Re: How Do I Integrate Birt Report with PHP Web Application [message #632940 is a reply to message #632919] |
Thu, 14 October 2010 17:39 |
Zend has a commercial java bridge you can use to call the BIRT engine to
run reports or you can look at the open source java bridge. I wrote an
article on this approach a while back:
http://www.theserverside.com/news/1363642/Intergrating-BIRT- with-PHP
The bridge should already be updated and you can also get it here:
http://www.birt-exchange.org/org/devshare/deploying-birt-rep orts/743-calling-birt-from-php/
Jason
On 10/14/2010 12:23 PM, Kellylee wrote:
> Hello Community,
> I have a big issue that I truely need help resolving. If this has
> already been answered, please forgive me. I can't seem to find what I am
> looking for doing a search.
> I need to demo a PHP application that contains reports that a user can
> dynamically pass parameters too. I have the Zend Community Edition
> server installed. I have Eclipse with BIRT Reports installed. I can
> preview the report using the web viewer within Eclipse. However, how do
> I put it all together in my PHP application?
> I have a form with a dropdown box the user selects. I need to pass their
> selection as a parameter to the BIRT report. However, I have no idea how
> this is all accomplished. I am able to connect to the database, create a
> query passing in the user parameter. Obviously, there is a way to pass
> the results to the BIRT template which I am unclear in how to do. Any
> help is greatly appreciated.
> Regards,
> Kellylee
Re: How Do I Integrate Birt Report with PHP Web Application [message #633225 is a reply to message #632962] |
Fri, 15 October 2010 18:22 |
Kellylee,
Are you sure the Zend Server does not contain the Zend Java Bridge and
not the the php-java-bridge?
Jason
On 10/14/2010 3:58 PM, Kellylee wrote:
> Hi Jason,
> It appears the JavaBridge is already installed on the Zend Server
> Community Edition. Do I redownload php-java-bridge_5.4.3.3 that contains
> the Birt integration? If so, the link you provided contains newer
> versions but not 5.4.3.3.
> I am confused in how to set this on the Zend Server Community Edition. I
> truely appreciate your expertise in this area. Thank you for taking time
> out to help me.
> Best Regards,
> Kellylee
Re: How Do I Integrate Birt Report with PHP Web Application [message #633242 is a reply to message #633236] |
Fri, 15 October 2010 19:41 |
I thought the Zend Community server had its own Java Bridge. Do you see
any BIRT reports in the Community edition?
Jason
On 10/15/2010 3:09 PM, Kellylee wrote:
> Hi Jason,
> I am not sure. I tried to follow your instructions but they are for TOMCAT.
> "The main step is to copy the JavaBridge.war file to the J2EE containers
> deployment directory. When using Tomcat, this directory is located at
> TomcatInstallDirectory/webapps."
> Do you know the steps I need to follow to get this working on the Zend
> Server Community Edition?
> When I try to run the following Test Script:
> <?php require_once("http://localhost/JavaBridge/java/Java.inc");
> echo java("java.lang.System")->getProperties();
> I get this error:
> The server encountered an internal error or misconfiguration and was
> unable to complete your request.
> Please contact the server administrator, mailto:admin@example.com and
> inform them of the time the error occurred, and anything you might have
> done that may have caused the error.
> More information about this error may be available in the server error log.
> Best Regards,
> Kelly
Re: How Do I Integrate Birt Report with PHP Web Application [message #635350 is a reply to message #635175] |
Tue, 26 October 2010 14:14 |
Kellylee,
I though they had a menu item for this, but I do not remember where.
Can you search the install for *birt*?
Jason
On 10/25/2010 4:47 PM, Kellylee wrote:
> Hello Jason,
> Ok, I was told the Zend CE edition does not work with BIRT reports
> unless I setup a Tomcat server. However, the Enterprise Zend server is
> suppose to do this without needing to download Tomcat.
> I downloaded the Windows version Zend Server 5.0.3 trial. The Java
> Bridge is installed. I installed Zend Studio 7.2 and installed the Birt
> Plugins. I created a report in Zend Studio. How do I deploy this report?
> This is where I am confused.
> Best Regards,
> Kellylee
Re: How Do I Integrate Birt Report with PHP Web Application [message #635382 is a reply to message #635358] |
Tue, 26 October 2010 15:04 |
Kellylee,
That url is the BIRT Viewer and does not use the JavaBridge at all.
Zend used to have the BIRT engine integrated much like the open source
JavaBridge article I wrote which uses the Birt Engine not the Viewer.
If you want to use the viewer you could always just add iframes to the
php page that include the url to the birt viewer deployed on tomcat.
Jason
On 10/26/2010 10:52 AM, Kellylee wrote:
> Hi Jason,
> I can not find a BIRT folder; however, when I run a BIRT report in Zend
> Studio the URL it is pointing to is
> http://localhost:63374/viewer/webcontent/birt
> Best Regards,
> Kellylee
Re: How Do I Integrate Birt Report with PHP Web Application [message #635404 is a reply to message #635387] |
Tue, 26 October 2010 16:19 |
Kellylee,
My email is jasonweathersby at windstream dot net. Send me an email.
Jason
On 10/26/2010 11:55 AM, Kellylee wrote:
> Hi Jason,
> I tried to follow your instructions by downloading the Tomcat server. I
> followed your instructions completely. I could view the report only on
> Tomcat. I was never able to view the BIRT report using the JavaBridge on
> the Apache Sever, which is why I decided to try the Zend server and Zend
> studio.
> I truely am at a lost in what to do at this point. I need to provide a
> demo to some high level executives but have no way at this point to
> accomplish this task. Is there any way I can contact you for some help?
> Maybe, if I follow your instructions while talking to you, I can
> determine what is going wrong.
> Again, thank you for your help.
> Kellylee
FUDForum. Page generated in 0.03944 seconds
