Re: org.xml.sax.SAXParseException: Premature end of file. [message #632869 is a reply to message #632752] |
Thu, 14 October 2010 14:13 |
Josh,
Take a look at this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=310512
Jason
On 10/14/2010 3:30 AM, Josh wrote:
> I've added BIRT to my application by including the components from the
> sample 'viewer' application into my web application. All works fine when
> running under Tomcat, however the same app has problems on Websphere
> 6.1. When attempting to view a report, I get
> 'org.xml.sax.SAXParseException: Premature end of file.' in a pop-up
> window. Following the wiki, I've tried setting the class loader policy
> to PARENT_LAST, however this has not resolved the problem. Are there any
> suggestions out there?
> Cheers.
Re: org.xml.sax.SAXParseException: Premature end of file. [message #633232 is a reply to message #632999] |
Fri, 15 October 2010 18:26 |
Josh,
I do not but you may want to ask the question in the bugzilla entry.
Jason
On 10/14/2010 7:37 PM, Josh wrote:
> Thanks a lot Jason. Using IE works fine. I was using Chrome & I hadn't
> thought to try another browser, as it was working with Chrome against
> Tomcat.
> I burnt a fair amount of time investigating this one, so it's a great
> relief to know what the problem is. I commented out the lines of code as
> per recommendation in the Bug and it also now works with the
> Chrome/WebSphere combination.
> Out of interest, do you have any idea what it is in WebSphere that's
> resulting in the error?
> Thanks again.
FUDForum. Page generated in 0.02666 seconds
