Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [TEXO] XML serialization for arraylist(TEXO XML serialization for EReference with containment at true)
[TEXO] XML serialization for arraylist [message #632744] Thu, 14 October 2010 07:00 Go to next message
Jean Duracel is currently offline Jean DuracelFriend
Dear readers,
In my ecore file I have :
<eStructuralFeatures
xsi:type="ecore:EReference"
name="achats" upperBound="-1"
eType="ecore:EClass BaseObject.ecore#//Achats" containment="true" resolveProxies="false">
</eStructuralFeatures>
Which gave me :
private List<Achats> achats = new ArrayList<Achats>();
When serialized with ModelXMLSaver :
<achats libelle1="medovina"/>
<achats libelle1="pruknik"/>
Is there a way to change this with something like :
<achats>
<item libelle1="medovina"/>
<item libelle1="pruknik"/>
</achats>
Maybe by using annotation inside the ecore file ?
Thanks a lot for your comment.
Re: [TEXO] XML serialization for arraylist [message #632767 is a reply to message #632744] Thu, 14 October 2010 08:21 Go to previous messageGo to next message
Martin Taal is currently offline Martin TaalFriend
Hi Jean,
Not supported right now I am afraid. Texo uses standard EMF XML serialization, I found this older post/reply on the EMF
newsgroup:
http://www.eclipse.org/forums/index.php?t=tree&goto=4004 01&#page_top
There is this open bugzilla:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=201662
@Ed, if we ignore the suppressing elements/levels when serializing and just look at adding a level for
serializing/de-serializing lists, is that part very complex to do? (if doable I can make a shot at it as part of the
Texo project, maybe it can later be moved over to EMF, if it works :-)).
gr. Martin
On 10/14/2010 09:00 AM, Jean Duracel wrote:
> Dear readers,
> <eStructuralFeatures xsi:type="ecore:EReference"
> Which gave me :
> <achats>
> </achats>
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [TEXO] XML serialization for arraylist [message #632783 is a reply to message #632767] Thu, 14 October 2010 09:14 Go to previous messageGo to next message
Hello Martin,
I will modify my xml files to meet this point.
Thanks for your quick answer and good work.
Re: [TEXO] XML serialization for arraylist [message #632943 is a reply to message #632767] Thu, 14 October 2010 17:32 Go to previous message
Martin,
There's quite an extensive patch in there. It's been a long time since
I looked but my comments there indicate it's still rough. Part of the
reason for focusing on the XML Schema stuff is that the serialization
and deserialization guidance is driven largely from ExtendedMetaData, so
if new tweaks are to be introduced, it's best for them to be properly
integrated with all the existing stuff that's intended to keep the
serialization conforming to some reasonable schema. I think there's
quite a bit of work left to do...
Martin Taal wrote:
> Hi Jean,
> serialization, I found this older post/reply on the EMF newsgroup:
> just look at adding a level for serializing/de-serializing lists, is
> part of the Texo project, maybe it can later be moved over to EMF, if
> it works :-)).
> gr. Martin
>> Dear readers,
>> Which gave me :
>> <achats>
>> </achats>
Ed Merks
Previous Topic:[TEXO] Annotation and XML attribute vs element
Next Topic:[EMF Compare] Duplicate differences into DiffModel
Current Time: Tue Apr 16 04:35:27 GMT 2024
Powered by FUDForum. Page generated in 0.09774 seconds
