow for a Sequence containing
an element and a list, Sequence{'a', 'z', 'e'} is valid, but
Sequence{'a', Sequence{'z', 'e'}} is not.
As such, it is currently impossible to call, from Acceleo, Java services
which take a collection as parameter. This is a known limitation which
we have little options to try and circumvent. Do you really need a list
as parameter, or can you workaround this limitation by calling the
service multiple times (one for each of your list's content)?
Laurent Goubet
Obeo
Emilio Salazar wrote:
> Dear all,
> OclAny
> debug.mtl
> Regards,
> Emilio.
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------040104050507070604010009--
Re: [Acceleo 3 / MTL] Problems when wrapping java methods in MTL [message #633102 is a reply to message #633098] Fri, 15 October 2010 11:48 Go to previous messageGo to next message
Hi Laurent,
First, thank you for so fast answer.
OK, I didn't know this limitation of OCL.
Fortunately, I think that I can workaround this limitation by calling the java method multiple times.
Thank you again.
Emilio.
Re: [Acceleo 3 / MTL] Problems when wrapping java methods in MTL [message #633142 is a reply to message #633098] Fri, 15 October 2010 13:48 Go to previous messageGo to next message
Hi Emilio, Laurent
> containing an element and a list, Sequence{'a', 'z', 'e'} is valid,
> but Sequence{'a', Sequence{'z', 'e'}} is not.
This is true of OMG OCL 2.0 and MDT/OCL 3.0.
OCL 2.2 changed Collection to conform to OclAny, so the above is valid
in OCL 2.2, which hopefully will be supported by MDT/OCL 3.1.
Ed Willink
Re: [Acceleo 3 / MTL] Problems when wrapping java methods in MTL [message #639840 is a reply to message #633142] Thu, 18 November 2010 04:54 Go to previous messageGo to next message
Sergio  is currently offline Sergio Friend
thank you very much for your help!!!
I was trying to do some workaround, and at the end I saw what was making me noise all the time.
In fact, this is what I can't understand:
[for (a : Association | class.getAssociations() )]
[numberOfRelations(a, class.name)/]
[if (numberOfRelations(a, class.name)>0)]
inside
[/if]
[/for]
where:
[query public numberOfRelations(a : Association, sourceClass : String) : Integer = a.ownedElement->asSequence().oclAsType(Property)->select(type.name.equalsIgnoreCase(sourceClass))->upper.oclAsType(Integer) /]
and this is the output:
	1
	1
	2
So, I have to believe that my query "numberOfRelations" is returning some integer (1,1,2) but if I what to use the result as a number... I can't!, so this operation fails: if (numberOfRelations(a, class.name)>0)]
And If I try:
[query public numberOfRelations(a : Association, sourceClass : String) : Integer = 2 /]
then this is the output:
	2
	inside
	2
	inside
	2
	inside
so, Why this can't be treated as an Integer?:
[query public [B]numberOfRelations[/B](a : Association, sourceClass : String) : Integer = a.ownedElement->asSequence().oclAsType(Property)->select(type.name.equalsIgnoreCase(sourceClass))->upper/]
Thank you!!!
Sergio Sacristán
http://s2o-bcn.blogspot.com/
Re: [Acceleo 3 / MTL] Problems when wrapping java methods in MTL [message #639859 is a reply to message #633081] Thu, 18 November 2010 07:54 Go to previous messageGo to next message
Stephane Begaudeau is currently offline Stephane BegaudeauFriend
Hi Sergio,
The problem is that your first query does not return an integer but a collection of one integer. We have a bug about queries, we don't check the type of the returned value and the type of the query, so even if you could expect this query to return an integer, it won't.
"a.ownedElement" is a collection
"a.ownedElement->asSequence()" still a collection
"a.ownedElement->asSequence().oclAsType(Property)" again, still a collection
"a.ownedElement->asSequence().oclAsType(Property)->select(type.name.equalsIgnoreCase(sourceClass)) " always a collection
"a.ownedElement->asSequence().oclAsType(Property)->select(type.name.equalsIgnoreCase(sourceClass))- >upper.oclAsType(Integer)" and finally a collection Smile
You can add a "->first()" to get the value since there seems to be only one integer in this collection.
Stephane Begaudeau, Obeo
[Updated on: Thu, 18 November 2010 07:54]
Report message to a moderator
Re: [Acceleo 3 / MTL] Problems when wrapping java methods in MTL [message #640064 is a reply to message #639859] Thu, 18 November 2010 21:42 Go to previous messageGo to next message
great! thank you!!
Sergio Sacristán
Re: [Acceleo 3 / MTL] Problems when wrapping java methods in MTL [message #870736 is a reply to message #640064] Wed, 09 May 2012 13:42 Go to previous message
ibrahim kara is currently offline ibrahim karaFriend
I am merging a plug-in written in Acceleo 2 to the new version Acceleo 3. In the old plug-in there are several calls to some java services with collection parameters. When I try to pass a collection to a Java service, I receive errors. I would like to know if it is possible to pass a collection from a template to a Java service as a parameter?
Thanks in advance.
Previous Topic:Trying to load UTP 1.1 (xmi from OMG)
Next Topic:[Acceleo] Determining whether a modeling element is extended by some stereotype in a hierarchy
Current Time: Sat Nov 27 14:20:24 GMT 2021
Powered by FUDForum. Page generated in 0.02708 seconds
