| [ETL] Accessing packages [message #632934] |
Thu, 14 October 2010 13:26  |
I'm working on a transformation that uses an ecore metamodel with several packages. Right now I'm able to use all types of the top level, but I cannot access any types from the packages.
I used the syntax from the reference
But I always get a type-not-found-exception. I don't think it is a registering issue because I can see the ecore structure just fine in the EPackage Registry View.
Any ideas why I'm not able to use the types of the packages? Are different namespaces of the packages any problem?
Thanks for your help!
Henning
[Updated on: Thu, 14 October 2010 15:30] by Moderator
FUDForum. Page generated in 0.05393 seconds
